Old 06-20-2013, 09:21 AM   #1
silverbandit1 OP
silverbandit1's Avatar
Oddometer: 1,000
Question HD Dyna Lowrider
I have found an 03' 100th anniversary Dyna Lowrider with less than 4k miles, Vance & Hines exhaust and detachable screen - other than that it is stock and looks nearly showroom.
I really don't know much about Harleys but I have been intrigued by them for a long time but just couldn't justify spending big $$$ on a new one.
I want to rent one first before making a decision - as the dream maybe way different than reality.
The seller is asking $8500 and it still has its original tires on it
So what can you tell me
Save Lives - Spay & Neuter
Those who cannot remember the past are condemned to think "profiling" is worse than the slaughter of innocent people.... In memoriam, 9-11-01
-B.Tinsley-
silverbandit1 is offline   Reply With Quote
Old 06-20-2013, 09:37 AM   #2
gymply
gymply's Avatar
Oddometer: 245
I would replace the 10 year old tires immediately and then ride the hell out of it. At 4K, the bike is just now broken in. The only known issue (that I am aware of) is the cam chain tensioners. The spring-loaded tensioner shoe is a wear item and should be inspected every 25K miles or so. It is pretty easy to inspect, but on most models you will have to pull the exhaust to get into the cam cover. I say go for it!
~gymply
'05 FXST
'12 FLHR
'14 FZ-09
gymply is offline   Reply With Quote
Old 06-20-2013, 10:07 AM   #3
ERD
Custom Rider
Oddometer: 370
I have the exact same bike. $8500 is a little high to ask for this bike. It's worth about $7000-$7500 retail consider that it needs a lot of work.
1. Very low seat height.
2. Easy to ride.
3. Very fast.
4. It has the lowest seat height and weight for the big twin Harley for its time
5. It has a tach on the tank!
6. Nice aluminum rims with 150 rear tire! NO TUBEs!!!
1. Windscreen to far forward and will produce excessive glare from headlight at night. I mounted a windscreen bag and replace the lexan with a smoked one to reduce the night glare.
2. Low frame will scrape just about anywhere. Luckily all the vitals are protected by the frame.
3. Mid controls are made for short inseam. Riding for long period will tire out legs. I put highway pegs on the engine guard. Parts to convert mid to forward control are still available. Some lowriders were ordered with forward controls.
4. Heavy clutch hard for smooth take-off and tires out hand in low speed parade. Put in a easy clutch for <$50
5. Front brakes sux... I upgraded all my single disk Harleys with SS brake lines and new non-factory pads. The 100/80-19 tires does not help with the braking.
6. Thin seat pad and low rear spring travel. It's a lowrider for a reason...
7. Goofy ignition switch. This one take some getting used to. Not only is it in a weird place (under the seat), the keys can be taken out with the ignition on ACC. It's a quick way to come back to a parked bike with a dead battery...
Overall, I like my lowrider. To bad Harley decided to discontinue this model and made the low model on the Sporty and Fatboy.
ERD is offline   Reply With Quote
Old 06-20-2013, 10:07 AM   #4
Trooper
Trooper's Avatar
Oddometer: 234
Well, the tires are ten years old and should be replaced immediately. The Twin Cam motor includes cam chain tensioners with nylon composite shoes and these have proven to be a wear item even though they are not on the regular maintenance schedule. Some owners have seen these shoes wear down until there was metal to metal contact against the cam chain, while others have experienced no wear. Harley-Davidson changed from spring loaded to hydraulically loaded tension on the shoes in the Dyna line for the 2006 model year and for all Twin Cams with the introduction of the 96-cubic-inch Twin Cam for the 2007 model year. Some believe the only true fix for this is to go with an aftermarket gear driven set up. It is a simple upgrade and should not necessarily prevent you from buying a clean low mileage bike. If this bike is one that will have an issue with the cam shoes, it won't show up until around 20-25,000 miles so there is plenty of time to do the up grade. As far as the price he is asking, it doesn't seem out of line but may be a little high. Remember tires will set you back about $500 now a days.
Greg
Daughter: What did you do for a living, daddy?
Daddy: I thwarted nature!
Trooper is offline   Reply With Quote
Old 06-20-2013, 10:10 AM   #5
blk-betty
bam-a-lam
blk-betty's Avatar
Oddometer: 2,473
Ex-wife had a '02 Lowrider. Only real issue is that it is low so don't expect much corner clearance. Otherwise a great looking bike, although I don't care much for the 100th Anniv paint and tank badges.
