Old 06-28-2013, 06:22 PM   #1
happyclam OP
happyclam's Avatar
Oddometer: 163
need m12x380mm hex bolt
Tried searching on the web, with no luck. It's a long engine bolt I need to extend to accomadate crash bars for a wee strom? Any Help appreciated. Thanks, Jeff.
happyclam screwed with this post 07-08-2013 at 05:50 PM Reason: ordered 400mm from metric tool
happyclam is offline   Reply With Quote
Old 06-28-2013, 06:59 PM   #2
CRASHDADDY
Oddometer: 22
m12x320 bolt
For something that long i would consider buying a piece of threaded rod, cut it to length and put a nut on each end. McMaster-Carr sells a GRADE B7, by the meter, this is good quality chrome-moly with a high tensile strength. This is NOT the soft crap they sell in the hardware store. The other option is to get a machinist to thread both ends of a piece of 12mm rod cut to your desired length. That is the route i would go and i would use some material with a good tensile strength.
CRASHDADDY is offline   Reply With Quote
Old 06-29-2013, 04:57 AM   #3
happyclam OP
happyclam's Avatar
Oddometer: 163
thanks crashdaddy, I'll check it out...
Old 06-29-2013, 05:45 AM   #4
beemerphile
beemerphile's Avatar
Oddometer: 1,913
I wonder if the rear mounting stud for a BMW airhead bike would be the same. I remember them as 12mm x 327 but I am often mistaken. If so, they are usually available cheaply from dismantlers.
ΜOΛΩΝ ΛΑΒΕ - Lee
Unreconstructed Southerner living in Occupied Georgia
beemerphile is offline   Reply With Quote
Old 06-29-2013, 07:14 AM   #5
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,415
http://www.metricscrew-toolco.com/
Old 06-29-2013, 08:06 AM   #6
Yamarocket630
Honey Badger
Yamarocket630's Avatar
Oddometer: 567
With a fastener that long just make sure it won't experience side or shearing loads. If so i would go with a larger diameter.
Yamarocket630 is offline   Reply With Quote
Old 06-29-2013, 09:20 AM   #7
Skippii
Hookers, my lad.
Skippii's Avatar
Oddometer: 6,505
Maybe some motorcycle axles might fit?
"Umm be careful what you say, this is Skippii....
You may get it delivered in the form of a shake or some interperative dance routine that involves nakedness, pizza and a stuffed raccoon..." -DCrider
Skippii is offline   Reply With Quote
Old 06-29-2013, 08:19 PM   #8
happyclam OP
happyclam's Avatar
Oddometer: 163
Originally Posted by concours View Post
Checked the web site, nothing that long...But i have 3 companies to call on monday...the search continues. I also need other hardware, i think, might come easier....or maybe i'lll just sell the bars as is and buy some new ones and go ride.. Thanks for the pointers everybody. My mistake the bolt nedds to be 380mm, sorry typo error in the late night...
happyclam screwed with this post 06-29-2013 at 08:31 PM
Old 06-29-2013, 09:17 PM   #9
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,317
These guys have a 400mm bolt:
http://shop.schaefer-peters.com/DIN-931-A2-M-12X400
Unfortunately they are in Germany but maybe they have an American distributor.
GreaseMonkey is offline   Reply With Quote
Old 06-29-2013, 09:21 PM   #10
GreaseMonkey
Preshrunk & Cottony
Oddometer: 5,317
If threaded rod would work, a meter of it is $7:
http://www.zorotools.com/g/00093447/k-G3691992?utm_source=google_shopping&utm_medium=cpc&utm_campaign=Google_Shopping_Feed&kw={keyword}&gclid=CKn7utT2irgCFRSVMgodEg8AYQ
Edited to add that Crashdaddy already found a higher grade threaded rod.
Old 06-30-2013, 04:23 AM   #11
JonnyCash
turd polisher
Oddometer: 1,603
I have a bunch of BMW engine mount bolts. I'll measure one up, and let you know.
Edit: I found it. It is 327mm long, with about 20mm of threads on each end. If you'll send me $5 for shipping, I'll send it your way.
I wouldn't bring her home to Mama, but Mama ain't home tonight.
JonnyCash screwed with this post 06-30-2013 at 04:32 AM
JonnyCash is offline   Reply With Quote
Old 06-30-2013, 08:27 AM   #12
rufus
We're burning daylight...
rufus's Avatar
Oddometer: 4,223
Originally Posted by GreaseMonkey View Post
If threaded rod would work, ..........
I absolutely would NOT EVER use threaded rod as a motor mount bolt.
rufus is offline   Reply With Quote
Old 06-30-2013, 08:57 AM   #13
GreaseMonkey
Preshrunk & Cottony
Oddometer: 5,317
"absolutely would NOT EVER" is a pretty broad term.
Old 06-30-2013, 01:22 PM   #14
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 1,469
A quick google showed this:
http://www.jackssmallengines.com/Par...366/2918777/pd
Calling Jack's small engine would be prudent before ordering. The other option is getting some M12 rod and making a stud by threading each end. Knowing the thread pitch is needed before making a 320mm long stud. Good luck!
Stan_R80/7 is offline   Reply With Quote
Old 06-30-2013, 02:57 PM   #15
happyclam OP
happyclam's Avatar
Oddometer: 163
I would but i need 380mm long, i had typed wrong the 1st time at 320mm. Thanks anyway. I think the rod is the way to go. I'll make some calls tomorrow to see whats available..Thanks again everybody.
Times are GMT -7.   It's 11:40 PM.
