Go Back   ADVrider > Riding > The Perfect Line and Other Riding Myths
Old 06-11-2013, 10:58 PM   #1
One Fat Roach OP
One Fat Roach's Avatar
Oddometer: 1,615
corners
So I recently upgraded from a 250 to a 650, first ever bike to my second. I love it. Lots of power in first gear (all around too of course) compared to what I had. So I've been brave, or stupid depending how you look at it, and have been taking corners (gravel only) rather aggressively. I'll adjust my speed properly before entry, but as I come out, I'll feather the clutch and with lots of gas try to slide my rear tire to one side exiting. I've only been riding three years, but this move has gotten a hold of me by the britches. I've been practicing the for about a week now and finally had my first lay down. I knew it would happen eventually and it went pretty much how i imagined. Low side skid for a few feet, no damage to bike or myself. And because of that, i lifted the pig back up with a smiled and rode the next 30seconds home.
Is this a bad idea to keep trying this maneuver? Do you execute it on corners? How often?
Originally Posted by Apple Jam View Post
just cause we ride fast doesn't mean we're in a hurry
One Fat Roach is offline   Reply With Quote
Old 06-11-2013, 11:45 PM   #2
Tha Rick
Shake and bake!
Tha Rick's Avatar
Oddometer: 5,546
Practice makes perfect...Perfect practice on the other hand
http://youtu.be/A13hMU23Res
Embeddy no worky...click the link.
Pressure on the outside peg, a bit of countersteer, a bit of throttle(with clutch to control overdrift)
Be safe! sounds like you are, but wear ATGATT.
Happy Trails Y'all.
It's not about tha bike nor tha ride; it's about tha adventure in life we all seek. Great memories are made of taking tha trail less traveled and explored.
Tha Rick screwed with this post 06-11-2013 at 11:54 PM
Tha Rick is offline   Reply With Quote
Old 06-11-2013, 11:46 PM   #3
corndog67
Oddometer: 1,281
You'll learn about traction and whatnot, but you are going to crash pretty hard one of these days. But how else are you going to learn. If you did this on a dirt bike, you wouldn't scuff your new 650 up.
corndog67 is offline   Reply With Quote
Old 06-12-2013, 07:32 PM   #4
joexr
Oddometer: 3,773
What's the bike? Try practicing on wet grass with plenty of room till you get better. Nothing more fun than a half bald knobby on wet grass. You'll learn more control learning to flat-track than almost anything else. Try doing donuts first till you're comfortable and then go to bigger , wider arcs. When you can go both directions doing 100 yard arcs you'll be better all around.
Old 06-12-2013, 07:37 PM   #5
Tuna Helper
Rawrr!
Tuna Helper's Avatar
Oddometer: 769
That's awesome, I want to do that sometime.
Originally Posted by dogjaw
I'm a bike slut, I love them all
Tuna Helper is offline   Reply With Quote
Old 06-12-2013, 08:14 PM   #6
One Fat Roach OP
Oddometer: 1,615
2004 KLR. Im starting small for sure just trying to get the movement/control down before I try bigger. Donuts are definitely on the to do list but I can't seem to get the right lean and gas combo. One of these days lol.
Ps I have no idea what ATGATT means. Or many of the other acronyms I see on here
Old 06-12-2013, 08:19 PM   #7
Fajita Dave
Fajita Dave's Avatar
Oddometer: 717
Using the clutch to induce a slide (pull in clutch, build RPM, and dump the clutch to cause the slide) can be very difficult and unpredictable. You can't really maintain a slide this way though since you only over power the rear tire for a moment until it starts gripping again. So you either end up low siding, or the slide wasn't all that spectacular. If you're just trying to have fun and don't care about wrecking then I don't see anything wrong with it though.
The long slide you see pro racers do is from a combination of being near the cornering limits of the tire and applying the right amount of throttle for the lean angle they're at. If you want to learn that, find a slick surface like wet grass. Then lean the bike into a corner and start rolling into the throttle nice and smooth until you start holding a slide. You can use the clutch a little bit to get things started but its mostly throttle control. Gravel can be sketchy with the front tire letting go but its a pretty good place for power sliding too.