Haven't kept up with pricing lately so maybe I'm off base thinking that his asking price is about $500-1K above what it should be.
Any day on a dirt road is a great day
blk-betty is offline   Reply With Quote
Old 06-20-2013, 10:11 AM   #6
GoonerYoda
Hot Dickens Cider
GoonerYoda's Avatar
Oddometer: 815
HD emblems adds 20% to the price.
GoonerYoda is offline   Reply With Quote
Old 06-20-2013, 01:11 PM   #7
silverbandit1 OP
Oddometer: 1,000
Called the local dealer and its $170 to change all fluids
Rear tire $204.00 + $150 labor
Front tire $150 + $100 labor
KBB showed about $5500 for trade in and $7500 for dealer retail
The local dealer has an 02' with nearly 70k miles and they are asking $8990
-B.Tinsley-
Old 06-20-2013, 01:21 PM   #8
Cakeeater
Oddometer: 964
Unless they are flushing the brakelines..you can save a bunch and do the oil yourself. If you can open a bottle of beer or turn on a faucet you have the aptitude to change oil(s) on an HD.
It's so hard to price older bikes. If something is pristine, then it's worth much much more than something mediocre. So KBB is kinda worthless imho.
Cakeeater
Cakeeater is offline   Reply With Quote
Old 06-20-2013, 01:35 PM   #9
blk-betty
bam-a-lam
blk-betty's Avatar
Oddometer: 2,473
Cakeeater
So true, and if you have a lift or acces to a lift you can pull the front and rear wheels and take to the dealer and let them change and balance the tires. This is what I've done with all my HDs when they need new rubber. I think the dealer charged $35 to mount and balance if the wheels are off the bike.
Much more of a pain with a touring HD but saves me money and should be easy peasy with the LowRider......only issue now that I think about it is you need a lift with extra low clearance to fit under the LowRider frame.
Old 06-20-2013, 01:50 PM   #10
gymply
gymply's Avatar
Oddometer: 245
Cakeeater
Agreed! The $45 bucks I spent on the factory service manual is the best money I've spent on the bike so far.
~gymply
'05 FXST
'12 FLHR
'14 FZ-09
Old 06-20-2013, 01:59 PM   #11
ERD
Custom Rider
Oddometer: 370
Everyone is looking to save a few dollars, but the lowrider is a pain to service without a lift. Most oil pans won't fit underneath without lifting bike. The lowrider, like most of the Harleys, are heavy and without a center stand. So you risk tipping the bike over by save about one to two hours of labor and take the wheel off while it is balancing on a floor jack - since it has no center stand and now has no front nor rear wheel.
Old 06-20-2013, 08:05 PM   #12
dickensheets
smprparatus
Oddometer: 289
He could afford a stand if he skips $100 tire changes!!! Yikes.
dickensheets is offline   Reply With Quote
Old 06-20-2013, 09:15 PM   #13
waveydavey
happy times!!
waveydavey's Avatar
Oddometer: 9,402
its not all that difficult...really...sheesh. My Softail with a springer front end is even lower and heavier and even a fat old guy like me can manage it easily.
"...once the honey was gone he wandered off, farting and too soon satisfied."
FUCK CANCER!!!!
waveydavey is offline   Reply With Quote
Old 06-21-2013, 05:39 AM   #14
XT_Driftwood
XT_Driftwood's Avatar
Oddometer: 573
I bought my HD on a fly&ride and before I headed for home the PO showed me one of these he built...
http://www.nightrider.com/biketech/bikelift.htm
I built one for myself in about 30 minutes. It makes getting the front or rear off the ground a snap, but you can't do both at the same time.
I'd use it for oil changes if I had to, but my T-Sport is tall enough that I can slip a pan under it easily.
'83 XT550 - once the bane of my existence, now considered to be the pinnacle of reliability and engineering excellence
'85 GPz 750 Turbo
'01 Harley T-Sport
'99 Cagiva Gran Canyon - the bane of my existence
XT_Driftwood is offline   Reply With Quote
Old 06-21-2013, 07:14 AM   #15
ERD
Custom Rider
Oddometer: 370
I've seen and used one of these in my friends shop. The ones he had were made from heavy metal tubing and the bottom was a cam that allow the user to swing the bike up in a gentle lift motion. It was made and sold years ago and the company no longer in business. They really work well for front end service, but lifting the back isn't so stable as the bike's front end, which turns, can't be strapped down to something solid.
Times are GMT -7.   It's 03:36 AM.
