Old 06-16-2013, 05:49 PM   #1
henrymartin OP
Mr. Tourguide
henrymartin's Avatar
Oddometer: 3,539
Anyone good with boat motors?
I just got my hands on a mid-eighties boat with a Johnson V4 VRO 110HP outboard. Probably same vintage.
Sat for 6+ years. Starter turns but does not engage. When i engage it manually, it struggles to turn the motor over. Well, it turns, but real slow and has a hard time.
I'll look into the starter and clean it. Where the heck are carbs on this thing? Looking at the motor, I feel like I never saw a motor before (and I rebuild a few bike motors)
henrymartin is offline   Reply With Quote
Old 06-16-2013, 05:56 PM   #2
wvboy
wvboy's Avatar
Oddometer: 219
Carbs should be on the very front of the motor. I have a 88hp johnson that has been super reliable.
A good sermon should be like a woman’s skirt: short enough to arouse interest but long enough to cover the essentials. Ronald Knox
wvboy is offline   Reply With Quote
Old 06-16-2013, 06:08 PM   #3
St_rydr
Strider
St_rydr's Avatar
Oddometer: 5,630
Check that all electrical connections are clean and right, check the bendix to ensure it is well lubed and engages properly. I would do a compression check to ensure all cylinders above 100psi and balanced between all cylinders. Seafoam works wonders on stuck rings and built up carbon deposits.
"Only a rider knows how much a fellow rider suffers in the winter." - Rob1313
Try Smug Mug!
St_rydr is offline   Reply With Quote
Old 06-16-2013, 06:18 PM   #4
troidus
Oddometer: 13,709
If the cylinders weren't fogged before the motor was stored, they're probably a little rusty.
troidus is online now   Reply With Quote
Old 06-16-2013, 06:20 PM   #5
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 6,814
I have a service manual for those motors. I'll send you a PM.
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc is offline   Reply With Quote
Old 06-16-2013, 10:41 PM   #6
Bad Daddy
Oddometer: 103
First thing to do is change the impeller in the leg. It's most likely taken a set, and won't pump water. If you're using a flushing attachment make sure water is coming out of the tell tale.
Run the engine off of a fresh fuel tank. Check the fuel filter.
And then do all the stuff mentioned by the other inmates!
The carbs are behind the black air box on the front of the motor.
"My biggest fear, is that when I die, my wife will sell all my stuff for what I said I paid for it." ...
Bad Daddy is offline   Reply With Quote
Old 06-17-2013, 02:22 PM   #7
Rutabaga
Oddometer: 730
First, check the ground connection for the battery wherever it is located. No good ground no get nuki. No get nuki no be happy.
Rutabaga is offline   Reply With Quote
Old 06-17-2013, 08:53 PM   #8
henrymartin OP
Mr. Tourguide
Oddometer: 3,539
Thanks for all the replies. I'll tackle this over the weekend (if I find the time).
Will post back once I find out more.
So far I found the battery, the oil tank, gas tank, and a bunch of wires. Will have to make some sense of it soon.
Old 07-02-2013, 11:31 AM   #9
henrymartin OP
Mr. Tourguide
Oddometer: 3,539
Cleaned the plugs, carbs, gas filter, gas lines...fresh gas (mixed at 50:1) and the sucker started on the third try. Sounds good, and all.
I did not replace the impeller since water comes out of the pisser at idle pretty strong when connected to water hose. Powerhead stays pretty cool too.
I'm getting a short buzzer alarm every second or so, which (upon research) means the VRO is not pumping oil. Ha, good thing I premixed for the test.
The manual I have covers too many motors and too many years, but it appears that the VRO services as a unit???
I'm going to pull the hose, take the oil tank apart and clean the filter, blow the hose clear and try again.
Online search reveals two camps - one that says bypass the VRO and run premix, the other says VRO is the best thing.
What say you boaters?
I don't want to run it too much until I get it in the water, the hose attachment is good for short tests, but I don't trust it for extended test runs.
Right now I'm cleaning carpets, removing hull oxidation (gellcoat), and fixing wiring to the bilge pump and all the wiring that does not work or look safe.
Old 07-03-2013, 03:01 PM   #10
BigEasy
BigEasy's Avatar
Oddometer: 1,717
Lube the starter bendix then use it, they loosen up and work best when they get use.
As for the VRO in a stock motor keep it. The last time I had one go out I think I paid about $150.00 installed. I like it just for the convience factor. The tanks on my boats hold a gallon when the alarm goes off so I don't have mess with doing math to mix oil. The motor will run just fine on premix that's how racers run them but I don't need that headache but that's my lazy opinion. Have fun with your new toy.
All who wander are not lost
"Play hard and FLOOR IT" Stevie Ray Vaughan
just remember: the only difference between genius and stupidity is genius has limits
BigEasy is offline   Reply With Quote
Old 07-03-2013, 05:24 PM   #11
mwood7800
Oddometer: 612
Do yourself a favor and change the impeller and oil in the foot. No way that impeller sat that long without damage. Should be changed every other year anyways
mwood7800 is offline   Reply With Quote
Old 07-04-2013, 08:21 PM   #12
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,411
I disagree, that's old logic. I run a water pressure gage on my 1988 Mariner 100, (that I bought new) I changed the water pump once, even then, water pressure has always remained as new. It gets less than 20 hours of use every year.
Old 07-04-2013, 09:22 PM   #13
barnyard
Verbal tactician
barnyard's Avatar
Oddometer: 10,928
The lower unit fluid should still be drained and changed. If the water stream is good out of the tell tale, I would leave it.
Back when I worked for a dealer, their unofficial policy was to recommend running premix after the VRO failed. Most of the people I knew that owned one, disconnected them and ran premix.
I sold mine before it failed and replaced with a Suzuki 4t.
all around good guy
barnyard is offline   Reply With Quote
Old 07-04-2013, 09:56 PM   #14
henrymartin OP
Mr. Tourguide
Oddometer: 3,539
The water pressure out of the "pisser" is good and the cooling head (whatever that black part is called) is nice and cool as long as the motor runs. As for the lower unit oil- I was planning on that. VRO - I'll try cleaning the pickup filter and the lines, then see if it starts working.
Short of calling Johnson, is there any way to find a year of manufacture? All I have on the motor is the serial and model numbers.
Old 07-05-2013, 12:11 AM   #15
Bad Daddy
Oddometer: 103
You can usually call a dealer and they can tell you the model year.
I might be able to tell with my Sierra Book if you pm me the numbers.
Times are GMT -7.   It's 05:00 PM.
