Old 06-27-2013, 10:59 PM   #1
Skippii OP
Hookers, my lad.
Skippii's Avatar
Oddometer: 6,506
How to make cheap and heavy spoke wheel weights
I recently decided to balance my Yahama XT350's rear tire, which has a single rimlock, but has never been balanced.
First thing I did was duct tape a bunch of 1/2" nuts and bolts to the rim and spokes to figure out how much weight I'd need. Then took them off, and using a digital kitchen scale, worked out I'd need 9oz (255g) of weight, or a little over half a pound. Or 36 of the 1/4oz stick on weights. Clearly, I needed a better solution. So I got a 1-inch pipe nipple.
I clamped some scrap metal to either side.
And welded the scrap to one side. (The other side just has the scrap metal so I have something to which to clamp.)
Simple enough.
...okay, I still suck at welding. I left a little gap in it. Don't leave any holes.
Secure it in place...
Go to the local tire shop and ask for any old weights they have pulled off vehicles. They gave me about half a pound for free. They have the steel tabs on them, so grab an oxy-acetylene torch. I'm actually using this rosebud torch with oxy-propane, and it works perfectly well for this application. A blowtorch might even be hot enough.
Lead is apparently toxic, or so they say. I ate plenty of lead paint chips and solder as a kid and I turned out completely normal, but I guess it's a good idea to wear some kind of protection. I'm not sure how much a respirator cartridge that seems to have been eaten by mice will protect lung from lead fumes, but it's probably better than nothing. I don't know if melting lead produces much in the way of fumes, but I'll want it when cutting and grinding later anyway.
Hold the metal tab with vicegrips, and the lead melts off in seconds and drips into the pipe. Only takes a few minutes to fill up the pipe...although when it was about halfway fill, it suddenly started leaking and a bunch of lead came up from the bottom of the brick. It looks like I spilled the lead, but I didn't..I just didn't properly weld the bottom on.
Pull out the pipe nipple.
...or not. Damn, that thing is soldered to the brick REALLY well.
Turn it over and hammer the pipe out...
Finally it comes free...
Use a brazing tip to melt the lead off the sides and clean it up.
Then go over to the drill press, and realize that you now want to secure the pipe again. Should have just left it in the damn brick! Oh well, drill a 1" hole in a block of wood with a spade or forstner bit, then drill a 1/8" hole (or however thick your spokes are) through the pipe.
Since the pipe nipple bulges in the middle, I used a rasp the thin the middle of some scrap wood so it would stay in the vice.
Cut a slot down to the hole with a metal cutting circular saw.
Remember that this needs to go over the spoke nipple as well, so drill out about half with a wider bit.
One 5 ounce spoke weight, all finished!
Slide it on the spoke...
I still needed more weight, though, so I got some threaded steel rod...
Drilled and cut that as before..
That rod was really, really hard to split open enough to get over a spoke.
Here they are, 9 ounces of weight, just slid over the spokes.
I then used vice grips to clamp them on so they wouldn't come off. The lead pipe was east to clamp on. Then I went over the seam with lead solder and the torch, working quickly so I wouldn't heat up the spoke enough to pop the inner tube. The steel pipe was not so happy to crimp onto the spoke, and ended up deforming my vise-grips after closing just a little bit. That channel was just filled in with solder.
I put some epoxy on them both, to keep the steel from rusting as well as holding them in place.
Somehow, I forgot to take a picture of the end result, but rest assured I did makes sure they were very secure before riding it.
"Umm be careful what you say, this is Skippii....
You may get it delivered in the form of a shake or some interperative dance routine that involves nakedness, pizza and a stuffed raccoon..." -DCrider
Skippii is offline   Reply With Quote
Old 06-28-2013, 08:23 AM   #2
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,540
I should have said something after your other post on balancing. I may have had some environmental and safety concerns.... Actually too busy at work to post.
Could have saved you time....money for gas, drill bits and a heck of a mess from the "Great stuff". I had a can of that start shooting on me recently,valve got stuck when I removed it from the gun, made a heck of a mess of my freshly cleaned gun but I was working outside so just dropped the can , threw a rag on it and left it on its own for a while.
I did cast a lot of lead with my grandpa back in the days, making battery posts adapters to go from side posts to top posts terminals.
Crucible was just an old ladle with a pour spout. Attach all the steel weight clips together with wire then melt in the ladle. Pull out the clips.
Pour was always in a block of hard wood drilled to specs. Let cool and because we had to drill for a bolt we just drilled with the lead still inside the piece of wood.
Would work to cut a slot, just hacksaw into the wood through the lead. If you lined up the cut with the woodgrain, all it takes is a chiesel to break the wood and free the weights.
We almost had to do that for my friend's old Triumph resto, but he did find/recycle enough weights. Maybe next time, darn things are expensive.
