Old 06-27-2013, 02:09 PM   #1
Bronco638 OP
Nobody Home
Bronco638's Avatar
Oddometer: 3,827
Sump Pump Battery Backup System - Recommendations?
I did a search and came up empty (on Adv Rider).
Is anyone using a Sump Pump Battery Backup System? If so, can you recommend a manufacturer and perhaps state what the total cost was?
I am handy enough that I can install the system myself. So, I'm really curious about who has what, how it's performed (good or bad) and if you think it's worth the time, effort & money.
Full Disclosure; I live in a townhouse community. Each of the buildings has four units. Each unit has a basement with a sump pump. I have heard some of my neighbors state that all of the sumps, in each building, are somehow tied together. I'm guess this is some type of 'emergency' system so that if one pump fails, theoretically, the water will make its way into the neighbor's sump and be ejected by that (working) pump. My t-house is internal (not one of the two end units) and my sump does appear to have ports that run to the neighboring units, on either side. However, if I peer into them, they dead end. So, if the sumps are tied together, it's external to my basement. My sump pump does not seem to run as much as all of my neighbors (based on their observations). I do not know why it runs so little but I do know it works as I test it occasionally. My t-house will be 13 years old in November. I have been thru one pump already (I'm pretty sure it was some crap unit used by the builder - based on it's appearance, when it failed, it was quite old). The current one is sold by Ace Hardware and is either 1/3 or 1/2 hp. I have no reason to expect it will fail any time soon. But, my basement is finished and I would like a little extra piece of mind especially if the power fails during a big Midwest t-storm. I have never had any flooding issues since moving in. Even when the first pump failed, I was lucky enough to discover it before 'bad things' happened.
So, what do you recommend based on your experiences?
TIA, Dave.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 06-27-2013, 02:18 PM   #2
pelvis_98
Havin A Time
pelvis_98's Avatar
Oddometer: 1,979
I have a flowtec. I think that is the make of it.
I have had to for 5 years now and i have only used it once. So i have no real recomondations on it or how well they work.
I do like that it not only works if the power goes out, but if the other pump fails for what ever reason. It has a little alarm on it so that you know that the main pump has failed and your back up has run.
Once a month i give my backup pump a test. It has a button to pust to test it and once a month i check the water level in the mattery. I have a deep cycle marine battery on it but have gone through two of them in the last 5 years.
I think because its always on some sort of charge and never gets drained it doesnt last as long?
I paid about 300 Canadian for the pump and around 100 for the battery for it.
pelvis_98 is offline   Reply With Quote
Old 06-28-2013, 07:41 AM   #3
Bronco638 OP
Nobody Home
Bronco638's Avatar
Oddometer: 3,827
I think a deep cycle battery requires "draining" and then a full recharge to stay 'healthy'. So, that would make sense. I was thinking of going with an AGM battery.
Old 06-28-2013, 08:32 AM   #4
pelvis_98
Havin A Time
pelvis_98's Avatar
Oddometer: 1,979
I agree with you. I just used the battery that was recommended in the paper work.
I will likely be switching battery types when its time to replace it.
Old 06-30-2013, 06:57 AM   #5
Wasser
Spilt my beer
Wasser's Avatar
Oddometer: 4,980
I have a domestic water operated sump pump as a back-up.
LINKY
Never have to worry about a battery.
Wasser is offline   Reply With Quote
Old 07-02-2013, 08:37 PM   #6
Just Max
Just Max's Avatar
Oddometer: 272
Move..?
I put the F in luck
Versys ADV Build
Just Max is offline   Reply With Quote
Old 07-08-2013, 08:26 AM   #7
BrittC
BrittC's Avatar
Oddometer: 280
I recently upgraded my backup sump pump from a crappy Basement Watchdog to a Wayne Emergency Backup Sump Pump 3300 GPH, Model# ESP25. The pump is MUCH more substantial, flows over three times as much water as my old backup pump, and each time I've tested it there has been no issue at all. Running on battery power it empties my sump pit nearly as quickly as my main pump.
