Old 06-10-2013, 06:18 PM   #1
grizCP OP
DROC
grizCP's Avatar
Oddometer: 371
Why do I keep breaking footpeg springs?... rrr.
So, I have now broken 3 springs on my left footpeg this year. There seems to be nothing abnormal/defective about the springs when I put them on... the pedal seems fine - it is a Fastway F3... but the spring keeps snapping in the same spot where the loopy doodad end touches the frame mounts. See the pics. Why is this happening? Any suggestions? Or alternatively, a CHEAP source for springs? Thanks.
99 Honda XR600R / 06 KTM 450 XC / 97 Beta Techno 250
grizCP is online now   Reply With Quote
Old 06-18-2013, 09:56 PM   #2
RDM
RDM's Avatar
Oddometer: 108
Maybe there is a sharp edge right there that wears a grove in the spring causing it to weaken. If so you could file the edge to smooth the it off or try a piece of tubing over that part of the spring to cushion it.
RDM is offline   Reply With Quote
Old 06-19-2013, 11:52 AM   #3
SnowMule
[angry moth noises]
SnowMule's Avatar
Oddometer: 18,606
Try putting a glob of RTV on the spring.
Old trick snowmobilers use on the springs holding pipe and exhaust can together, RTV kills some of the vibrations that wear on the springs.
Spewer of the poignant non sequitur
SnowMule is offline   Reply With Quote
Old 06-19-2013, 08:04 PM   #4
Adios Pantalones
AdventureDeficitDisorder
Adios Pantalones's Avatar
Location: San Diego, not Mex, but I can smell it from here.
Oddometer: 2,331
This. I bet there's a burr on that edge.
Adios Pantalones is offline   Reply With Quote
Old 06-20-2013, 08:46 AM   #5
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,301
I'd soften the spring at that bend, that will cure the breaking issue.
Submerge the spring in a pan of water so the bend sticks up above the surface 1/2" or so but leave the coil in the water, just so you can get heat at where it snaps, then heat it with a propane torch just until it starts glowing and then let it cool naturally and it will not break on you.
GreaseMonkey is offline   Reply With Quote
Old 06-20-2013, 11:39 AM   #6
mpatch
Oddometer: 996
is the peg hitting the spring when folded and smashing the spring?
mpatch is online now   Reply With Quote
Old 07-04-2013, 05:27 AM   #7
grizCP OP
DROC
grizCP's Avatar
Oddometer: 371
I don't think so.... at least not when you move the peg by hand...
Old 07-04-2013, 05:30 AM   #8
grizCP OP
DROC
grizCP's Avatar
Oddometer: 371
I think the plan of attack will be to lightly file the frame mount and paint. I think y'all might be on the right track with the burr. Thanks.
Times are GMT -7.   It's 07:30 PM.
