Old 06-26-2013, 09:41 AM   #1
klm4755 OP
Oddometer: 575
Spare tire carrier for the Vespa GTS step-by-step walk thru
Enclosed is a step-by-step walk thru outlining the fabrication and process for installation of a spare tire on a Vespa GTS 250ie. Note that the Vespa GTS rims are interchangeable. It is OEM recommended that the rear tire (130-70/12) be slightly larger than the front tire (12070-12), but a rear wheel/tire combo can be installed on the front hub without issue. Therefore, if you are to carry a spare wheel tire it is recommended to carry the rear tire size on the spare. The thread will be separated into 5 parts:
1. Spare tire placement options
2. Attach bracket Mock-up and proof of concept
3. Bracket fabrication
4. Wheel installation
5. Horn relocation. Guess where the wheel will be mounted?
6. Review and observations
wheel placement option 1, in wheel well...loose quite abit of storage and foot placement
wheel placement option 2, on rear rack, loose aft storage
wheel placement option 3, upright on rear rack, not ascetically pleasing, would need to fabricate a bracket to mount
wheel placement option 4, on scooter side---like a pannier this would occupy the space of a pannier as pannier space is more valuable and would make the bike asymmetric.
wheel placement option 5, front faring mount. This location provides a few challenges. The challenges include:
1. clearance with front wheel faring
2. wheel attachment to scooter
3. Horn relocation
4. loss of front load carrying capability
5. headlight visability
headlight is partially blocked, I'll need to "rake" the wheel as to limit headlight beam blockage
will mount on OEM front rack
disassemble rack, won't need these parts
re-install rack
quick wheel fit check, wheel contacts post
trim post, need to tuck wheel as close as possible to scooter
make bracket from aluminum rectangle bar stock
fit about here
drill oversized hole matching the front bracket
trim attach flanges
light deburr all mounting holes
rough machined bracket, repeat process
break edges with deburr tool
add loop adhesive velcro to the bracket to front rack contact/touch points as to spare the finish of the front rack
mount check
wheel base-plate out of wood first, then metal
trim with band saw
wheel check
attach base-mount to bracket interface to front rack
attach to scooter
mount wheel to baseplate
scooter fit check
no front fender contact
still some headlight blockage, need to rake the wheel and will try another mount approach
vespa GTS front wheel hub ($30 from e-bay)
opposite side of hub, these hole attach to your front brake disc
need to trim off small tabs to make a flush surface, easy-peasy as hub is aluminum
trimmed hub
trim down the large disc to accept the hub
remove front decorative trim as the tire will tuck to a lower position, plug holes with fastener
aluminum sheet stock, 6061-T4 .125 inch gage
outline transfer from wood to metal
blend corners at 1.5 inch radii
cut on band saw
deburr
mount on bracket
mount assembly on rack
prime (2x coats) + paint (2x coats) the wheel hub
mount assembly on scooter
front view, notice the assembly blocks the horn and running light
countersink fasteners
attach hub with course thread M6 fastener, use blue loctite paste
fit check, no tire contact with scooter or bracket, only hub
front fender check, no issues
view from top
remove stebel horn from cavity. Stable horn install can be found here:
[topic114292]
will mount the horn here
need additional hose and elbow hose couplers
bond straight coupler into stebel nozzle
mount with fastener here
straight connecter bonded in horn hole
thread nozzle hole thru bracket
horn as attached
horn/hose backside view
assembly on scooter
assembly front view
need to thread horn hose thru plastic trim, no real other option
connect horn hose with hose elbow connector, easy to disconnect if assembly needs to be removed
horn mounted
wheel clearance to top of front fender
front 1/4 view, closer tucked wheel, no headlight blockage
outside front view
side view
front 1/4 view
horn mount side view
horn front view
headlight view from ground
Mod review and observations:
1. Additional piece of mind if need to conduct fix a flat where plug is insufficient
2. Certainly will mount for any long distance riding
3. No additional noise at hi-way speeds
4. Stebel horn is perceived to be ~30% louder, from re-location
5. assembly weight ~ 20 lbs, this will have benefit in cross wind conditions
6. some increase in front impact crash worthiness
7. benefit to other vespa riders if touring with GTS scooters
Enjoy!
Keithm
klm4755 is offline   Reply With Quote
Old 06-26-2013, 09:53 AM   #2
JerseyBiker
Living the life!
