Old 06-28-2013, 03:26 PM   #16
ChromeSux
Plated and screwed
ChromeSux's Avatar
Oddometer: 1,521
Even the guy that invented the wheel did not need 9oz on his first wheel, that is messed up, are you sure this wheel is actually round.
ChromeSux is offline   Reply With Quote
Old 06-28-2013, 04:06 PM   #17
joexr
Oddometer: 3,773
I don't even think his HEAD is round.
Old 06-28-2013, 04:15 PM   #18
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,819
Klr?
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Old 06-28-2013, 08:24 PM   #19
ONandOFF
-ROAD-
ONandOFF's Avatar
Oddometer: 6,672
Originally Posted by Skippii View Post
I recently decided to balance my Yahama XT350's rear tire, which has a single rimlock, ...
One 5 ounce spoke weight, all finished!
An "A" for initiative! When faced with similar circumstances, I took the items of required weight to the motorcycle dealer and asked what they had for balancing weights. Luckily, they produced sizeable lead weights that simply clamp onto the spokes.
I know... what fun is that?
Let's ride!!! - No offense, but there've been a lot of people over time who were just as sure, yet got it wrong. - Una necedad, aunque la repitan millones de bocas, no deja de ser una necedad. - "you know that I could have me a million more friends and all I'd have to lose is my point of view" (Prine)
ONandOFF is offline   Reply With Quote
Old 06-28-2013, 08:53 PM   #20
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,635
I don't know if melting lead produces much in the way of fumes, but I'll want it when cutting and grinding later anyway.
When else would you encounter lead fumes?
FWIW, lead smells like blueberries. I've melted hundreds of pounds. Do it outside and stay up-wind from it; a busted respirator won't help.
crazydrummerdude is offline   Reply With Quote
Old 06-28-2013, 09:37 PM   #21
Beezer
Oddometer: 5,850
"torpedo" fishing weights.... couple oz each, & ya,,,, seems to be an excessive out of balance you have
Beezer is online now   Reply With Quote
Old 06-29-2013, 02:28 AM   #22
willis 2000
neo-quixote
Oddometer: 3,653
ya had another thread showing deterioration of your rims
your charging system is causing the alloys to react
put on a mosfet rr
,repair previous damage
willis 2000 is offline   Reply With Quote
Old 06-29-2013, 02:31 AM   #23
willis 2000
neo-quixote
Oddometer: 3,653
are you unconcerned about dissimilar metals
even with a lead buffer
Old 06-29-2013, 06:18 AM   #24
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,333
Somebody needs to take your tools away, Skippii
About half the time I think you are trolling, and the other half the time, I'm really not so sure...
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 06-29-2013, 07:55 AM   #25
ohgood
ohgood's Avatar
Oddometer: 2,902
The pipe was not galvanized. They come in galvanized and black steel. I used black steel.
(If you want to see me weld galvanized, check out the muffler threads. I do it a lot there, but don't recommend it.)
ok, just checking :)
Yes, Android AND iphone GPS works without cellular data. Use offline maps and enjoy. (thanks drtbyk!)
ohgood is offline   Reply With Quote
Old 06-29-2013, 08:01 AM   #26
VonHelm
soggy doggy
VonHelm's Avatar
Oddometer: 4,000
9 oz? WTF?
Are you trying to balance a bent rim? :crazy
http://www.oilandpiston.com/
Well he’s one of those who knows that life
Is just a leap of faith
Spread your arms and hold you breath
And always trust your cape (Guy Clark)
VonHelm is offline   Reply With Quote
Old 06-29-2013, 08:48 AM   #27
Skippii OP
Hookers, my lad.
Skippii's Avatar
Oddometer: 6,505
Originally Posted by trailer Rails View Post
That option was discussed is the other thread and he stated it was too much work to remove the tire and line up the light spot of the tire with the rim lock.
That's not really accurate. I said that there was no indication of a light or heavy spot on the tire, and I disagreed with the assumption that it was pure coincidence that the heaviest spot on the rim just happened to be exactly where the giant old rimlock was installed. That indicated to me that the rimlock is causing the weight.
"Umm be careful what you say, this is Skippii....
You may get it delivered in the form of a shake or some interperative dance routine that involves nakedness, pizza and a stuffed raccoon..." -DCrider
Skippii is offline   Reply With Quote
Old 06-29-2013, 08:53 AM   #28
Skippii OP
Hookers, my lad.
Skippii's Avatar
Oddometer: 6,505
During reactions or compounds where lead is volatile, like leaded gasoline exhausts and stuff like that.
Lead melts around 600*F, and boils well over 3,000*F. I don't suspect that heating it to a barely liquid state is going to give off a lot of fumes, in the same way that puddles of mercury don't evaporate.
Still, I had the fan going and the respirator on because as I always say, Safety Third.
Old 06-29-2013, 08:56 AM   #29
Skippii OP
Hookers, my lad.
Skippii's Avatar
Oddometer: 6,505
Originally Posted by viverrid View Post
That looks like WAY more trouble than it is worth. It's only "cheap" if your time is worthless.
If I'm not riding, I like to spend my days off in the garage finding creative solutions for stuff like this. For me, it is very therapeutic and time well spent.
Old 06-29-2013, 09:01 AM   #30
Skippii OP
Hookers, my lad.
Skippii's Avatar
Oddometer: 6,505
I had another bike with a much smaller rimlock that I took to a pro mechanic to have him balance. It took him over and hour and 5.55oz of weights for him to do it.
This rim lock is about twice the size, so I don't think it's that unreasonable.
Times are GMT -7.   It's 04:41 PM.
