Old 08-22-2013, 05:45 PM   #31
roamer OP
roamer's Avatar
Oddometer: 308
It's a KOMET boring system. The extensions are really rigid. A lot of light cuts to prevent deflection and chatter.
With the right combination of extensions, I was able to just clear the top bore.
It worked pretty well, roundness is under .0001" and the concentricity between the two bores is under .0002".
I'm happy with that.
Sent from my Nexus 7 using Tapatalk 4
Quote, Said GusGus, "Duct tape is like the Force. It has a light side, a dark side, and it holds the universe together.... ."
06 R1200GSA, 08 KTM 450EXC 06 1000S DS Multi, 06 KTM 450SMR, 08 KTM 450SMR, 08 KTM Superduke.
roamer is offline   Reply With Quote
Old 08-22-2013, 06:25 PM   #32
OaklandStrom
Oddometer: 1,612
I'm confused. The upload date on the video is 2011.
Are you building this now, or did you do some of the work a few years ago?
Originally Posted by roamer View Post
Once the bores are all squared up, the boring head was put to work. The upper bore in this video was done first, then an extension was added. This allowed the boring head to pass thru the finished bore and reach the lower bore all in one clamping.
If I were to flip the fixture and do the second bore, that would be an opportunity to introduce error. This worked really well. When uninstalled the pivot shaft, it went in smooth as glass.
https://www.youtube.com/watch?v=HwkvZhRfahw&feature=youtube_gdata_player
For sale:
Wee Strom Racks http://advrider.com/forums/showthread.php?t=908855
Saddle bags and duffel http://advrider.com/forums/showthread.php?t=908849
OaklandStrom is offline   Reply With Quote
Old 08-24-2013, 08:39 AM   #33
roamer OP
roamer's Avatar
Oddometer: 308
The shock mount on the swing arm, The tube clamp portion is slightly offset, and the mount block is offset, making for a few combinations of leverage adjustment. That shock is not going to be used, its just for checking clearance of the lower shock eye.
Old 08-24-2013, 07:27 PM   #34
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,643
This is some great work. Keep the updates coming.
I really miss having access to Haas equipment.
I really don't miss working in a machine shop.
A VF2 in my garage would suit me nicely.
crazydrummerdude is offline   Reply With Quote
Old 08-26-2013, 09:40 AM   #35
roamer OP
roamer's Avatar
Oddometer: 308
Got a few of these knocked out...
Old 08-26-2013, 02:21 PM   #36
Krasniewski
I don't ride much.
Krasniewski's Avatar
Oddometer: 1,270
I'm curious as to why the 848... power to weight, or a personal affinity?
Looks beautiful - really nice work there.
Krasniewski is offline   Reply With Quote
Old 08-26-2013, 02:53 PM   #37
roamer OP
roamer's Avatar
Oddometer: 308
A little of both really. The horse power is just right for the application, I don't follow the "bigger is better" mindset.
There are a couple unique features that will become apparent once its complete.
Times are GMT -7.   It's 10:53 PM.
