Old 07-06-2013, 11:14 AM   #31
davebig
Another Angry Hun !
davebig's Avatar
Oddometer: 3,667
Originally Posted by Mr. Cob View Post
Howdy spro,
I had Bruno setup my final drive with a different gear ratio and rebuild my drive-shaft when I had my 1150GS hacked, he does excellent work.
Bruno has a great reputation, you may want to ask him about 34 or 37 /11 but the gears are around 600 and and the labor's damn near that much.DB
Patience: A minor form of despair disguised as a virture.
Ambrose Bierce
davebig is offline   Reply With Quote
Old 07-06-2013, 12:34 PM   #32
Melrone
Oddometer: 953
when I had mine done.Tom Cutter had it back in 3weeks. He does nicew work.I bought those tools needed to pull my FD apart from Harbor Frieght. Tom explained how to disassemble it over the phone,not ahard job just got to be careful..
Melrone is offline   Reply With Quote
Old 07-07-2013, 05:07 AM   #33
airspro OP
airspro's Avatar
Oddometer: 136
Ok Melrone ,,, I found Toms website
http://www.rubberchickenracinggarage.com/
Still waiting on tools etc , thanks for all the info guys , learning , always good to learn more about my hobbies :)
best
spro
PS: Ya Dave think the wheelbearing went out almost right at the motel driveway as almost all the oil was on the ground there when I came out of the office .
airspro is offline   Reply With Quote
Old 07-07-2013, 08:19 AM   #34
airspro OP
airspro's Avatar
Oddometer: 136
Many articles have been written about replacing the bearing, but most of them suggest replacing the shims exactly as found. I don't understand this at all; here is an assembly which has failed and we're going to replace the damaged component and pretend it never happened? It didn't go bad by itself. The new 17-ball bearing is undoubtedly better, but it's not a cure for improper assembly. Any time a final drive is rebuilt, it should be thoroughly checked out.
http://www.bmwra.org/otl/finaldrive/
So much to learn . Not boring to say the least :)
Old 07-07-2013, 08:28 AM   #35
airspro OP
airspro's Avatar
Oddometer: 136
So this 850R has a FD ABS like mine has ? That would interchange then I take it .
http://www.flickr.com/photos/39085009@N02/5079537505/
Old 07-07-2013, 08:39 AM   #36
airspro OP
airspro's Avatar
Oddometer: 136
http://www.bmwmoa.org/forum/showthre...l=1#post142296
As for the synth vs. dino issue. BMW specs 90w non-synthetic GL5 rated oil for this application. They sell both a non-synthetic and a synthetic oil with their label. A number of people have made the simple observation that the rather sudden increase in the incidence of failures of the big ball bearing on Oilhead bikes occured at the same time that many dealerships started routinely filling the final drives with synthetic. That is only an observation and does not prove cause and effect. But, as far as I can determine by asking owners with failures nearly every time I hear about one, there have been far more failures with synthetic lube than with dino. I haven't written down the data but my limited sample is running a ratio of well over 10 to 1. I have no idea what the actual incidence of the use of dino vs synthetic in all of the bikes is, however.
Hmmm , interesting to say the least .
Old 07-07-2013, 09:11 AM   #37
airspro OP
airspro's Avatar
Oddometer: 136
Found it Mr Cob
http://www.advrider.com/forums/showp...2&postcount=13
Old 07-13-2013, 08:21 PM   #38
airspro OP
airspro's Avatar
Oddometer: 136
Fixed the bike this morning . Chris Harris video's on uTube really helped .
This thread is imo closed .
best
spro
Times are GMT -7.   It's 02:31 PM.
