Old 09-19-2013, 01:38 PM   #31
MikeinEugene
MikeinEugene's Avatar
Oddometer: 2,482
Originally Posted by disston View Post
I removed some rust from a couple of clamps on the carbs of my bike and 4 bolts on the handlebar. Did this last week with phosphoric acid. Now they are worse, more rusted, than they were the week before. I got no protection from further rusting.
I'm going to try again. Maybe I didn't let it sit in the acid solution long enough?
A few posts up there was mention of covering whatever was recently de-rusted with WD40.
MikeinEugene is offline   Reply With Quote
Old 09-19-2013, 02:16 PM   #32
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 12,457
you need to put someting on em to protect them from the atmosphere, or you'll just keep getting fresh rust. the acid won't protect anything, justy remove the top layer of meterial, leaving a fresgh surface of metal to be attacked.
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance. T.R.
Old 09-21-2013, 08:04 AM   #33
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,394
I've read on other sites about using vinegar and will try it next time. I've been using Evaporust, wire brush, sand paper, sanding disc etc. No blast cabinet, yet. It's a lot of work. Thought of doing this.
I've cleaned a lot of parts and want to reuse them. What are people using to prevent the rust from coming back? I've got the parts coated in WD40 and have been looking at Eastwood cadium plating color paint, but have heard it looks terrible. Any suggestions?
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 01-04-2014, 11:37 AM   #34
hillbillypolack
Grumpy Old Goat
hillbillypolack's Avatar
Oddometer: 6,146
How could this process be used on an entire motorcycle or car frame?
Or does the piece need to be completely immersed in the solution?
I found Jesus. He was behind the sofa the whole time.
1996 M900 2012 GS 2008 Megamoto 2008 S2R
2006 HP2e
hillbillypolack is offline   Reply With Quote
Old 01-04-2014, 11:50 AM   #35
hpsVFR
Hoosier Daddy
hpsVFR's Avatar
Oddometer: 1,344
The piece needs to be completely immersed.
I'll get back in the saddle again if it kills me...
hpsVFR is offline   Reply With Quote
Old 02-16-2014, 04:44 AM   #36
YYguy
YYguy's Avatar
Oddometer: 2,177
Originally Posted by JimVonBaden View Post
Jim
Jim, your response makes me think there's a ACF-50 thread somewhere but I couldn't find it. In fact, I found this thread by searching for one. On the UK GSer site, ACF-50 is very popular and gets mentioned often as a preventative anti-corrosive. As with all these chemical topics, I only know that I don't know enough to have an educated opinion. So, is there a downside to that stuff?
_____
YYguy
YYguy is offline   Reply With Quote
Old 02-16-2014, 09:15 AM   #37
falcofred
aka Beer Scout
falcofred's Avatar
Oddometer: 260
Originally Posted by 396 View Post
Cool process, but after reading about the hydrogen being formed and released from the surface of the steel, it sparked my memory. I've had some grade 8 bolts fail in the past due to "hydrogen embrittlement" It's a process where the steel ends up with microscopic pressure points than can lead to cracking. It might not apply here, but I don't think I would try this on a drive chain.
From Wiki:
Hydrogen embrittlement is the process by which various metals, most importantly high-strength steel, become brittle and fracture following exposure to hydrogen. Hydrogen embrittlement is often the result of unintentional introduction of hydrogen into susceptible metals during forming or finishing operations and increases cracking in the material. This phenomenon was first described in 1875.[1]
Hydrogen embrittlement can occur during various manufacturing operations or operational use - anywhere that the metal comes into contact with atomic or molecular hydrogen. Processes that can lead to this include cathodic protection, phosphating, pickling, and electroplating.
I'm in Aerospace, when we have steel parts over 180 KSI cadmium or zinc plated, the process specifies a baking process to immediately follow the plating to "bake out" the hydrogen. The process then calls for the parts to be ink stamped "baked"
Well, I don't know, but I've been told
You never slow down, you never grow old.
