Old 06-21-2013, 08:45 PM   #1
ktmklx OP
ktmklx's Avatar
Oddometer: 700
Better Mouse Trap For a KLR
http://www.backroadequipment.com/
So I have spent a year of my free time developing a pannier and top box mounting system for a KLR. I would like to show off my work here and see if there may be some interest in my rear rack/top box mounting system. If there is some interest I'll set up a thread in the Vendors area, just trying gauge interest at this point.
So what do i got?
A rear rack for the KLR, here are details:
13" x 16" rack
3/16" 6061 aluminum material
CNC cut
stock tool kit access
hole pattern for Rotopak mount
keyhole mounts for quick connect top box
stainless steel mounting hardware
top box quick connect:
four heavy duty plastic pucks create quiet and tough mounting system
four large 6061 washers
zinc plated button head mounting screws
6061 quick cam lock (top box attaches in less than 10 seconds) when locked into position the box is tightly locked onto the rack there is no movement and it is not coming off
top box can be locked onto rack with a padlock
optional integrated lock would be available
mounting is symmetrical, box can be mounted in one orientation and 10 seconds later be mounted in a different orientation
top box can be attached and removed without opening the box
The mounting pucks are the same size and location for the pannier racks so you can have a pair of Pelican 1550s (or what ever your favorite box is) for panniers when touring and when you want to commute to work, pull off the panniers and slide one box into the rack (takes about 10 seconds to do this) and you have a top box for your computer and lunch.
What do you think?
ktmklx screwed with this post 11-23-2013 at 10:58 AM Reason: correction rack is 13" x 16" not 13" x 18"
ktmklx is offline   Reply With Quote
Old 06-22-2013, 06:48 AM   #2
2 SPOT
wannabe
2 SPOT's Avatar
Oddometer: 3,319
well, that looks real neat, i always like stuff that is modular and multi purpose.
2 SPOT is offline   Reply With Quote
Old 06-22-2013, 07:46 AM   #3
bete
misguided adventurer
Oddometer: 561
Nice work, but will it be to pricey for us klr tight wads? bete
09klr-11wee-07,990adv
bete is offline   Reply With Quote
Old 06-22-2013, 03:01 PM   #4
ktmklx OP
ktmklx's Avatar
Oddometer: 700
The rack will sell for $100, quick connect pucks and cam lock for box mounting will be an additional $50.00.
Still working on the pannier rack pricing.
Thanks for looking.
Old 06-24-2013, 06:28 AM   #5
captwheel
Oddometer: 78
I like it & would be interested if you go to production. Keep me posted.
Phil
captwheel is offline   Reply With Quote
Old 06-24-2013, 08:42 AM   #6
kubiak
Oddometer: 4,829
nice design!
Old 06-24-2013, 08:54 AM   #7
thriveoutdoors
Oddometer: 1
Really nice! Looking forward to production!
thriveoutdoors is offline   Reply With Quote
Old 06-25-2013, 07:19 PM   #8
ktmklx OP
ktmklx's Avatar
Oddometer: 700
Here is the rack on a gen 1 KLR.
Old 07-03-2013, 11:29 AM   #9
captwheel
Oddometer: 78
do you have any more pics of the side racks, & how they are mounted? Can you take the side covers off while the racks are on the bike?
Any plans on other models (DRZ400)?
Thanks, Phil
Old 07-03-2013, 02:43 PM   #10
phoenix13
Oddometer: 307
very professional
phoenix13 is offline   Reply With Quote
Old 07-03-2013, 03:26 PM   #11
HeatXfer
Bad knees
HeatXfer's Avatar
Oddometer: 732
Looks very useful; I like the 'locking' lever: is there a ball detent or other device to keep it from swinging loose?
HeatXfer is offline   Reply With Quote
Old 07-04-2013, 10:22 AM   #12
ktmklx OP
ktmklx's Avatar
Oddometer: 700
1) The lever loop is sized so that it "hooks" the the puck that it grabs. It actually feels like there is a detent as you close the lever.
2) The hook on the lever has to follow the radius created by the pivot bolt, the puck that the hook grabs only moves forward and backwards in the key hole. So when forces push the box towards the front of the bike (the direction you would push it to take it off) with the lever engaged, the lever locks up because it can only pivot on its radius and the puck can only go straight forwards.
3) The pivot bolt for the lever uses a nylon lock nut so friction between the lever and rack can be adjusted. I have tested with a loose lock nut and have had no problems due to points 1 & 2 (mostly 2).
This box is not coming off unless you want it to!
Thanks for the good question.
Old 07-04-2013, 10:41 AM   #13
ktmklx OP
ktmklx's Avatar
Oddometer: 700
Thanks, Phil
Phil,
I will be posting some more pictures of the racks shortly, I have just sold a set of the the racks for a Gen 1 KLR and will post pictures of the installed product. Yes, the side covers are removable with the racks in place.
I do have plans for other bikes, but I will be focusing on the rear rack with box mounting kit, with side racks to follow.
I am considering offering the aluminum side racks with mounting pucks as a universal kit. Then handy guys can fit them to their own bike. Any interest in that?
ktmklx screwed with this post 07-04-2013 at 11:00 AM
Old 07-04-2013, 10:44 AM   #14
ktmklx OP
ktmklx's Avatar
Oddometer: 700
Originally Posted by phoenix13 View Post
very professional
Thank you, if I am going to sell a product it has to meet high standards.
Old 07-04-2013, 02:22 PM   #15
Nnordsman
Nnordsman
Oddometer: 338
A universal is not a bad idea. It may or may not appeal to some people. Unlike your workmanship, which I could not touch, most of us can handle drilling a couple of holes for the screws. Particularly the rest of us KLR types.
Nnordsman is offline   Reply With Quote
Times are GMT -7.   It's 02:05 AM.