JerseyBiker's Avatar
Oddometer: 2,384
Outstanding!!
This would have been great to have on my last Vespa. Once I added a top case in the rear the scoot developed a front tire wobble - I'm guessing due to the weight being so far back. This weight in the front might have cancelled out the wobble.
In any event, an absolute fantastic job and terrific step by step instructions!
FOR SALE 2015 Harley Street 500 ---2012 Honda Silverwing
JerseyBiker is offline   Reply With Quote
Old 06-26-2013, 12:38 PM   #3
rpclark
rpclark's Avatar
Oddometer: 171
Will it fit on the back?
"Thinking is the source of our problems. Your heart holds the answer to solving them."
rpclark is offline   Reply With Quote
Old 06-26-2013, 12:49 PM   #4
gogogordy
gogogordy's Avatar
Oddometer: 1,926
Well done!
As usual Keith very well done farkle.
I'd make 2 suggestions:
1) Protective "clear bra" circles on the paint, under the rubber cups
2) Your voltage regulator's already minimal airflow has just been reduced even further...they get plenty hot in normal use with just the small amount of airflow the horncast allows in. On my GTS, I drilled several air holes in the plastic shroud the VR mounts above, on the throttle side radiator. Can't hurt and did I mention that VR gets hot as hell?
Isn't it past your bedtime?
gogogordy is online now   Reply With Quote
Old 06-26-2013, 01:18 PM   #5
klm4755 OP
Oddometer: 575
Good comments, I'll take alook at directing some flow to the cavity, unaware the cavity usage was for VR cooling. I'll also need to add aux front turn signals as the tire/wheel blocks view from head on.
Keithm
Old 06-26-2013, 01:19 PM   #6
klm4755 OP
Oddometer: 575
Yes, the wheel would fit on the back rack, but at the loss of the racks cargo carry ability.
Keithm
Old 06-26-2013, 01:32 PM   #7
gogogordy
gogogordy's Avatar
Oddometer: 1,926
Keithm
The VR lives on top of the black plastic right-side radiator shroud and gets very little cooling air.
I'm certain you know how much electonics like heat...and Im not saying the VR wouldnt fail otherwise, but on the Vespas they are buried so uncharacteristically deep when compared to most other PTW's I dont see a down side to adding some cooling.
Anyway...great mod (I mounted my Rotopax up front in a similar fashion) and very well executed and documented. thanks for sharing.
Old 06-26-2013, 01:33 PM   #8
gogogordy
gogogordy's Avatar
Oddometer: 1,926
Keithm
Add'l benefit: The add'l weight up front from my gas or your spare actually improves the ride and handling/braking IMO.
Old 06-28-2013, 01:16 AM   #9
conchscooter
conchscooter's Avatar
Oddometer: 2,007
Thats a very clever and well thought out piece of work. From my own experience with a GTS removing the rear wheel is unnecessarily complicated and difficult- dealing with the exhaust and the fragile bushing (I used the Moto Amore bushing which I'm told also crumbles after a while) and the impossible to move bearing in the support plate for the wheel. I loved riding the GTS but the original vespa concept of simplicity seemed to have got left behind on these four stroke machines.
http://www.keywestdiary.com
IBA#39,523
conchscooter is offline   Reply With Quote
Old 06-29-2013, 08:22 PM   #10
Warney
Warney's Avatar
Oddometer: 568
Excellent fabricating skills and a clever solution. Changing a rear tire on the side of the road on a Vespa GTS is impossible without pliers, a breaker bar, multiple sockets, hex bit socket, torx bit socket, a socket wrench, extensions, and a torque wrench. Who carries all that? Then there is the matter of that fragile graphite bearing...
Vespaman video
http://www.youtube.com/watch?v=eUNXDSvpN7I
Alternate method requiring even more tools
http://www.youtube.com/watch?v=iSvFcNRFEuM
Warney is offline   Reply With Quote
Old 06-30-2013, 07:39 AM   #11
klm4755 OP
Oddometer: 575
Vespaman video
Good point, I'd suspect it would be desirable to carry these tools while in touring mode. I'm in the process of fabricating a lockable metal pannier for storage. Here are a couple of shots of concept:
pannier rack
rack + metal ammo can
left side of scooter, not yet fabricated rack to can mount....
I plan on carrying the tool list listed within the pannier.
Keithm
Times are GMT -7.   It's 07:19 AM.
