Go Back   ADVrider > Fluff > Shiny Things
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 06-21-2013, 05:41 AM   #16
DriveShaft
Oddometer: 4,524
Some of The better mid-range pans I've used keep steel as the working surface,, using a gauge of steel that would normally be considered cheap. And bond a thick hunk of aluminum (wrapped in steel for the aesthetics) to the bottom to help w/ heat conduction, and dispersion. Before we plunked down the dollars on the all-clad, our two favorite pans were a real thick aluminum non-stick (I want to say circulon) and some martha stewart branded no-name thing w/ the extra-thick bonded base. It was verry effective. You had to anticipate a little more thermal momentum, but that was relatively easy to anticipate and account for. The difference in price for thick-gauge multi-ply formed sheet vs the bonded base is pretty significant. Great for frying pans, where the bottom surface is the only surface that matters.
DriveShaft is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 06:04 AM.
