Old 06-05-2013, 12:25 PM   #1
Irish John OP
Oddometer: 234
Sticking forks on a TLR
Well lots of good info and opinions shared in TLR jetting thread. However, I have now run into a new problem unrelated to the jetting issue.
Last night, I pulled the forks to install new seals and wipers. Left fork, came apart easily. Right fork took a fair bit of persuasion to get the tube our of the lower. The tube will only slide smoothly into the lower about 3" then it starts to stick and wedge itself in place. First thought the tube is bent, checked it with a straight edge and on a glass top table, it's good to go. I can not see anything inside the lower, no obvious our of round or dimple. Check it with the other tube same thing. So I'm thinking it is out of round or there is a slight dimple on the inside. The exterior does have a fairly good gouge where it looks like it hit a rock.
So I suppose I will need to find a new lower fork leg or a maybe a cylinder hone with a long shaft to reach down inside and see if I can round it out. Anyone experience something like this?
Irish John is offline   Reply With Quote
Old 06-05-2013, 11:29 PM   #2
Twin-shocker
Oddometer: 1,673
Why not take the fork leg to a good engineering shop, ask them to check the internal bore, and if its damaged see if they can rectify the problem?
Old 06-06-2013, 12:58 AM   #3
LarryDawg
trials nut
LarryDawg's Avatar
Location: Nickerson/Hutchinson Kansas=Cesspool of the World
Oddometer: 74
fork bushing
I built a new one from oil in impregnated brass for fellow inmate ADVCoop send me dimension s and I can make you one if you are unable to find one
Larrydawg
"you dont quit riding Cuz' ya got Old!!! Ya get Old Cuz' ya quit riding!!!
1976 Honda TL 250 (Dozer!)
LarryDawg is offline   Reply With Quote
Old 06-06-2013, 05:45 AM   #4
ADVCoop
ADVCoop's Avatar
Oddometer: 792
Larry does great work! That bushing was a perfect fit and got me riding again.
2006 Husqvarna TE610 - 1982 Suzuki PE175 - 2009 Yamaha XT250 (wife's)
ADVCoop is online now   Reply With Quote
Old 06-06-2013, 02:19 PM   #5
Irish John OP
Oddometer: 234
I don't think it needs a bushing, it seems like the fork tube encounters some type of interference down inside the tube which wedges the tube and does not allow it to slide down further.
Old 06-06-2013, 08:42 PM   #6
Irish John OP
Oddometer: 234
Well I borrowed a dail gauge and there is dimple inside the lower fork tube caused by a ding on the exterior. No all I have to do is figure out how to reduce it.
Old 06-07-2013, 09:14 AM   #7
LarryDawg
trials nut
LarryDawg's Avatar
Oddometer: 74
have you seen this place john
http://hondarestoration.com/nosResul...+Reflex-1986-Q
it has a lot of parts for your bike
Larry
Old 06-07-2013, 09:39 AM   #8
Irish John OP
Oddometer: 234
Thanks Larry!
Old 06-07-2013, 11:24 AM   #9
Irish John OP
Oddometer: 234
Larry, PM inbound
Times are GMT -7.   It's 05:47 AM.