I used to be good at filling the bucket with old weights, to the point where I couldn't move it. Now I have lead on my hands and maybe the computer, just checked the fishing tackle box and there is a 12lbs cannon ball that we can't use for fishing, missing a hook. May just come home with me that one.
Have tools, will travel!
Old 06-28-2013, 10:16 AM   #3
ohgood
ohgood's Avatar
Oddometer: 2,633
welding galvenized steel ! danger will robinson ! danger !
scrolling through the words to get to the pictures is cool, but i'm really just here for the tracks and waypoints... post some ok ?
ohgood is offline   Reply With Quote
Old 06-28-2013, 11:48 AM   #4
groundrules
groundrules's Avatar
Oddometer: 1,663
just curious- if you need 9oz of weight, isn't something else wrong?
groundrules is offline   Reply With Quote
Old 06-28-2013, 12:42 PM   #5
HapHazard
Waiting for Gudenov
HapHazard's Avatar
Oddometer: 2,235
Hello, I'm actor Troy McClure. You kids might remember me from such educational films as "Lead Paint, Delicious But Deadly" and "Here Comes the Metric System!"
One must be aware that in a Skippii how-to thread, certain commonly-held, well-established health and safety guidelines are sure to be either ignored or actively disregarded.
This should NOT be cause for concern - Skippii has proven to be indestructible, and it is the hallmark of a Skippii thread.
HapHazard is offline   Reply With Quote
Old 06-28-2013, 12:48 PM   #6
viverrid
not dead yet
Oddometer: 30,482
That looks like WAY more trouble than it is worth. It's only "cheap" if your time is worthless. And yeah, if you need 9 oz. of weight, something else is wrong other than just having a single rim lock. I've had several bikes with a single rim lock (I have one now) and none has ever needed 9 oz. to balance. A rimlock weighs less than 4 oz.
Really frugal riders have been known to just wrap wire around the spokes for balance weight, but it would take a lot to get to 9 oz. that way.
Advanced pancreatic cancer found 04/2010. Have outlived +/- 97% of patients with this diagnosis, but 08/2013 cancer now in liver, vascular system and lungs with 20+ lung tumors. Sick/weak sometimes, not riding much. No more treatments & now under Hospice care.
viverrid screwed with this post 06-28-2013 at 12:57 PM
viverrid is offline   Reply With Quote
Old 06-28-2013, 12:54 PM   #7
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,247
9 oz. is an insane amount of weight. you may want to demount the tire, remove the tire iron you left inside the tire, and remount. then balance it... the absolute heaviest rim lock i have here is 3.2 ounces...
current bikes
stainlesscycle is offline   Reply With Quote
Old 06-28-2013, 12:58 PM   #8
viverrid
not dead yet
Oddometer: 30,482
Originally Posted by stainlesscycle View Post
9 oz. Is an insane amount of weight. You may want to demount the tire, remove the tire iron you left inside the tire....
lol!!!
Old 06-28-2013, 01:00 PM   #9
Skippii OP
Hookers, my lad.
Skippii's Avatar
Oddometer: 6,506
The pipe was not galvanized. They come in galvanized and black steel. I used black steel.
(If you want to see me weld galvanized, check out the muffler threads. I do it a lot there, but don't recommend it.)
Old 06-28-2013, 01:43 PM   #10
trailer Rails
trailer Rails's Avatar
Oddometer: 3,371
That option was discussed is the other thread and he stated it was too much work to remove the tire and line up the light spot of the tire with the rim lock.
trailer Rails is offline   Reply With Quote
Old 06-28-2013, 01:48 PM   #11
Yukon65006
Yukon65006's Avatar
Oddometer: 524
Just zip tie some 1/0 welding cable to a spoke.
______________________________________
Turn signals are like farts, never trust them.
Yukon65006 is offline   Reply With Quote
Old 06-28-2013, 02:29 PM   #12
groundrules
Oddometer: 1,663
how about just zip tying the rest of that brick on there?
Old 06-28-2013, 03:25 PM   #13
Truckin_Thumper
low profile
Truckin_Thumper's Avatar
Oddometer: 28,872
Eye Heart Skippii threads
gimmie the button!
Truckin_Thumper is offline   Reply With Quote
Old 06-28-2013, 03:59 PM   #14
stainlesscycle
Oddometer: 2,247
less work than fixing a flat on the side of the road when the tire goes flat, or one of them wheel weights zings off like a bullet through the body part of your choice or tears up your fender??? i think there is a potential for disaster here..
current bikes
Old 06-28-2013, 04:22 PM   #15
jantarek
jantarek's Avatar
Oddometer: 1,041
$4.99 at Amzon for bunch of stick on's Link
but you go on and build your weights if it makes you happy
My Blog: www.jantarek.com RR is on
Save $5 on www.smugmug.com enter this code:
TINCpSleQpUSI
My SpotWala
jantarek is offline   Reply With Quote
Times are GMT -7.   It's 04:28 AM.
