Old 06-29-2013, 10:03 AM   #31
Skippii OP
Hookers, my lad.
Skippii's Avatar
Oddometer: 6,506
Originally Posted by VonHelm View Post
9 oz? WTF?
Are you trying to balance a bent rim? :crazy
Originally Posted by willis 2000 View Post
ya had another thread showing deterioration of your rims
your charging system is causing the alloys to react
put on a mosfet rr
,repair previous damage
Originally Posted by ChromeSux View Post
Even the guy that invented the wheel did not need 9oz on his first wheel, that is messed up, are you sure this wheel is actually round.
This rim rear rim is not damaged.
The front rim of this bike had corrosion, but balanced easily.
"Umm be careful what you say, this is Skippii....
You may get it delivered in the form of a shake or some interperative dance routine that involves nakedness, pizza and a stuffed raccoon..." -DCrider
Skippii is offline   Reply With Quote
Old 06-29-2013, 10:22 AM   #32
WRW9751
7th Day Adventurist
WRW9751's Avatar
Oddometer: 380
Easier Way?
It's much nicer to ride a balanced wheel than not, but it sure seems your adding a lot of pain just to save a few bucks. There are some solutions that work rather well and not that much. Motion Pro makes a light weight rim lock.
http://www.dirtrider.com/tests/parts...m_lock_review/
You can go tubeless but for a price. In the old days we used to take out the rim locks and drill holes in the rims and screw stainless 10# screws into the bead. This allowed the tire to run at fairly low pressures and still balance, using strip weights. I am also in agreement with others that your having to use WAY to much weight. At most I would accept is 1 ounce. It will vary depending on where the rim loc is compared to the valve stem.
WRW9751 is offline   Reply With Quote
Old 06-29-2013, 12:28 PM   #33
freeflow
get in or go in
freeflow's Avatar
Oddometer: 15,607
a rim lock on an XT350
freeflow is offline   Reply With Quote
Old 06-29-2013, 12:40 PM   #34
joexr
Oddometer: 3,773
Thumb
Good point.
Old 06-29-2013, 01:46 PM   #35
VonHelm
soggy doggy
VonHelm's Avatar
Oddometer: 3,994
Bless yer heart, Skippii.
While I find your posts endlessly entertaining, having to add that much weight to a motorcycle wheel is indicative that there is something wrong. The wheel is bent, out-of-round, or desperately needs to be trued.
If you spent half as much effort diagnosing and correcting the problem as you spend endless hours concocting cockamamy solutions, you'd be way ahead of the game.
http://www.oilandpiston.com/
Well he’s one of those who knows that life
Is just a leap of faith
Spread your arms and hold you breath
And always trust your cape (Guy Clark)
VonHelm is offline   Reply With Quote
Old 06-29-2013, 04:32 PM   #36
ABHooligan
The Flying Mythos
ABHooligan's Avatar
Oddometer: 1,124
Skippii,
I always tune in to your threads. They're fascinating to me. I can identify with your enjoyment of garage tinkering/fabricating, but my mind doesnt reach the same mad-scientist-on-opiated-shrooms level.
However, I wouldn't want to be riding (or driving an armored truck) behind you when one of those weights becomes a projectile.
"Motorcyclist killed by homemade sabot round" Tonight at eleven.
I've ridden a peppy xt350, and never thought it had enough juice to need rim locks.
"I tried to move my mind there and nowhere else and imagine a single detail that, if I didn't see it that weekend, I never would... The world is easily lost."
James Dickey
ABHooligan is offline   Reply With Quote
Old 06-30-2013, 10:29 AM   #37
oPAULo
jack of all terrain
oPAULo's Avatar
Oddometer: 3,979
Old rim locks are heavy. HEAVY.
Without a rim lock, an XT350 will shuck a tire in a heartbeat in the nasty woods at 8-10 psi.
Zero dollars spent.
Tinkering in the garage like men do.
A fine job Skippii.
Mine haven't moved in 4+ years and 20+ thousand miles of road, gravel, dirt, trail and track.
