Old 06-04-2013, 10:24 PM   #1
kvr929rr OP
kvr929rr's Avatar
Oddometer: 180
Klim warranty: Slow start, Helpful Rep, Stay tuned
I am really smokin' pissed. On the 10th time I wore my klim traverse jacket the bottom slider of the zipper fell out. Since I was on a trip I couldn't put it out of order and send it right in so I tried to put a zipper stop on it and when that didn't work I tried to glue the bottom slider in place so I could use the jacket until I could get it fixed properly. All I did was put a little glue at the bottom of the slider to hold it in place so I didn't lose it en route and could line up the zipper to make it work. Well that didn't work and the slider came off and the zipper came apart and got stuck so I had to pull the zipper apart to get the jacket off which pulled off a few teeth. I fedexed it to them when I could ($65) for them to evaluate a warranty repair. klim which "guarantees their product against materials and workmanship defects for life" wouldn't repair it under warranty because I had tried a home repair. WELL , IF YOUR ZIPPER DIDN'T BREAK IN THE MIDDLE OF MY TRIP THEN I WOULDN'T HAVE TO FIX IT. Grrrr!! They wanted $80 to fix it plus money to send it back probably another $65 to get it back for a return trip. Screw that. $220 to fix a $300 jacket that shouldn't have had this problem in the first place. I have been buying and using adventure gear for a long time (30+ years) and I have never had a zipper fail. I spend the money and buy quality gear so it doesn't fail when I need it.
Other complaints:
The pitzips snag on the surrounding material.
The fit is adequate for 13 year old prepubescent girls which I guess the Europeans think we should all look like.
The arms don't have enough room to put in D3O armor and flex your arm 120 degrees
The collar is too big to seal out the elements. (a big error in an all weather jacket)
The D3O armor has only adequate protection for street riding and you could not fit a pressure suit or armored mesh shirt underneath unless you are built like the aforementioned 13 year old.
kvr929rr screwed with this post 06-08-2013 at 07:10 PM
kvr929rr is offline   Reply With Quote
Old 06-05-2013, 02:12 AM   #2
atravlr
atravlr's Avatar
Oddometer: 204
Give Olympia a try,
they are cut for American sized guys.
atravlr is offline   Reply With Quote
Old 06-05-2013, 02:51 AM   #3
Riot
Tiger Rider
Oddometer: 105
Eek
Have I got this right:
You bought a jacket.
Its too small - "..The fit is adequate for 13 year old prepubescent girls .."
You then added armour under the jacket.
You wore it anyway 9 other times even though it was too small instead of taking it back.
The zipper broke.
You tried a trail fix or two.
They would not honour warranty?
Riot is offline   Reply With Quote
Old 06-05-2013, 06:49 AM   #4
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,427
Why do ya'll add that useless, unneeded "U" to words? I mean it still sounds the same without it. HONOR. Go ahead and try it, it won't hurt you.
OK, back to your prepubescent finger pointing.
Albie screwed with this post 06-05-2013 at 06:55 AM
Albie is offline   Reply With Quote
Old 06-05-2013, 07:33 AM   #5
max384
Disgruntled Student
max384's Avatar
Oddometer: 3,338
That sucks. A trail fix really shouldn't void a warranty. If you're out on a trip and the zipper fails, you don't have much of a choice but to make a temporary fix. This is very disappointing to hear, since I ride with a Klim jacket.
On a side note, you have a very valid complaint. Why muddy the waters with every other little grip you have about the jacket? It just sounds like sour grapes to me. If you had stopped after the first paragraph, few could find fault in your post. However, now you just come across like a whiny bitch throwing a temper tantrum. If you have a valid complaint, make it, and be done with it. Otherwise, it's hard to take your real complaint very seriously.
You do realize the rest of the world spells it with a 'u,' right? The word was also first spelled with a 'u' and then the spelling was later changed in America. The question you should really ask is why don't we also spell it with a u.
'09 Suzuki SV650, '02 KLR250, CRF70 and 80 for the kids IBA # 56419
Newfoundland 2012
James Bay 2014
max384 is offline   Reply With Quote
Old 06-05-2013, 07:35 AM   #6
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,427
The answer is, because we figured out it wasn't needed.
Old 06-05-2013, 07:59 AM   #7
Hetzel88
cycles is a mean toy
Oddometer: 170
No twatwaffles or shitwhistles in that rant anywhere. I'd rate it a 5 at best.
