Old 07-06-2013, 11:59 AM   #16
barnyard
Verbal tactician
barnyard's Avatar
Oddometer: 10,981
Originally Posted by Bad Daddy View Post
You can usually call a dealer and they can tell you the model year.
Any dealer should be able to tell you. It is a letter code, I used to have it, but threw it away.
all around good guy
barnyard is offline   Reply With Quote
Old 07-06-2013, 03:19 PM   #17
r1150r
Out standing in my field
r1150r's Avatar
Oddometer: 959
http://www.leeroysramblings.com/omc_model_code.htm
r1150r is offline   Reply With Quote
Old 07-06-2013, 09:09 PM   #18
mwood7800
Oddometer: 612
If the impeller is that old it's shit. It will work great till you get high rpm. No way it will work like it is supposed to. It will piss a stream all day till u need it. Anyone who doesn't replace their impeller at least every 3 years, 2 is a stretch, rode the short bus.
mwood7800 screwed with this post 07-06-2013 at 09:15 PM
mwood7800 is offline   Reply With Quote
Old 07-07-2013, 12:23 PM   #19
henrymartin OP
Mr. Tourguide
henrymartin's Avatar
Oddometer: 3,566
Motor is 1987.
I need to find a dealer so I can buy some lower unit oil and a couple other things.
henrymartin is offline   Reply With Quote
Old 07-07-2013, 02:15 PM   #20
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,412
Originally Posted by henrymartin View Post
Motor is 1987.
WallyWorld (or NAPA, or ...) has lubrimatic lube for that, as good as any. Just don't get the stuff marked "for electric shift" lower units. Procedure to refill after draining is pump it in from the bottom, till it comes out the level plug, then plug that, remove the pump and plug the drain.
If the oil is milky looking, water intrusion past the shaft seals is indicated. Usually it's the prop shaft, fishing line wrapped around the prop can eat up the seal, or worn bearings, or just old age.
concours screwed with this post 07-07-2013 at 02:21 PM
Times are GMT -7.   It's 11:26 PM.
