Old 06-28-2013, 12:37 PM   #16
LocuL
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,332
anyone done anything with the Aqualines/safaris?
http://www.motocrossworld.com/site/s...oduct_id=33834
KTM 950(1190) Adv-s, Soon to be Project 1190
KTM 530 EXC-R 08
LocuL is offline   Reply With Quote
Old 06-28-2013, 02:58 PM   #17
srad600
srad600's Avatar
Oddometer: 672
Originally Posted by crazybrit View Post
It sounds like a product opportunity for the company owner. With a bit of research I bet he could come up with a version that fit the 990 and was removable for easy cleaning.
Yep, but he was under the impression someone else was already doing that research.
Isn't this the exact same thing the OP is using, only you're holding onto it?.
Looks that way to me. Seems like a simple and effective product either way.
srad600 is offline   Reply With Quote
Old 06-28-2013, 04:44 PM   #18
Trail bandit OP
Random adventurer
Oddometer: 204
Originally Posted by KTMbageera View Post
The new fuel cap w/filters from CJ Designs look good to me. This is how I have been doing it.
http://youtu.be/uEI2Ancvd3w
Yeah, this was my worst case option. Good video.
Really glad the soldering worked out. Buy a second filter , hex key in the electric driver, solder iron and then thirty minutes later you won't need to carry a soggy extra large condom around ever again.
Trail bandit is offline   Reply With Quote
Old 06-28-2013, 06:37 PM   #19
azcagiva
new orange flavor
azcagiva's Avatar
Oddometer: 1,152
Cool idea.
-John
An Elefant never forgets.
www.Raceforthewounded.com
azcagiva is offline   Reply With Quote
Old 12-30-2013, 01:03 AM   #20
guglemonster
Oddometer: 299
sold and cold
sorry, b ut the splitstream system is too lame
first is a single layer strainer, it will wash out fine particles, I prefere multylayers with overlock sawn
second is far too expensive, here in EU 80 euros the couple!!!!
third the way you fixed it is too delicate :), gluing or soldering may brake and in the right tank it will be hard to recover
sorry for beeing so direct, but I have being producing and mounting the ultimate product for the last 3 years with 7 different kind of filtration, water separation, micron selection (from 30 to 0 microns) and refueling speed
there is already a post here of somebody who installed my system
here some pictures if you want :)
plus I did the system also for SMR, SMT, 1190 ADV and BMW 1200 and 800
KTM is far behind this one aahahahah
happy new year :)
guglemonster is offline   Reply With Quote
Old 12-30-2013, 01:05 AM   #21
guglemonster
Oddometer: 299
yes
WE
guglatech eheheh
20-30 microns for carburettors bikes
0 micron fuel injection
0 micron with water separation for extreem riding
0 micron with water separeting insert for rally and around the world tours :)
we rulezzz :)
Old 12-30-2013, 05:21 AM   #22
rossguzzi
990 Adv.
rossguzzi's Avatar
Oddometer: 1,024
Gugglemonster can you tell more about it ??
990 Adv 06, Aprilia Tuono 03 Racing gen 1
rossguzzi is offline   Reply With Quote
Old 12-30-2013, 07:11 AM   #23
guglemonster
Oddometer: 299
sure, shoot the questions :)
btw, depending on the shape and construction of your tuono tank cap it may be possible to adapt one filter to your tuono as well :)
mp me with whatever questions
I still have to understand how it works here, sorry i'm too much of a neewbee here
regards :) and I miss my green face for the smiles heheheeh
: killen
Old 12-31-2013, 08:46 AM   #24
renogeorge
Oddometer: 1,393
Looks like a good alternative. With 3 tanks, I am going with external,inline filters for the right side and auxiliary tanks. Looking for a handheld filter for use with the left side tank for those rare instances where I am getting questionable quality gas. Anyone have a source???
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Old 12-31-2013, 03:27 PM   #25
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,819
http://www.amazon.com/Racor-Fuel-Fil...+filter+funnel
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Old 12-31-2013, 09:39 PM   #26
renogeorge
Oddometer: 1,393
Thanks. Might work. I like the filtration but was thinking of something foldable and taking up less space.....
KTMs--300, 518, 990
Old 01-01-2014, 04:14 AM   #27
guglemonster
Oddometer: 299
Unless you will use 30 microns or less filtering capacity you will never prevent the per-pump filter from clogging up and the pump from cavitating
The stupid paper filter in the pump is working between 5 and 10 microns and you will have to replace them eventually too, again falling in the stupid original design
Change the prefilter at the pump with a bigger one, eliminate the paper one with an automotive stell canister external setup and prefilter at cap
Unless you will refuel diesel or sugar enriched petrol your bike will never ever suffer from filter or fuel starvation
Eliminating the stupid paper filter will improve also pump efficiency pushing a couple of lines of bars, 0,2 bar usually, more due to smaller flow resistance
Result is a better throttle response at low and middle range
This is the set up runninr on my as well as other bikes at the moment
Can't beat it ;);););)
E funnel is ideal for 4x4 for bike is a real pain in the back
Old 01-01-2014, 11:16 AM   #28
Themastermike
Passin gas
Themastermike's Avatar
Oddometer: 785
Those gains seat of the pants or dyno?
Sent using Telepathy
BBF 03-09-13 "It is cool. I was playing dakar racer It truly was a gr8 day of riding you bitch"
Themastermike is online now   Reply With Quote
Old 01-01-2014, 11:29 AM   #29
Spark01
V-Twin
Spark01's Avatar
Oddometer: 305
There is a pressure regulator inside the fuelpump. Removing a filter doesn't increase any thing. The pressure regulator will maintain that same fuel pressure....
'10 990SMT
Spark01 is offline   Reply With Quote
Old 01-01-2014, 12:11 PM   #30
guglemonster
Oddometer: 299
Yesno
The pressure maybe the same but the flow and resistance to flow have nothing to do with pressure since the pump will have to fight less in case of bigger and better flow surface
We do not talk about more power just about better throttle response derived from less resistance from the media ;)
Times are GMT -7.   It's 10:52 PM.
