Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 06-10-2013, 10:48 PM   #1
Patrol OP
VALE 46!
Patrol's Avatar
Oddometer: 1,366
Moonshine: I need the how to
I recently visited the Smoky Mountain area and sampled peach moonshine. I love it. And I love the idea of making it yourself, if for no other reason that to be able to serve it to friends around the bonfire. Can anyone give me some insight into the process? Is it too complicated to just make a small batch as an entertaining experiment?
Somewhere between One Love and Molon Labe
Patrol is offline   Reply With Quote
Old 06-10-2013, 11:12 PM   #2
fz6kd7
Oddometer: 789
I had a great uncle that (used) to make shine when
i asked about a recipe the most i could get was to
clean really good between batches.
fz6kd7 is offline   Reply With Quote
Old 06-11-2013, 04:01 AM   #3
Rutabaga
Oddometer: 732
Make sour mash with most anything you want or have laying around. Heat it in covered container and recover the boil off via a condensing tube. Drink.
Might be expensive or not depending on your toy budget but quite simple. I am sure Google can be more specific.
Rutabaga is offline   Reply With Quote
Old 06-11-2013, 04:50 AM   #4
No False Enthusiasm
a quiet adventurer
No False Enthusiasm's Avatar
Oddometer: 4,731
Buy a gallon of kerosene... pour into pint sized mason jars and cap...
Pretty close to the more fashionable stuff...
NFE
No False Enthusiasm is online now   Reply With Quote
Old 06-11-2013, 05:02 AM   #5
Nytelyte
Somewhere about
Nytelyte's Avatar
Oddometer: 682
Do you want whiskey, or simply potable ethanol? Whiskey requires a pot still and you retain more of the flavor of what you put into it (traditional 'shine) or you can build a column still and get a more 'refined' but neutral product, more like vodka. Nice side of that is anything that can be fermented can create the latter and you throw flavorants into your storage vessels.
Note: To the gov't agent reading this, its all theory and conjecture.
Nytelyte is offline   Reply With Quote
Old 06-11-2013, 05:12 AM   #6
WRrioR
Oddometer: 247
kitchen stove top get ready for the party method:
wrap copper tubing around something solid and cylindrical so that the coil will fit inside a two liter bottle. leave plenty of length on both ends. bend one up and over and attach to the top of a pressure cooker. cut the bottom off a two liter bottle of pop. drop coil into bottle and run other end out of bottle mouth. bend out the tubing and cut to whatever lenth. place this up on a wood box in the sink with a hole cut in the top for the bottle to sit, and a hole cut in the side where your tubing can protrude. attach rubber hose to reach your catch recepticle.
go buy the cheapest crap wiskey you can find, and boil it down in the pressure cooker. run cold water in to the pop bottle over coils while this is going on.
as the wiskey simmers and condenses, the good stuff will be released trapping the crap in the pressure cooker. Repeat two or three times as desired. catch some drip in a spoon, and if you get no blue flame when trying to ignite it, re-distill.
or make your own mash and wait weeks for it to ferment. really good shine has no taste, and will evaporate as you swallow. put some in a jar and drop in a skinned peach.
WRrioR is offline   Reply With Quote
Old 06-11-2013, 05:16 AM   #7
vwboomer
Buffoon
vwboomer's Avatar
Oddometer: 10,631
And you thought jerkin off was the only way to go blind
Honestly, it's not worth it on a small scale. More time and hassle when you can buy decent vodka pretty cheap.
i tried using a pressure cooker, copper tubing and bucket of ice. Monitored the temperatures to make sure the nasty alcohol was gone leaving only good healthy stuff. I ran it through 3 times and still wasn't very good
A good way to do it is a water heater. You can set the temp to exactly what you want, build your column and go.
But it's still not worth it small scale.
vwboomer is offline   Reply With Quote
Old 06-11-2013, 08:56 AM   #8
Patrol OP
VALE 46!
Patrol's Avatar
Oddometer: 1,366
Great info. No worries re government agents. No plans to distribute. The commercial shines (Smoky Mnt Moonshine, etc) aren't sold in Canada. I'm going to give it a go I think, just an experiment.
Old 06-11-2013, 12:10 PM   #9
Icewalker
Conundrum
Icewalker's Avatar
Oddometer: 42,608
If they are going to let folks grow pot then they need to let folks distill
But yes ... the president is a very fine fellow .... please don't rendition me to somalia ..... pretty please.
Icewalker is online now   Reply With Quote
Old 06-11-2013, 12:51 PM   #10
pilot
Slacker Moderator
pilot's Avatar
Oddometer: 31,875
That's enough of the politics.
The other 10% are sociopaths , serial killers and KLR riders. You wont get much sympathy from them.
-Furious D
Who wants to go to their grave without any scars? - tjconc
pilot is offline   Reply With Quote
Old 06-11-2013, 01:50 PM   #11
Commuter Boy
Oddometer: 2,901
What is it about cops and moonshine? My dad always ran shine (and had a skookum setup), one of his buddies set up an artisan distillery on the east coast when he pensioned out early, and another one did the same on the west coast.
Start with a basic mash. Easiest is just sugar, high alcohol yeast, some citrus fruit chopped up. Put away in a warm place for a few weeks in a closed container same as you do for brewing beer.
Rack it off once or twice, again, same process as brewing beer.
Dad had settled on a refurbed solid steel keg, welded on a temperture gauge and installed a vertical stainless slobber box on the top, with stainless ball bearing fill inside, held up by mesh. Put the keg on a propane powered turkey fryer burner, attach stainless tubing ( I think it was brake lines with flared fittings) at the top to connect to an ex-university lab glass distillation tube, water cooled from the garden hose.
Easy peasy. The above setup came apart quickly, and could be easily stored around the place so that it wasn't obviously a still Just keep your mouth shut about it too, they attract attention like nobody's business.
Commuter Boy is offline   Reply With Quote
Old 06-11-2013, 02:40 PM   #12
Fe Man
I am Iron Moran!
Fe Man's Avatar
Oddometer: 8,366
I'm not saying a word....
Physics, gravity, and law enforcement are the only things that prevent me from operating at my full potential
Fe Man is offline   Reply With Quote
Old 06-11-2013, 05:41 PM   #13
triplenickel
triplenickel's Avatar
Oddometer: 2,428
Not a problem to order one, they just sell them as being intended for water.
07 SE
PG007
Old 06-11-2013, 06:19 PM   #14
padiii
padiii's Avatar
Oddometer: 349
http://homedistiller.org/forum/index.php
padiii is offline   Reply With Quote
Old 06-11-2013, 06:52 PM   #15
Mcreviver
Oddometer: 24
The Choice of Senators
I live in a part of PA that was once home to a famous bootlegger named Prince David Farrington.
http://www.shinewhiskey.com/our-whiskey.php
According to a book written about him he had a police escort to Washington D.C. during the prohibition era to deliver product for consumption by our esteemed legislators. He had his share of troubles with the law however but he was well liked by the locals and he many times helped his friends and neighbors out financially.
Anyway, his process was described and he used steam to heat the brew instead of direct fire as many others do. This prevented "burning" of it and made the taste unique and better than his competition.
Mcreviver is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 02:14 PM.