Tom Petty - Last Dance with Mary Jane
2010 Ducati Multistrada, 2007 KTM Superduke, 2005 DR650 Father & Son Ride Nova Scotia
falcofred is offline   Reply With Quote
Old 02-16-2014, 10:07 AM   #38
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,632
I won't look it up this morning but I am pretty sure that ACF-50 is Lanolin Wool based. If so I have been using similar products in different brand names for much longer that the Internet and haven't found a downside to it.What I have is mostly sold for machine tools, sure keeps the tablesaw and others from rusting and the upside on woodworking tools is that it does not contain sillicone, I don't like spraying that kind of silicone products in my shop, gets everywhere and will eff...up any finishing/painting job if not removed beforehand and that's hard to do on some porous surfaces.
Upside is that it gets into the metal casting pores such as unprotected aluminiums,cast irons and others and makes everything much easier to clean later, any good soap will break down the Lanolin and the dirt will lift at the same time.And to some extent will dissolve the whitish powdery corrosion on Alu and also make that easier to remove and polish later. And same with rusty steel, I sometimes restore antique tools and and give them a good coat, let it sit and later remove the now softer rust.
As for V-Twin's question up there.....unanswered as to the flash rust and further protection? I am trying this on some car parts exposed to salt and yes a couple bolts on my bike:
http://lloyds.targetnetwork.net/kryptonite-metal-treatment-satin-black-20-l-pail-5-25-gal/
NO I didn't buy a 20L pail.....455 ml for $20.00 and sure a lot of coverage, I have hardly used any and painted rather large parts with it.
Don't know yet but preliminary tests at work in a bucket of seawater, little parts did quite good after a 3 weeks immersion. And that's a Canadian product, specs are good for heat resistance etc etc...!Haven't had time to see if it can be powdercoated, futher tests will come eventually.
Have tools, will travel!
H96669 screwed with this post 02-16-2014 at 10:14 AM
Old 02-16-2014, 10:35 AM   #39
vtwin
vtwin's Avatar
Oddometer: 7,394
Thanks for the info Concours. I've been just spray painting the parts in clear. I should have bought a zinc plating kit like others have.
Monroe.
unknown
Old 02-16-2014, 05:55 PM   #40
JimVonBaden OP
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,344
I'm sure it works well as an anti-corrosive. My good friend uses it, but working on a bike covered in that crap is a nasty frustrating mess!
JimVonBaden is online now   Reply With Quote
Old 02-16-2014, 06:30 PM   #41
danfmc
Oddometer: 25
Hello to all.
Recently I bought an old motorcycle, and it has small rusty spots on frame, near some original welding.
What can I do to get rid of this rust without dismantling the whole bike? I have a bottle of phosphoric acid and I was thinking of getting a rag soaked in acid and cover the rusty part with it, and then paint the part with a small paintbrush with oem color. I'm not thinking about getting rid of the rust with something like sandpaper because it might weak the frame, don't you think? And will phosphoric acid corrode the painted part?
Thanks.
danfmc is offline   Reply With Quote
Old 02-17-2014, 08:12 AM   #42
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,632
Originally Posted by danfmc View Post
Hello to all.
Thanks.
You'll be fine. One good product is Krud Kutter, the one thay says "The must for rust" on it does contain Phosphoric Acid and does neutralize the rust for maybe a year according to the claims on the container.
But I like the rust converters made out of Tannic/gallic acids. They are usually milkish white in color unlike the clearish Phosphorics. And convert the rust to a darker black polymer. The phosphorics are more like a clearish varnish. I wonder how much snow is over my test piece???....been outside for a couple years I should look for it if just to show the difference between the two products.
Old 02-17-2014, 03:37 PM   #43
danfmc
Oddometer: 25
But can I apply it soaking a rag and applying it for a few hours to the rusty surface, with a solution with phosphoric acid suitable for remove rust? And will it ruin the paint job? The part I need to remove rust is this
Old 02-18-2014, 07:18 AM   #44
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,632
^^^ Remove the privacy setting on your pic.
Old 02-18-2014, 08:39 AM   #45
Treadless
seeking adventure
Treadless's Avatar
Oddometer: 5,338
If ruined paint to you is stained or etched then yes it will ruin it. If ruined is blistering-pealing then no it likely won't. Best to test a spot that is somewhat out of sight to be sure.
Locktite has a product (can't recall the name right now) that is easy to use and is applied to surface rust and piant bonds well to. Taking a route like this might be safer for you and the bike and produce a better result than using an acid.
Treadless is offline   Reply With Quote
Times are GMT -7.   It's 09:17 PM.
