Old 06-25-2013, 05:41 PM   #1
vanislejay OP
Oddometer: 143
Old Bikes Long Rides - How to prepare
I am planning my first long bike trip on an old bike. What does everyone do/check out to prepare their bike for multi day rides?
I'm going to be taking a 73 Yamaha TX750 around 1200 miles in four days. Not unreasonable and I think enough room for some breakdown time. Most of it will be pretty isolated. I've had this bike for a year or so and I did a ride over 200 miles on it a couple weeks ago. Ill be riding two up and I will probably throw some saddle bags on there for camping gear, but most of the ride will be coastal roads so I am imagining an average of 50mph or so. We are going alone, but it's a busy vacation week here in Quebec so an isolated road side breakdown wouldn't be a complete stranding (I hope).
Here's the map if anyone is interested. https://maps.google.com/maps/ms?msid...85ab6d10&msa=0
The bike has the balancer chain tensioner and the deep sump, so the original design flaws shouldn't cause me any problems.
vanislejay is online now   Reply With Quote
Old 06-25-2013, 08:39 PM   #2
hunter_greyghost
XS650 Allroads Traveller
hunter_greyghost's Avatar
Oddometer: 8,321
I'd treat it like any bike ride if you have faith in its reliability etc.,
I noticed your pointed out that basic design faults have been rectified so those shouldn't be a problem,
Have you worked on this bike yourself? what is the history of the bike? original mileage? has it been rebuilt/restored? just a few questions I've thought of
My XS650s have both been rebuilt but now have 50,000+kms on them,
touring around parts of Australia, 50% dirt roads in a lot of trips, both loaded fairly well at times
Depends on your gut feelings sometimes too, your faith in your bike like I said earlier, have great time on the trip,
I've done plenty of remote area rides - always enjoyable, better with company,
Cheers
Baza
1981 XS650SH "Tourer" [ For Sale - 2015], 1975 XS650B "Adventure" ['Kenny Krazyhorse'], 1982 XL500R 'Project' x2 [for sale], DT175 [new projects] x 2
www.aussiegreyghost.smugmug.com
Couldn't afford a 'GSA', so now it's an 'XSA' "I didn't do it! & whoever said I did, is a liar!"
hunter_greyghost is offline   Reply With Quote
Old 06-25-2013, 09:51 PM   #3
retiredgentleman
Oddometer: 115
I have done a 2000 km 5 day trip, on my 1978 XS650, through the rocky mountains. As mentioned, its important to know the history; what components have been up-graded, etc.
On my bike I had replaced the rectifier, the regulator, the ignition, the fuse panel, and I had cleaned the electrical connectors. Its important to know you have a good battery, and a good charging system.
You should check that you are getting 14 volts across the battery terminals, when you rev the engine up to 3000 rpm.
Of course you want good tires and brakes. I have tubeless tires, so I carry a tire repair kit and a small 12 volt air compressor. I guess you have spoke wheels and tubes, so that could be more work if you have a flat.
A tool kit, spare fuses, a test light, some electrical wire, electrical tape, nylon cable ties, tire pressure gauge, all good to have with you.
Each day check around the bike for loose nuts and bolts. I had a small bolt vibrate loose inside my headlight bucket, which caused a few electrical problems.
retiredgentleman is offline   Reply With Quote
Old 06-26-2013, 06:22 AM   #4
vanislejay OP
Oddometer: 143
Thanks for the tips! And that is one loaded up XS!!
I usually carry a small tool kit with me that enables me to do almost everything, and it has almost everything mentioned above, but it's still good to get some reassurance.
I have about a month to get the bike ready so I will check out the charging system, and the rest of the electrical while I am at it. I have been a little suspect of the charging system for a while, so no point walking into this trip with a known potential issue.
I rebuilt the top end last year and inspected the rest of the motor while I was at it. Everything looked pretty solid. I have some valve clack that I need to clean up before I leave and I have a spare set of points and a condenser that will be in my kit. Yesterday one of my exhaust mounts broke on the rear. It was a flimsy little bracket that I am surprised lasted 40 years, so I will bend up new brackets for both sides this week.
The bike is stock aside form pod filters and some of the baffle has been removed from the exhaust, the jetting has been modified to suit. She has about 25,000 original miles, of which about 3,000 are mine, and it hasn't been rebuilt aside from what I have mentioned above.
What is best to carry for tubed tire repair? I am a regular cyclist and no stranger to road bike flat repair. Can I use the same patch kit for a motorcycle tube? The pressure is a lot less on the motorcycle tube so I suppose it should work. What do people carry for tire levers? I doubt my flimsy bicycle tire levers would be able to get my motorcycle tire off. I doubt I will have a problem, but a patch kit and levers are pretty light, I might as well put something in my tool kit just in case.
Old 06-26-2013, 12:43 PM   #5
nick949eldo
Oddometer: 969
That's a nice lazy pace - you should have a great time. In looking at your route, my preference would be to cross the Gaspe Peninsula on Highway 299 up the Matapedia Valley and through the Chic Chocks rather than following the Cassapedia Valley and Highway 132. 132 takes most of the traffic and is nowhere near as interesting or scenic - trust me on this one!
Highway 229 is one of the best motorcycling roads in Quebec.