Got to be close to 9 oz.
oPAULo is offline   Reply With Quote
Old 07-03-2013, 06:15 PM   #38
CycleDoc59
Wrench Rider
CycleDoc59's Avatar
Oddometer: 944
It's normal to install 2 rimlocks opposite each other.
Because they are heavy. Then heavy balancing weights are not needed.
Lead "egg" sinkers range from 1/4oz up to
8oz each. I drill a small hole end to end, then saw in a split
and squeeze on the spokes. Reusable too...
http://www.basspro.com/Bass-Pro-Shop.../product/7564/
CycleDoc59 is offline   Reply With Quote
Old 07-09-2013, 05:59 AM   #39
ONandOFF
-ROAD-
ONandOFF's Avatar
Oddometer: 5,908
Zero dollars spent.
A fine job Skippii.
I also have two like these plus one that looks like their kid: 2 - 1/2 Ounces total. I thought that was a lot of weight on a wheel. Sure looks like a lot. But they've been needed to balance through a handful of tires already, not to mention through a rim change. They stayed in place even as the rim sustained sufficient pounding to crack. It rides as smooth as a knobby allows at 90mph.
I suspect Skippii probably spun the rim and looked for out-of-round and out-of-true. Yes, 9Oz does seem excessive, but it is what it is, and that's the weight it took to balance (if the weight measurement is accurate). And if he'd rather roll his own than pick up weights like this at a dealer, well I have seen folks do much less productive things. Even if he does use non-ViseGrip ViseGrips!
Let's ride!!! - No offense, but there've been a lot of people over time who were just as sure, yet got it wrong. - Una necedad, aunque la repitan millones de bocas, no deja de ser una necedad. - "you know that I could have me a million more friends and all I'd have to lose is my point of view" (Prine)
ONandOFF is offline   Reply With Quote
Old 07-09-2013, 07:10 PM   #40
LexLeroy
Aging Gracelessly
LexLeroy's Avatar
Oddometer: 1,963
Spent uranium fuel rods... they're pretty heavy. 3/4" brass rod is cheaper, however, and you could make yourself some fancy re-usable weights with the addition of some tapped holes and stainless set screws. Wouldn't look as cool as the pipe nipples, but sometimes one must settle for less.
"That's MISTER Crash to you, sonny...."
LexLeroy screwed with this post 07-09-2013 at 07:29 PM
LexLeroy is offline   Reply With Quote
Old 07-10-2013, 12:50 AM   #41
peterman
cop magnet
peterman's Avatar
Oddometer: 13,464
nine frikken ounces?
shit!,,you coulda just duct taped a small kitten to the spokes on the light side!
Let's see,,16 ounces used to be a pound,,so,, 9 ounces is ,,,,,Wow! like half a beer!
peterman
___________________________
"Your God, your rules,,YOU go burn in hell!" LLV
peterman is offline   Reply With Quote
Old 07-10-2013, 09:07 AM   #42
HapHazard
Waiting for Gudenov
HapHazard's Avatar
Oddometer: 2,235
Beer wouldn't work - it'd get all shaken up and spray everywhere and of course, waste beer.
The kitten on the other hand...
HapHazard is offline   Reply With Quote
Old 07-10-2013, 09:33 AM   #43
foxtrapper
Oddometer: 755
Might I suggest next time you use use solder or lead wire and simply wrap it around the spokes?
True, it's not as entertaining as casting your own weights. But it is fast easy and effective.
foxtrapper is offline   Reply With Quote
Old 07-11-2013, 04:17 PM   #44
bajaburro
Ancient Adventurer
bajaburro's Avatar
Oddometer: 1,550
Originally Posted by jantarek View Post
$4.99 at Amzon for bunch of stick on's Link
but you go on and build your weights if it makes you happy
look at the shoes he's wearing.tells the whole story.
ancient adventurer
bajaburro is offline   Reply With Quote
Times are GMT -7.   It's 01:33 AM.
