Old 06-12-2013, 03:05 PM   #16
roamer OP
roamer's Avatar
Oddometer: 308
Doing the layout for the swingarm fixture.
Quote, Said GusGus, "Duct tape is like the Force. It has a light side, a dark side, and it holds the universe together.... ."
06 R1200GSA, 08 KTM 450EXC 06 1000S DS Multi, 06 KTM 450SMR, 08 KTM 450SMR, 08 KTM Superduke.
roamer is offline   Reply With Quote
Old 06-12-2013, 08:40 PM   #17
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,609
Impressive!
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is online now   Reply With Quote
Old 06-12-2013, 09:08 PM   #18
Donkey Hotey
De Jo Momma
Donkey Hotey's Avatar
Oddometer: 11,971
I'm more impressed by the tools you've got at your disposal. Holeee-crap! I didn't think the Z-axis way covers looked like Haas but, now I'm going to guess VF-4. Nice 3D taster which says nothing about all the fixture plates. Most people have no idea what you've got tied up there but, I do. Wow!
Donkey Hotey is offline   Reply With Quote
Old 06-13-2013, 06:48 AM   #19
roamer OP
roamer's Avatar
Oddometer: 308
That's a VF2. The tooling often takes more time than the part I'm making.
Sent from my Nexus 7 using Tapatalk 2
Old 06-13-2013, 08:30 AM   #20
Donkey Hotey
De Jo Momma
Oddometer: 11,971
If I spent more time in my VF-2, I'd recognize the damn table and way covers. Yeah, the setup and tooling are what people never see.
Old 06-14-2013, 07:51 AM   #21
roamer OP
roamer's Avatar
Oddometer: 308
Starting the swingarm. The six machined spud ends can be seen bolted to the uprights. The spuds have a semi-press fit into the tube, with a .06 chamfer on each for the weld.
Old 08-19-2013, 12:50 PM   #22
roamer OP
roamer's Avatar
Oddometer: 308
Some more progress on the swing arm..
Old 08-19-2013, 12:52 PM   #23
roamer OP
roamer's Avatar
Oddometer: 308
Back into the machine to align bore the bearing bores..
Old 08-20-2013, 05:53 AM   #24
pennswoodsed
lizards,bugs and me
pennswoodsed's Avatar
Oddometer: 759
Wicked Tooling and fixtures
Be a shame to build all those beautiful jigs for one copy
pennswoodsed is online now   Reply With Quote
Old 08-20-2013, 07:00 AM   #25
roamer OP
roamer's Avatar
Oddometer: 308
That's true.
If this prototype works like its intended, I might make more.
Old 08-21-2013, 09:21 PM   #26
MiteyF
MiteyF's Avatar
Oddometer: 1,995
Subscribed. I always wished I had more time to design/machine motorcycle parts when I had access to all the tools... someday when my woman makes me all that money I've been needing :-)
People tell me I have a motorcycle problem. I tell them, I may have problems, but motorcycles are the solution.
MiteyF is online now   Reply With Quote
Old 08-21-2013, 10:15 PM   #27
Pezz_gs
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,784
Roamer,
This is looking very nice
Im watching this build
Airhead Tragic
I'm not a complete idiot -- Some parts are missing
XR460/4 - http://www.advrider.com/forums/showthread.php?t=497905
Pezz_gs is offline   Reply With Quote
Old 08-22-2013, 04:24 AM   #28
Scubawerx
Scubawerx
Oddometer: 202
Awesome Details
Very subscribed!
Scubawerx--Underwater Search Salvage and Recovery
Scubawerx is offline   Reply With Quote
Old 08-22-2013, 07:19 AM   #29
roamer OP
roamer's Avatar
Oddometer: 308
Once the bores are all squared up, the boring head was put to work. The upper bore in this video was done first, then an extension was added. This allowed the boring head to pass thru the finished bore and reach the lower bore all in one clamping.
If I were to flip the fixture and do the second bore, that would be an opportunity to introduce error. This worked really well. When uninstalled the pivot shaft, it went in smooth as glass.
https://www.youtube.com/watch?v=Hwkv...e_gdata_player
Sent from my Nexus 7 using Tapatalk 4
Old 08-22-2013, 12:45 PM   #30
Donkey Hotey
De Jo Momma
Oddometer: 11,971
...then an extension was added. This allowed the boring head to pass thru the finished bore and reach the lower bore all in one clamping.
You MUST do tool and die work to have a boring setup that specialized. Dual cutter or just rigid as hell?
If somebody walked in off the street and needed that done, most would have no idea how expensive that would be or the investment in tooling involved. Bravo!
You must have assembled everything in-place and hoped you didn't accidentally move X & Y. The VF-2 doesn't have enough Z travel to pull that cutter all the way out of the part.
(edit: MAYBE it does...JUST barely)
Times are GMT -7.   It's 05:32 PM.
