Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 06-05-2013, 06:28 PM   #31
RocketJohn
Hook em' Horns!
RocketJohn's Avatar
Oddometer: 11,354
Originally Posted by groop View Post
The Land Rover isn't in the shop
We've got a winner!
RocketJohn™ - 1974 Honda CL350 / 1998 BMW R1100RT / 2013 Yamaha Super Tenere Blog
RocketJohn is offline   Reply With Quote
Old 06-05-2013, 07:00 PM   #32
Lesharoturbo
Nerdly Adventurer
Lesharoturbo's Avatar
Oddometer: 1,197
80kWh battery capacity charged in 20 minutes at 480VAC input (without losses) would require 500Amps, not really a big deal. To run one charger from solar (no storage) would require a 300kWAC array @STC or about 400kWAC to get real use out of (morning and evening). Even with 20% efficient panels, the array would cover @14,000sqft for the panel area and about 20,000sqft for a real installation with access ways, cable ways and room for the inverter and switchgear, about 2/5 of an acre for he solar alone.
Individuality is best expressed individually; you are conforming in your non-conformity.
Lesharoturbo is offline   Reply With Quote
Old 06-05-2013, 09:06 PM   #33
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 34,256
Originally Posted by troidus View Post
He was talking about being able to charge 4-10 cars simultaneously, and eventually running the chargers from solar panels. I don't see how the charging stations can be unstaffed if they're planning to swap packs, and I don't see how they can offer free charging if they have to have staff.
I think the current rapid charger is 480V, so who knows what voltage the new 20-minute charger will be.
Musk has "tweeted" that it will take less time than filling a car with gasoline. What kind of battery can be charged that fast?
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 06-05-2013, 09:40 PM   #34
Hal-Koll
socially challenged
Hal-Koll's Avatar
Oddometer: 62
Haven't you heard about putting your cell phone battery in the microwave and charging it in 1 minute? I bet they could do that with the car batteries if they build a microwave you could drive your entire car into.
Hal-Koll is offline   Reply With Quote
Old 06-05-2013, 09:51 PM   #35
troidus
Oddometer: 15,702
Dunno, but one thing about the Tesla packs is that they're made up of a crapload of small cells, so maybe he has figured out a massively parallel way to charge them and knows just how much those 18650 cells can be pushed. Or you're right that they're just going to swap packs, but then he shouldn't also be talking about a new type of charger.
troidus is offline   Reply With Quote
Old 06-06-2013, 02:45 AM   #36
motu
Loose Pre Unit
motu's Avatar
Oddometer: 4,589
I recently spent 5 years at a Mitsubishi dealership, and a couple of years ago the new iMiev demo came down from our other branch 40km away - it didn't have enough fuel in the tank to get back home. We had to change one of our outlet plugs over to charge it, although it's just the standard plug with a larger earth pin, other stuff still works on the outlet. It had 2 charge ports, one is for fast charging...and Mitsubishi won't supply the fast charge cable because it shortens battery life. Changing the battery pack on an iMiev is a simple 2 or 3 hour job, using a forklift to remove the battery.
Would be great around town, but you can't travel out of the city. It only cost 3 times the price of the iCar it's based on.
motu is online now   Reply With Quote
Old 06-06-2013, 06:57 AM   #37
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 34,256
What new type of charger? The actual charger is built into the car. The "Supercharger" is just a D.C. power supply.
Even if they charged all the cells in some sort of parallel way, that would still be 80Kwh in 20 minutes. A lot of energy and a lot of heat.
Old 06-06-2013, 06:19 PM   #38
troidus
Oddometer: 15,702
http://www.teslamotors.com/supercharger
They bypass the onboard charger. And they're charging to 50% capacity in 20 minutes and claiming that that's 200 miles of range, enough to get to the next charge port. According to the linked article, subject to demand, you can stay connected to continue charging beyond the 20 minutes. They also say that the charge rate may be reduced if the ambient temp is over 100. My guess is that they're using the onboard cooling system to pull heat out of the pack during charging.
Old 06-06-2013, 07:19 PM   #39
potatoho
Cheese and Rice!
potatoho's Avatar
Oddometer: 4,705
I saw a Miev yesterday. The owner said it was $150/mo lease and a 90 mile range. I thought it was a pretty dinky non-descript car -- but everyone was kinda talking about it with amazement.
