Old 11-07-2013, 01:07 PM   #76
mefly2
mefly2's Avatar
Oddometer: 1,224
Originally Posted by Mr. Fisherman View Post
Sign me up and let me know when you are ready for testing...
Same for me ...
----------------> jer-
30+ years with RTs...then to F/GS; now *Finally*
the BMW: R1200GSW, factory low seat & lower crash bars;
Touratech: Upper Crash Bars, big foot, pannier rack, ZegaPro panniers;
Fuzeblock, Rigid Dually D2 + yellow covers; Wunderlich bar risers w/ Q-adjust
mefly2 is offline   Reply With Quote
Old 11-07-2013, 08:24 PM   #77
Dominic49
Oddometer: 34
can the AG401 be hooked to a battery tender for storage?
Dominic49 is offline   Reply With Quote
Old 11-08-2013, 03:14 PM   #78
garandman
Wandering Minstrel
Oddometer: 6,184
Please comment.
Originally Posted by RandyO View Post
those jumper clamp wires don't look up to the task of handling the amperage they claim is available for jump start, I've seen heavier gauge melt
2012 WR250R, 2009 TW200, 2008 Tiger 1050 ABS, 2008 CRF100F
“The problem in defense is how far you can go without destroying from within what you are trying to defend from without.” ― Dwight D. Eisenhower
garandman is offline   Reply With Quote
Old 11-11-2013, 01:19 PM   #79
garandman
Wandering Minstrel
Oddometer: 6,184
Bump.
Old 11-16-2013, 08:14 PM   #80
switchback
Eatin' Dirt Since 1982
switchback's Avatar
Oddometer: 1,485
As soon as the HD SAE connectors are available will be getting a Micro-start. Keep us posted!
Sent from my Nexus 7 using Tapatalk 4
David
Wind is strong and cold
Rain blurs the winding road ahead
I live on two wheels
switchback is offline   Reply With Quote
Old 11-18-2013, 10:16 AM   #81
dallasdrz
Oddometer: 52
Wink iPad
I want to get one for my wife's ipad .
How long would it take to charge an iPad and what about continuos
Use while plugged in?
2001 Drz400e (sold)
2008 Beta450rr (rfs)
dallasdrz is offline   Reply With Quote
Old 11-19-2013, 06:19 PM   #82
loph917
Beard Bros Racing
loph917's Avatar
Oddometer: 4,672
Brought the micro start to an event this weekend. Got to use it twice. Both times it worked like a charm. First was a cold blooded 950SE (not mine ). Fired right up. The second was for a Husky. Tried several times but something was up with the electrical system and the Husky just wouldn't stay running. Not the fault of the micro start.
The only issue I had was the clamps. They are surrounded by plastic and were next to impossible to clamp on to the terminals. Ended up just pressing the clamp to the negative terminal on the Husky. I think they are designed that way to prevent accidental shorting but perhaps different length leads would be better with a bit less clamp thickness.
Otherwise it worked as advertised!
[ this space for rent ]
loph917 is offline   Reply With Quote
Old 11-20-2013, 06:14 AM   #83
mefly2
mefly2's Avatar
Oddometer: 1,224
Longer leads would generate more resistance / heat upon use.
Old 11-20-2013, 06:21 AM   #84
garandman
Wandering Minstrel
Oddometer: 6,184
The cables are on the thin side compared to most jumpers.
Does this battery have some sort of current control to limit the flow?
Old 11-20-2013, 07:21 AM   #85
phreakingeek
phreakingeek's Avatar
Oddometer: 507
sae connector/pig tail
hovering over the Buy button and wanted to know if the SAE jumpstart/Battery Tender pig tail will be available shortly?
Is there an ETA on when I will be able to get one of those? Should I hold off a week or two for my order or will it be months out?
phreakingeek is offline   Reply With Quote
Old 11-20-2013, 02:58 PM   #86
JR356
JR356's Avatar
Oddometer: 3,894
Recent posters.
You probably should contact Mfgr.directly with your questions.
AntiGravity does not seem to reply frequently to this thread.
Looks very interesting,will probably buy after the Holidays,unless they come up with a Black Friday or similar deal.
May even get one for wife and daughters vehicles,more practical than waiting around in a questionable location for someone to come along to jumpstart.
JR356
JR356 is offline   Reply With Quote
Old 11-20-2013, 04:47 PM   #87
Waynee40
Franga
Waynee40's Avatar
Oddometer: 28
Purchase In Australia
I have tried to get one of these from Australia but Nil stocks !! Grrrr
Can I order one directly from the US and what will the postage be ?
Waynee40 is offline   Reply With Quote
Old 11-22-2013, 04:21 PM   #88
L.B.S.
Oddometer: 1,416
Mine arrived today, in plenty of time for me to wrap up for a buddy's Christmas present.
Thanks Antigravity doods!
L.B.S. is offline   Reply With Quote
Old 11-24-2013, 01:54 PM   #89
Chuck35
Chuck35's Avatar
Oddometer: 36
I would like to be able to buy the SC-1 with jumper cables and a 110v charger to use as an automotive jumper as well as being able to limp a car into the shop (ie alternator not charging).
With the warning to get the micro starts off the down vehicle within 30 seconds, they may not be suitable for my limp in needs.
2008 Yamaha FJR1300
Chuck35 is offline   Reply With Quote
Old 11-25-2013, 07:21 PM   #90
sonoran
you already know
sonoran's Avatar
Oddometer: 24,710
Originally Posted by Antigravity View Post
I would suggest a double zip lock baggie. We looked at waterproofing it but there are too many ports and the tooling for a waterproof case is MAJOR.
But.......... it just so happens that we are introducing our latest product...
It is the worlds smallest most powerful battery and no one in the industry has anything to compare to it. It is called the XPS "EXTREME POWER SERIES" line of batteries (2 models) ... So we taken our smallest battery case and filled it with pure, unadulterated awesomesness of power! We call it the SC-1 and it is 4" inches long x 1.25" inches thick x 3.25" inches tall...
It looks like our original 4-Cell but it can actually start V8-trucks and also does 1200cc Twins very easily... and its WATERPROOF (or more correctly said water tight) So you can submerge it with no ill effect. It can also hold a charge for close to a year.
It is NOT meant to be a replacement battery for an adventrure bike... the capacity is too small... what it IS meant to be is a redundant safety battery. Meaning you stick it on the bike somewhere or in your pannier (not connected) and have a back up available to flip your bike no matter where you are. At 13 oz and being so small there is NO reason why anyone should not carry this in there truck, car, bike or whatever. The cool thing is that it is lifepo4 so you can leave it connected as the emergency battery if you ever to have to get back to civilization. We will have a kit for it soon that allows you to just plug it in to a Micro-Start Harness to do the jump starting if needed.
So you understand the SC-1 is LIFEPO4 based which is safe to leave attached to your bike or car if you have to use it as a regular battery.... the Micro-Start is Lithium Polymer and CANNOT and SHOULD NEVER be left attached to your vehicle after it jump starts it.
YOu can get info here, http://antigravitybatteries.com/extr...ower%20series/ (webpage not completely active yet... can't order yet)
Check the video below...
Hey this is awesome.. was gonna go with the micro-start but this suits my needs for a backup battery better.
Order inbound!
sonoran is online now   Reply With Quote
Times are GMT -7.   It's 09:59 AM.
