Old 06-16-2013, 08:18 PM   #1
indr OP
Oddometer: 501
Alternator to R/R Wire Gauge
indr screwed with this post 02-22-2015 at 09:34 PM
indr is offline   Reply With Quote
Old 06-16-2013, 08:31 PM   #2
gsweave
Yinz, blinkers are on.
Oddometer: 12,499
Originally Posted by indr View Post
16 or 14?
amperage?
http://electrical.about.com/od/wirin...twiresizes.htm
1 Peter 2:16 Live as free men, but do not use your freedom as a cover-up for evil;... .
gsweave is offline   Reply With Quote
Old 06-16-2013, 08:44 PM   #3
broncobowsher
broncobowsher's Avatar
Oddometer: 1,870
Field wire?
Turn on wire?
Output wire?
broncobowsher is offline   Reply With Quote
Old 06-16-2013, 08:45 PM   #4
doxiedog
doxiedog's Avatar
Oddometer: 932
Works best with a bigger + on the output to batt.
It stoped burning them out on my sv650.
Snot nosed 68 yr.old kid.
I ride because, it lets my soul out to play. .
doxiedog is offline   Reply With Quote
Old 06-17-2013, 08:10 AM   #5
ttpete
Rectum Non Bustibus
Oddometer: 6,147
If you have a 240 watt alternator, it's capable of delivering 20 amps. For that, you need 12 gauge. Divide wattage by voltage to get amperage.
2015 BMW R9T, 2010 Ducati 1098 Streetfighter S
2009 Kaw 650 Versys, 1967 Triumph 650 TT Special
Old 06-17-2013, 08:21 AM   #6
ragtoplvr
Oddometer: 6,602
up to 40 amp 3 phase you can use 18 hypalon (does not melt) on the ac leads to the reg and 12 Hypalon to the battery. If you use high amps or long run , then 10 Hypalon to the battery. 35 to 50 amp single phase use 12 hypalon to RR and then 10 hypalon to battery. Hypalon is widely used for motor leads for flexibility, oil tolerance and durability. Also used in fuse links, it can take heat. If you use PVC, you need bigger.
Rod
ragtoplvr is offline   Reply With Quote
Old 06-17-2013, 09:53 AM   #7
ttpete
Rectum Non Bustibus
Oddometer: 6,147
Rod
Just because you can doesn't mean you should. All you're doing is creating heat with 18 gauge, and that heat is energy that didn't get to the regulator. The idea behind using hypalon is that it can survive in externally hot conditions that aren't necessarily caused by trying to run high amperage through small wires.
The weak link in stator-to-regulator wiring is often the connectors. They get hot from poor contacts and the hard shells melt. Some folks eliminate them and use crimped and soldered connections.
Old 06-17-2013, 03:12 PM   #8
duck
duck's Avatar
Oddometer: 10,403
I use 8 gauge for the alt to batt connection. It's $1/foot on Fleabay.
duck is offline   Reply With Quote
Old 06-17-2013, 05:02 PM   #9
broncobowsher
Oddometer: 1,870
Poor choice. Hard to work with and way overkill. 10 gauge can handle 60 amp alternator in a 40+ year old truck. And that routes from the engine, to the amp meter in the dash and back to the battery, so a fairly lengthy run as well. 8 gauge is probably what the battery cable to the starter is.
Old 06-17-2013, 05:59 PM   #10
duck
duck's Avatar
Oddometer: 10,403
Hard to work with? ROFLMAO.
Times are GMT -7.   It's 01:24 PM.
