Old 10-19-2013, 05:18 PM   #61
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 9,768
Originally Posted by perfect-fairings View Post
It took us a little bit more time to build the universal small rally fairing but we want to have a complete kit.
So now we can offer a complete solution of rally fairing , small navi tower to mount all the necessary rally equipment and all the needed brackets.
All the brackets are made from high grade aluminium and the point is that all aluminium parts come out in the color you like.
In few days I will put some pics with all the parts mounted on several bikes to take a look .
My best regards
Dimitris
Roaming Rally 2015
GRAVEL TRAVEL CANADA - Canada's source for overland routes
Tales From The Bivouac Rally Print Publications
Deadly99 is offline   Reply With Quote
Old 10-22-2013, 09:16 AM   #62
LukasM
Oddometer: 5,388
G]
Hi Dimitris,
Does the tower have the same dimensions as the KTM Rally? How much are you charging for the two side plates and the top one?
Old 10-23-2013, 02:51 AM   #63
perfect-fairings OP
Oddometer: 99
Originally Posted by LukasM View Post
Hi Dimitris,
Hi
Yes its exactly the same as the KTM rally.
Price for the tower is 650 € in any color you like and free shipping in all over the world!
The lights coming sepsrate.
Thank !!
perfect-fairings is online now   Reply With Quote
Old 10-23-2013, 03:09 AM   #64
LukasM
Oddometer: 5,388
So if the lights are not included, what exactly is?
You can buy the 3 plates for €315 list price incl. 20% VAT original from KTM (usually minus 10-20% discount), so €350-€400 on top seems rather excessive for a couple of spacers and bolts if that's all it is?
LukasM screwed with this post 10-23-2013 at 10:46 AM
Old 10-23-2013, 08:15 AM   #65
ride guy
Oddometer: 27
Any plans for a Honda XR650R? Without a headlight?
ride guy is offline   Reply With Quote
Old 10-23-2013, 12:18 PM   #66
perfect-fairings OP
Oddometer: 99
some pics of the universal small fairing ,this one is the prototype i think we have some points to fix on it and make it better.
our prototype fairing with headlight cut for Husaberg FE450
[IMG]URL=http://s1362.photobucket.com/user/dimaidonis/media/DSCN4626_zpsb2936ff8.jpg.html][/URL][/IMG]
[IMG][/IMG]
Also we had to make and a small navigation tower .
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
And finally a small taste of how it looks like ..
[IMG][/IMG]
The price of this fairing will be 95 euro.
Old 10-24-2013, 06:27 AM   #67
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,320
Sean-0 is offline   Reply With Quote
Old 10-24-2013, 10:14 AM   #68
perfect-fairings OP
Oddometer: 99
Originally Posted by Sean-0 View Post
I asked from a friend to borrow me his xr !!
I Think it will take a while but we will do it
By the way whch tank you use on your XR?
Old 10-24-2013, 12:51 PM   #69
red_rooster
Oddometer: 5
XR650R FVairing
I too am intersted in XR Fairing. I have the Clark 4.3. Is the idea to have the fairing mount to the old Radiator shroud locations?
red_rooster is offline   Reply With Quote
Old 10-24-2013, 05:35 PM   #70
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,320
i would use the acerbiz tank as thats a long range tank and would be the tank a 1 would use to suit a rally fairing
the market is large for this bike
Old 11-05-2013, 11:17 PM   #71
canadius_maximus
Quaere verum - Seek truth
canadius_maximus's Avatar
Oddometer: 539
africa twin RD03
[IMG]
[/IMG]
KTM 690
[IMG]
[/IMG]
[IMG]
[/IMG]
I will upload more soon..
Hi there Dimitris - greetings from Vancouver, BC.
So, I have some questions about your fairings ( I have a 2009 KTM Enduro R):
1) Mounting bracket - if I select the option to include the mounting brackets, those appear to bolt onto the frame? That top bracket appears to require drilling into my frame? Sounds worrisome - or am I misinterpreting the picture? And how is a vertical load (up or down) taken up? Since the entire weight of the fairing, bracket, and whatever nav/instruments are mounted - all appear to want to cause that bracket to pivot down, no? Is there a secondary attachment point down further along the frame?
2) Front Tanks. Does this fairing (specifically, the two-round light version shown above - assume a specific tank? For example, can I use it with the Rally Raid Evo 1 tanks? Or the Aqualine Safari tanks? Or no front tanks? Your replica racer photo looks like the stock (no front tanks) ...
3) Lights. What lights are recommended with this setup? Would the lights bolt to the fairing directly, or to a subframe that would in turn attach to the fairing stay/bracket that is supplied?
4) Variants and/or modifications. I like the turned-down lip on the replica racer photo above, whereas the product shots on the perfect-fairings website don't show this. Did that owner modify the top to create that lip? I've never worked with fiberglass - would be scare to stress/break the fairing ...
A question for any of the KTM 690 folks who've gone with this fairing - everyone happy with the brackets? Strong enough? I have to be honest, they look a bit fragile - - please, no offense intended - just an observation, likely an incorrect one - but as I'm finalizing my decision, I'm looking for as many data points as possible ....
Thanks,
CM
By grace alone. Through faith alone. In Christ alone. From Scripture alone. Glory to God alone.
KTM 690 R Rally Raid Evo 1 (and 2) Kit Build for Dummies
canadius_maximus screwed with this post 11-05-2013 at 11:25 PM
canadius_maximus is offline   Reply With Quote
Old 11-07-2013, 08:47 AM   #72
windquest
windquest's Avatar
Oddometer: 574
KTM 690 question
KTM KTM 690
RALLY FAIRINGS
fiberglass 799.00
Do you sell this kit without the front fender and belly pan? If so how much is it for the fiberglass version?
Regards,
Jason
Trans-Canol 2014ish
windquest is offline   Reply With Quote
Old 11-08-2013, 02:15 PM   #73
perfect-fairings OP
Oddometer: 99
africa twin and Super tenere 750 rally fairings!
some new updates for these rally fairings!
Africa Twin 690E
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
AFRICA TWIN REPLICA !
[IMG][/IMG]
SUPER TENERE 750 REAL RALLY FAIRING!
[IMG][/IMG]
[IMG][/IMG]
Old 11-08-2013, 02:53 PM   #74
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 9,768
Liking the shape of the last one
Roaming Rally 2015
Old 11-10-2013, 02:56 PM   #75
perfect-fairings OP
Oddometer: 99
Thanks,
CM
Thank you for these interest questions!
1.mounting bracket that shown in this pics is only for the fairing which comes for the oem headlight not the 2 spot lights,for the two spot lights the brackets is totally different (i will upload some pics soon)
Also this mounting bracket is designed to keep only the fairing no nav instruments on it..
2.Tanks,we offer different type for front tanks
3.About lights you can choose the best for you,there are two many options
4.we can make the lip as the shown bike if you like without extra cost.
best regards
Dim
Times are GMT -7.   It's 11:50 AM.
