Go Back   ADVrider > Riding > Layin' down tracks > GPS Tracks - Rockies
Old 06-26-2013, 08:42 PM   #1
HighTechCoonass OP
Living the Dream....
HighTechCoonass's Avatar
Oddometer: 2,493
Laugh Colorado Discovery Route... sectional tracks
Hey fellows - doing this next week... any one have this broken down into sections...(500 point intervals) Thanks!
NEW dash plates for your F800..here... lhttp://advrider.com/forums/showthread.php?t=1007140
HighTechCoonass is offline   Reply With Quote
Old 06-26-2013, 10:00 PM   #2
Countdown
Oddometer: 5,663
There is a 500 point version on their web site?
Jerry Counts
Countdown is offline   Reply With Quote
Old 06-27-2013, 09:54 AM   #3
HighTechCoonass OP
Oddometer: 2,493
In the zip file it only has the full route and the one section the oury loop around
To lake city.
Old 06-28-2013, 07:50 AM   #4
wbbnm
wbbnm's Avatar
Oddometer: 2,220
Basecamp has a pretty easy-to-use tool for breaking up tracks. And you can do it in Mapsource by just cutting and pasting from the track properties dialog box like you would do with any other text file.
I do this all the time with tracks I download from other guys.
You might do a rough calculation of how many 500 point tracks you would get by breaking up the whole thing. If it is more than your GPS unit can handle, you can break the full track up into >500 point segments and then filter down to 500.
I believe the result would still be plenty good for navigation.
wbbnm is offline   Reply With Quote
Old 06-28-2013, 01:51 PM   #5
eddyturn
Wannabe
Oddometer: 2,063
HTCA - I went to their Web site and got the tracks and they are broken down by day. Maybe look again? Love to say hi if you get time through Durango area before or after the ride. I have one of your controllers and love it.
All things being equal... fat people use more soap
eddyturn is offline   Reply With Quote
Old 06-28-2013, 04:21 PM   #6
Countdown
Oddometer: 5,663
Just checked the Zip files and this is the one you want
COBDR FINAL 500pts.gpx
Jerry Counts
Old 06-28-2013, 05:49 PM   #7
HighTechCoonass OP
Oddometer: 2,493
Laugh
GOT IT... answered my own question after messing with it.... If you need them email me....
Garmin Base camp software
opened the raw file....it shows the separate tracks sections.
and I the created routes( using each tracks).
double click the tracks... the select "create a route" form the bottom of the open window...as shown...
see here .... highlighted the route... then select "file" "export" "export selection" as shown
Emailed the routes to myself to get the routes to my Iphone5 with the "pathaway" app software...
used the software to push to routes to my 60csX!
created 6 routes with the 2 go "arounds"....just like it shows up on there web site...
HighTechCoonass screwed with this post 06-28-2013 at 06:46 PM
Old 06-28-2013, 06:37 PM   #8
Countdown
Oddometer: 5,663
opened the raw file....it shows the separate tracks sections. and I the created routes( using each tracks). see here .... highlighted the route... then select "file" "export" "export selection" as shown no cutting and pasting needed..... Emailed the routes to myself to get the routes to my Iphone5 with the "pathaway" app software...used the software to push to routes to my 60csX! created 6 routes with the 2 go "arounds"....just like it shows up on there web site...
Yes great, but he was asking for 500 point Tracks not Routes.
Jerry Counts
Old 06-28-2013, 06:45 PM   #9
HighTechCoonass OP
Oddometer: 2,493
Laugh
yes sorry about that... I will delete edit post.... from what I can tell a route make it more efficient... (takes out the unnecessary intermediate points)
I like the separate sections... make it easy to manage since it is a multi-day trip.
Old 06-28-2013, 08:18 PM   #10
Countdown
Oddometer: 5,663
If you read about long trips, a lot of people do use routes but they have huge risks of autorouting. Most experts advise always have tracks for your trip, they are idot proof. Most people with hand helds only use tracks.
Jerry Counts
Old 06-28-2013, 08:42 PM   #11
HighTechCoonass OP
Oddometer: 2,493
Laugh
That is exactly the kind of advice I need... because I have always only used a GPSs to tell "where I am" in the back country... referencing topo book maps. I will add the tracks also! Thanks for the advice I loaded up both...
HighTechCoonass screwed with this post 06-28-2013 at 08:58 PM
Old 06-30-2013, 01:08 PM   #12
HighTechCoonass OP
Oddometer: 2,493
Puke
Warning.... tracks on my 60csX is limited to 500. the track was truncated... end section was cut off.... I see why now I hate messing with these devices... I have enough to learn everyday at work with new electronic control systems, when i get home i like to turn the brain off!
HighTechCoonass screwed with this post 07-01-2013 at 06:51 PM
Old 07-01-2013, 09:48 AM   #13
Countdown
Oddometer: 5,663
Warning.... tracks on my 60csX is limiter to 500. the track was truncated... end section was cut off.... I see why now I hate messing with these devices...
I don't understand.
Yes very common knowledge, last generation units uses 500 point tracks.
Go to COBDR web site, download 500 point track file.
Download file to your 60 and you are done. There is no messing.
Jerry Counts
Old 07-01-2013, 06:49 PM   #14
HighTechCoonass OP
Oddometer: 2,493
Laugh
yeap that's what I did.... and I renamed each track s1,s2,s3,s4,s5, and s6... So I could view... otherwise the tag is so big you cant see where you are going...
also a note routes are limited by 250 points. sometimes common is not so common
I don't understand.
HighTechCoonass screwed with this post 07-01-2013 at 07:23 PM
Old 07-01-2013, 09:20 PM   #15
Countdown
Oddometer: 5,663
I renamed each track So I could view... otherwise the tag is so big you cant see where you are going...
What do you mean by this? This is a point to point ride with no crossovers so just turn every track on and go. It will just look like one long track from end to end. No need to know where one ends and next starts.
Jerry Counts
Times are GMT -7.   It's 06:55 AM.
