Old 06-04-2013, 07:46 PM   #1
Monty348 OP
Monty348's Avatar
Oddometer: 63
Brembo brake master cyl. Fantic 309
"New to me" 309 Fantic. I took the cap off the front master cylinder this evening to change the brake fluid and found two pieces of course plastic mesh inside with the fluid. A better description would be to say they were small cubes of plastic scouring pad. Do these belong in there? Are they some sort of baffle?
Monty348 is offline   Reply With Quote
Old 06-14-2013, 10:54 PM   #2
LarryDawg
trials nut
LarryDawg's Avatar
Location: Nickerson/Hutchinson Kansas=Cesspool of the World
Oddometer: 74
I've worked on and ridden lots of bikes and have never seen anything like that in a mastercylnder on motor cycles, maybe some of the smaller Cars would have it but never seen it in motor cycle. My two cents
Larry
"you dont quit riding Cuz' ya got Old!!! Ya get Old Cuz' ya quit riding!!!
1976 Honda TL 250 (Dozer!)
LarryDawg is offline   Reply With Quote
Old 06-15-2013, 08:58 AM   #3
Boom Boom
Oddometer: 228
My 307 Fantic had the same thing, never removed them and everything worked fine. No idea what function they served.
2014 Sherco ST 300
2014 Sherco SEF-R 300
2013 Sherco X-ride
Boom Boom is offline   Reply With Quote
Old 06-15-2013, 02:13 PM   #4
Monty348 OP
Monty348's Avatar
Oddometer: 63
After quite an extensive web search I found that a Suzuki of some sort from the mid '80's used the same master cylinder. The parts fiche showed these and listed them as "filters".
I cleaned and dried them quite well and put them back in place. As long as they don't deteriorate all will be well.
Times are GMT -7.   It's 12:42 AM.