Hetzel88 is offline   Reply With Quote
Old 06-05-2013, 08:19 AM   #8
Cerberus83
The Wingman
Oddometer: 142
Neither is herb
Cerberus83 is offline   Reply With Quote
Old 06-05-2013, 11:14 AM   #9
SnowMule
[angry moth noises]
SnowMule's Avatar
Oddometer: 18,530
I've had the same issue with their warranty/repairs... jacket had a couple of holes and seams tearing, took them two tries to get that right.
$300 sled pants got holes in the knees after about 200 miles of riding, and I got a "Nope, not covered under warranty, but we'll fix each hole and tear for $50 each!" Thanks but no thanks.
Local lady quoted about $50 to fix ALL the holes/snags, in addition to reinforcing the knee panels, altering the waistline, and adding belt loops. Sledders are apparently all either short and skinny, or tall and fat... no gear for tall-skinny riders.
It's good gear when it holds up, but I certainly wouldn't pay retail (or near-retail) in hopes that they honor their warranty when the time comes...
Spewer of the poignant non sequitur
SnowMule is offline   Reply With Quote
Old 06-05-2013, 11:17 AM   #10
Smoke Eater 3
Oddometer: 692
This is good to know. I was about to drop a grand on Klim gear.
Smoke Eater 3 is online now   Reply With Quote
Old 06-05-2013, 11:21 AM   #11
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,427
Originally Posted by Cerberus83 View Post
Neither is herb
huerb????
Old 06-05-2013, 11:32 AM   #12
BlueLghtning
Riding is my passion
BlueLghtning's Avatar
Oddometer: 5,120
Disappointing to hear they wouldn't honor your warranty claim. When you are out riding and the gear you are wearing fails, you have to do what you can to continue on. I do agree with max384 that the rest of your complaints was just petty stuff you were pissed off about. Failures can happen in any gear, but them denying the claim is definitely something to wonder about.
I bought a Klim Lattitude Jacket and Traverse pants last year and my wife is wearing latitude pants and a Traverse jacket we got this year for her. We are both really enjoying it and so glad to not be screwing with rain gear anymore. At this point, we'd still continue to buy Klim gear and seems pretty well built. We've been through lots of other crap gear over the years.
My gear has been worn a lot and so far is standing up to it very nicely. I really like the Overland jacket that came out.
BlueLghtning - Follow me on my SPOT Messenger
Mine: 09 DL650, 08 WR250R,
Hers: 07 Ninja 650R, 13 CRF250L,
Smugmug Pics - Save $5 <-- Click Here
BlueLghtning screwed with this post 06-05-2013 at 11:37 AM
BlueLghtning is online now   Reply With Quote
Old 06-05-2013, 11:42 AM   #13
L.B.S.
Oddometer: 1,323
Get back to us with how well spelling: nife, sord, sutle, scool, riting and so on, works out for you.
The Tom of the unown soljer?
L.B.S. is offline   Reply With Quote
Old 06-05-2013, 11:54 AM   #14
slartidbartfast
Love those blue pipes
slartidbartfast's Avatar
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,863
Neither is herb
That one is spelt correctly whichever side of the Atlantic you are on. Most Americans simply don't pronounce it correctly.
While the commonly cited their/there/they're and similar butchering of the language irritates me too, moaning about spelling on here is irrelevant and pretentious
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100
January 2010 New Zealand South Island ride
Summer 2009 UK to Alps ride
Summer 2008 UK End-to-End ride
slartidbartfast screwed with this post 06-05-2013 at 12:03 PM
slartidbartfast is offline   Reply With Quote
Old 06-05-2013, 12:10 PM   #15
Mr. Canoehead
Taste Gunnels!
Mr. Canoehead's Avatar
Location: Calgary, Too far to the mountains and too cold
Oddometer: 1,581
If the OP is Canadian (and with KVR in his name, he probably is) then "honour" is the correct spelling, eh.
We can't all dumb down English. just because it makes sense!
2006 FJR1300A, 2005 GS1150 Adventure, 2002 DR650 SE, a fortune in Farkles.
"No matter how many [internet] opinions you line up, you can't vote nonsense into truth"- Kevin Cameron
Mr. Canoehead is online now   Reply With Quote
Times are GMT -7.   It's 07:49 AM.