On your Google map, activate 'photos' then compare the scenery of the two - you'll see what I mean.
As far as breakdowns, as long as you treat them as challenges, not disasters, you will be fine.
Have fun
Nick
PS Don't bother with a patch kit - take a spare tube, and don't forget some lubricant (shampoo, soap, wd40, ky jelly) to help get the tyres on and off. Buy some proper motorcycle levers otherwise you just won't be able to manage - and carry the necessary wrenches to remove the wheels!
nick949eldo is online now   Reply With Quote
Old 06-26-2013, 12:54 PM   #6
vanislejay OP
Oddometer: 143
Thanks for the route suggestion Nick949eldo, I have seen your site and read your ride reports, really impressive! I really want to ride up to James Bay at some point as well. I actually have a 73 Eldo that is next up on the bench and your ride reports have been motivation to get it up and going.
I have also drooled over the pics of your 750S more than once haha.
Old 06-26-2013, 01:12 PM   #7
nick949eldo
Oddometer: 969
Thanks for the kind words. By now you've undoubtedly heard of the chrome bore issue with early Guzzis - but its worth mentioning just the same. Lots of info on line, and easy (if a bit expensive) replacements are available.
Quebec is one of my favourite places to travel: the roads, scenery, people, cheese, wine - all fantastic!
Nick
Old 06-27-2013, 05:48 AM   #8
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,413
Legs, man you need LEGS! 17t countershaft and 38t rear sprocket. I've had two TX750's, back then and now. Bring extra contact points, in case they get oiled then burnt. You have the sump extension and balancer chain adjust mods, yes? Verify your charging system before you leave, voltmeter should go to 13.6+ when revved up (headlight on). And check your oil FREQUENTLY!!! They can push a lot out at highway speed.
concours screwed with this post 06-27-2013 at 03:18 PM
Old 06-27-2013, 06:01 AM   #9
SloMo228
World Class Cheapass
Oddometer: 1,745
I did a trip of similar length last year on my '78 GL1000. I rebuilt that bike from the frame up, replacing everything that needed replacing, and it ran great for years. Then I went on the trip and on day one, the stator burnt out. Fortunately, I had previously wired in a switch so I could run without a headlight and the stator somehow had enough life left in it to keep the battery from draining if there was no load from the headlight, so I was able to complete the trip.
I guess the point of this is that no matter how well you prep the bike for the trip (except maybe short of a complete teardown and replacement of all wear items) there's still a decent chance that, on your 40+ year old machine, something will go wrong. Just try to take it in stride if something does happen, and hopefully it won't be a trip-ender either. There is definitely something special about touring on a vintage bike that you don't really get from more modern rides. Maybe it's the extra excitement from not knowing when the next thing is going to break?
--------------------------- Steve----------------------------------------
'93 GL1500 frankenbike basketcase in progress
'96 DR350SE
SloMo228 is offline   Reply With Quote
Old 06-27-2013, 06:53 AM   #10
vanislejay OP
Oddometer: 143
I have used that to explain to my co-workers why I only have old vehicles. The first is that you can almost always get them back up and running at the roadside, the second is that knowing you will make it to your destination everytime is too boring.
Old 06-27-2013, 03:23 PM   #11
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,413
Take two, http://www.bikebandit.com/motion-pro...type-tire-iron
+1 on taking a new tube... or two 18 and 19.
Throttle cables in good condition? A busted clutch cable can be limped along, but no go without throttle.
Old 06-27-2013, 03:25 PM   #12
hunter_greyghost
Oddometer: 8,321
Gotta agree with that statement, dunno about the second part of that sentence though!
Cheers
Baza
Old 06-28-2013, 06:34 AM   #13
vanislejay OP
Oddometer: 143
I'll pack 'em, but don't be so sure about that. I limped about 30km home once with a string tied to my right leg at just the right angle to actuate the carb slide. It was a single carb bike though, and obviously not push/pull. If I had lost a clutch cable at the same time I would have looked like lord of the dance.
Old 06-28-2013, 07:17 AM   #14
hunter_greyghost
Oddometer: 8,321
Just load it & go, I'm off up to the Abercrombie River area again, little village called Tuena, old gold mining spot,
and don't forget to photos!
Cheers
Baza
Old 06-28-2013, 12:34 PM   #15
NJ-Brett
Brett
Oddometer: 6,443
When I used to do long trips on old bikes (not so old at the time) I knew what was likely to need attention having had the bike a while.
What I did was to buy all new cables, and wire tie another set of new cables to them and install on the bike. Its a place to store them, and if one breaks, you just switch the ends, no removing the gas tank.
I stuffed spare bulbs inside the headlight shell, and took enough tools to tear the motor apart. If you bring something, you will NOT need it.
Tire irons, patch kit, small pump, money.
9000 mile trip on a 1979 Bonneville special and I had one flat at the grand canyon which I fixed.
After having the bike a while, I knew the weak points, the speedo drive was crap, and the key switch wore out.
Both lasted the trip, but a week after the trip my rear brake master cylinder rusted up.
A spare regulator is likely a good idea on any old bike, they are small and easy to pack.
Start with newer tires, brake pads and battery.
NJ-Brett is offline   Reply With Quote
Times are GMT -7.   It's 08:50 AM.