There's been quite a push towards battery electric vehicles in the past two years. However, I feel strongly that daily battery maintenance required of ownership will make owners start to wonder why they completely restructured their lives around the needs of a fucking car
potatoho is online now   Reply With Quote
Old 06-06-2013, 07:32 PM   #40
YamaGeek
Ancient trailbike padwan
YamaGeek's Avatar
Oddometer: 6,386
And we haven't as a society done this with cars and car travel in general?
I'm not sure why we cant just start making economical small IC powered vehicles ( cars..), like the rest of the world does. I guess I'm jaded as I'm fine with two motorbikes that get near to over 100 mpg. It seems a well designed small car could get 60-65 mpg with regular gasoline and a light foot.
We're here because of a love most exestential. (toothy)
YamaGeek screwed with this post 06-06-2013 at 08:33 PM
YamaGeek is offline   Reply With Quote
Old 06-06-2013, 07:52 PM   #41
MiteyF
MiteyF's Avatar
Oddometer: 2,042
No, read it one more time. It's 200 miles on a FULL charge, only 100 miles on a 20-30 minute "quick" charge.
The Model S can travel about 200 miles, or for about three hours, when fully charged. With the network, it can be recharged to 50 percent of its battery capacity in 20 to 30 minutes,
People tell me I have a motorcycle problem. I tell them, I may have problems, but motorcycles are the solution.
MiteyF is offline   Reply With Quote
Old 06-06-2013, 08:07 PM   #42
Jurgen
Trolljegeren
Jurgen's Avatar
Oddometer: 42,889
Originally Posted by svs View Post
Got in on the First Response!!
That picture is historic for me as it's the first electric vehicle I've seen parked in a residential driveway and plugged in... I think that will be much more common in years to come...
I should've taken a pic of my neighbor's Volt with the extension cord running to it. But they are moving now and it is no longer out front.
They're nihilists, Donny, nothing to be afraid of.
Originally Posted by nskitts View Post
I'm sorry your dog died before you got to beat it with a dead chicken.
Moderator:CSM/JoMomma/ShinyThings/Sports
Jurgen is offline   Reply With Quote
Old 06-07-2013, 05:48 PM   #43
potatoho
Cheese and Rice!
potatoho's Avatar
Oddometer: 4,705
It's the daily maintenance of a battery electric vehicle which is the deal killer. Charging isn't passive like pouring gasoline. It a dynamic process that's just as fallible as every other consumer electronic -- in that once you get fancy and set up the timed charge (for better cost) it becomes more like a Windows upgrade where you cross your fingers that it'll work out by morning. And for charging while out and about, there's story after story on the forums of charging station incompatibilities, inexplicable charging rates (dependent on which port you connect), even charger corruption where the car's port or firmware gets damaged.
It's not that big of a deal, just early adopter problems. However, cars are a particularly unwelcome thing to have reliability issues. That's what I meant, are people ready to have their car create so much drama in their lives.
The other thing is parts cost. Insane! To sip the juice they put in the most expensive, efficient components. Having to pay $600 for headlights and other thrift store level parts goes against the whole ethos of an economy car.
Old 06-08-2013, 11:56 PM   #44
troidus
Oddometer: 15,702
ABB has a bus charging system that supplies 400 kW in a 15-second burst during stops, then they top off the pack at the end of the line in 3-4 minutes. Then they give it a full charge overnight. No info on total battery capacity, though.
http://www04.abb.com/global/seitp/se...Tosa+e-bus.pdf
If 400 kW can be sustained, that would permit fully charging an 80 kWh Tesla in 12 minutes. (Unless my math is way wrong.)
Old 06-10-2013, 09:28 AM   #45
ig_88e
Oddometer: 152
Flow battery? Essentially it's a battery with changeable electrolyte.
You would pull up to the electricity pump (no joke), hook up and in and out hose, and change out the electrolyte.
https://en.wikipedia.org/wiki/Flow_battery
Just a guess. Regular batteries do not like quick charge.
As to the discussions about PV arrays to charge, you could have an array that charged a bank of ultracapacitors, and then go from that to the car. Unless the station is charging cars non-stop, you can reduce the size of your array pretty easily.
ig_88e is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 03:29 AM.