There are many more ways to hurt yourself on a motorcycle but few are more fun.
2008 GSXR 600
2001 CR250R
Fajita Dave is offline   Reply With Quote
Old 06-13-2013, 05:07 AM   #8
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,482
Sliding through rear around a corner is a valid technique for dirt/offroad riding. I'm not brave enough to try it on a 570lb sport touring bike
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 06-13-2013, 07:45 AM   #9
BanjoBoy
BanjoBoy's Avatar
Oddometer: 878
Glad yer learn sum "real" riding techniques; this will help you tremendously in the long run. Lotta riders slab fer hundreds of thousands of miles, brag'in all the while, not know'in wut theyz do'in cuz slab'in ain't ride'in. If'n yer slide'in 'round in the dirt 'n mud, yer ride'in! (Un fortunately ya get no IBA brag'in rights. )
Try slide'in up close ta the tank; that'll weight the front, and help the rear pivot around it. Also, practice spin'in up the rear in a straight line ta get the feel'in where the traction level iz, then try spin'in it up come'in off the corners. The faster ya go, the mo stable the bike will be, but also stuff happens faster, and ya get hurt mor when ya bail.
Relax 'n let the bike do it's thang; feel the bike, become one with the bike grasshopper.
All the gear all the time. I recon theyz talk'in 'bout wear'in a bunch of gear fer protection?
No gutz, no glory.
2007 FJR1300
2007 FZ6 (Dirt bike)
BanjoBoy is offline   Reply With Quote
Old 06-13-2013, 07:56 AM   #10
motorat
TBD
motorat's Avatar
Oddometer: 935
go here.
http://www.americansupercamp.com/
you will learn how to do it and have a good time
to ignore the facts does not change the facts
motorat is offline   Reply With Quote
Old 06-13-2013, 02:55 PM   #11
Fajita Dave
Oddometer: 717
Originally Posted by motorat View Post
go here.
I just wouldn't stick my leg out sideways like the guy in the cover photo of that website. That's an excellent way to screw up your knee if your foot catches anything or you try to put weight on it to catch a fall.
2008 GSXR 600
2001 CR250R
Old 06-17-2013, 06:12 AM   #12
lnewqban
Ninjetter
lnewqban's Avatar
Oddometer: 291
Cool2
All The Gear All The Time: Means you should wear all the protective gear even for short, apparently safe trips.
Hope you are not trying this move on dry pavement and that your clutch will last.
lnewqban is offline   Reply With Quote
Old 06-18-2013, 01:58 PM   #13
ZoSo15
Oddometer: 7
Yeah...holy crap.
Our knees aren't meant to take forces in that direction. That's a knee surgery waiting to happen right there.
ZoSo15 is offline   Reply With Quote
Old 06-18-2013, 03:07 PM   #14
Truckin_Thumper
low profile
Truckin_Thumper's Avatar
Oddometer: 28,890
Originally Posted by ZoSo15 View Post
Yeah...holy crap.
ya'll are new at this, aincha?
That foot is an outrigger......flat trackers.....hot shoe.
gimmie the button!
Truckin_Thumper is offline   Reply With Quote
Old 06-18-2013, 03:10 PM   #15
Andyvh1959
Cheesehead Klompen
Andyvh1959's Avatar
Location: Da frozen tundra eh? 1.5 mile west of Lambeau
Oddometer: 799
Still learning to slide a bike, now at 55 years old. But I am picking it up on the dirt and with my ice bike. Great fun!!
Does help too on the street. Once when demo-riding a BMW R1200GS I had the rear tire break loose on a 90 degree turn from a county highway onto a town road. Because of my dirt/ice experience, I stayed in the lean and rolled into the gas, did my first ever pavement power slide.
Changed my shorts later. Heh, heh.
When life throws you a curve,.....lean into it!
42+ year rider, 22+ year MSF Coach, Street, Dirt, Ice, ride em all!
Andyvh1959 is offline   Reply With Quote
Times are GMT -7.   It's 06:33 PM.