I got mine from Northern Tool for about $250 (without the battery).
2002 Aprilia ETV1000 Caponord
2008 Yamaha WR250R
1992 Yamaha XT225 Serow
http://britt-motorcycling.blogspot.com
BrittC is offline   Reply With Quote
Old 07-08-2013, 12:57 PM   #8
broncobowsher
broncobowsher's Avatar
Oddometer: 1,578
LINKY
This is my thought as well. Battery only lasts so long. Big storm, extended outage, screwed.
So long as you have water service this will work.
Battery maintance sucks. Hate having to replace a $100 battery that was never used for anything other then an occosional test of the system.
broncobowsher is offline   Reply With Quote
Old 07-09-2013, 03:38 AM   #9
pelvis_98
Havin A Time
pelvis_98's Avatar
Oddometer: 1,979
I hate the battery too. But I am on a well so I dont have much choice.
Though your back up will last fairly long as your sump pump does not run non stop. Only runs when it needs to pump water out.
Old 07-09-2013, 08:16 AM   #10
Smoke Eater 3
Oddometer: 686
A few years ago when we had some area flooding, I hooked up a bilge pump with a float switch to a deep cycle battery. It worked fine and moved plenty of water. I just routed the hose out a basement window.
Smoke Eater 3 is offline   Reply With Quote
Old 07-09-2013, 08:43 AM   #11
Bronco638 OP
Nobody Home
Bronco638's Avatar
Oddometer: 3,827
LINKY
This is a neat idea but that means I would have to run a water line to that corner of the basement. For me, that means turning off the main and draining the house.
This sounds more like what I'm looking for. I have a source for deep cycle batteries. Given the weather, in Chicago-land, this Spring/Summer have you had to use your back-up Britt?
Old 07-09-2013, 01:06 PM   #12
broncobowsher
Oddometer: 1,578
Do you have a washing machine in the basement? Run a splitter off the water line.
As long as it doesn't mess up your neighbors, shutting off and draining a water line is not that big of a deal.
I just hate maintaining batteries that are rarely used.
Old 07-09-2013, 02:05 PM   #13
Bronco638 OP
Nobody Home
Bronco638's Avatar
Oddometer: 3,827
Nope, the washer & dryer are on the second floor. There is a slop sink but that's in the opposite corner (~40' away). My basement is also partially finished (that is, about 60% finished and 40% storage/mechanical space). I would need to remove a lot of ceiling tiles to run that line.
Each townhouse has it's own water supply so I don't need to worry about "messing up the neighbors". It's not that big of a deal (to run a water line) but enough of a deal that I think the balance is tipped towards the back up system with battery.
I hate maintaining rarely used batteries as well. I wonder if a regular car battery, on a trickle charger, would work just was well.
Old 07-10-2013, 08:13 PM   #14
showkey
Oddometer: 1,916
Negative on the regular car battery.........they do not tolerate deep cycling and generally do not have the AH capacity needed to run the pump for long periods.
1982 CX500 Turbo ,2006 ST1300, 2012 NC700X
1971 CT90,1981 C70, 1986 TRX 250,
1993 TRX300 4X4, 2001 TRX500 4x4, 1987 XR250L
showkey is offline   Reply With Quote
Old 07-11-2013, 08:16 AM   #15
pelvis_98
Havin A Time
pelvis_98's Avatar
Oddometer: 1,979
The backup pump does have a trickle charger built into it.
I think the problem with the deep cycle marine battery is they work best if they go dead and charged again. (at least i believe thats the way they are designed.)
The problem is the battery is never used unless the power goes out, and even then that does not mean the pump actually needs to run.
So in the 5 years i have had the back up pump it has never run on the battery. Other then when i have pressed the button to test it.
Times are GMT -7.   It's 10:32 PM.
