Old 06-28-2013, 06:36 PM   #1
haggis mctavish OP
Oddometer: 21
going in too hot
I am a hacker with Suzuki vl1500 heavy hack on the left, standard forks, with about 20k klms experience . being of advanced years I ride in a conservative nature however I can fly the chair in a parking lot and know when the chair is lifting.
however
I gave myself a big fright recently when I tried to attack a twisty road with a bit more enthusiasm than usual. A long sweeping left hander doing about 100 ks when I realized the bend was tightening on me more than I realized. my memory of my reaction is as follows
hard on the brakes to reduce speed however realized I was not going to make the bend and focused on a tree in the scrub where I estimated I would end up.by this time I was on the incorrect side of the road and would be dead meat should an oncoming vehicle arrive.
decided on one last effort, off the brakes all my strength into hard left on the bars we avoided the scrub just managed to stay on the road and with good fortune rather than good management managed to return to the correct side of the road unscathed
I would appreciate advice on the following
at no time did I think that tightening my line and flying the chair was an option . was it an option for me
I got off the brakes before my final steering input as it made turning the bars left easier. is this correct or should I have continued braking whilst steering
any other thoughts on my initial mistake and subsequent recovery
I have come to the conclusion that riding a hack at anything close to the limit is far more demanding than riding a solo to the same limits.
I have now returned to my sedate riding style but will be interested on members thoughts on my close call
haggis mctavish is offline   Reply With Quote
Old 06-28-2013, 06:50 PM   #2
madeouttaglass
The AntiHarley
madeouttaglass's Avatar
Oddometer: 3,623
Hi Haggis, Welcome to ADV. I have roughly the same amount of hack miles under me. Although mine is on the other side, I've found a method that has worked well for me. If I feel a bit too hot turning to the right (Where my hack is) I concentrate on the line I want the hack wheel to follow. This might not work for others but for me it is the right kind of "target fixation". It takes my mind off all the other things going on including possible oncoming traffic. This idea occurred to me when I was playing with my Gear Up in the Smokie Mountains and the Tail of the Dragon at Deal's Gap. I feel it made me faster and smoother.
Our ride across the USA on a Ural Gear Up- http://www.advrider.com/forums/showthread.php?t=781149
Escape from NY- http://advrider.com/forums/showthread.php?t=955520
madeouttaglass is offline   Reply With Quote
Old 06-28-2013, 08:08 PM   #3
cleatusj
Dirt floor engineer
cleatusj's Avatar
Oddometer: 1,234
I've found that extra throttle will squat the drive tire more and help keep from flying too high, but afterwards I need to remove the seat cover from the neither regions.
In the stable now. '76 Moto Guzzi Convert Hack
'93 Moto Guzzi Calli 3 with Leaner turned rigid
'99 WR400F
Hack build: http://www.advrider.com/forums/showt...rt+floor+build
cleatusj is offline   Reply With Quote
Old 06-28-2013, 08:48 PM   #4
SwampFox883R
SwampFox883R's Avatar
Oddometer: 379
A technique to help keep the 3rd wheel down when turning towards the sidecar is to:
1) shift you weight inside the "triangle" -- load the inside foot peg; and
2) apply a little front brake while maintaining throttle -- in more extreme riding, you can make to back tire slip a little to bring the rig around the turn.
Both are necessary when riding my Sporster rig w/empty chair at even a slightly spirited pace.
Lee - Maddie's Chauffer
KLX250S + TW200
R1100GS w/CSM Sidecar
AN650 Burgman w/Texas Sidecar <Mrs. SwampFox's
SwampFox883R screwed with this post 06-29-2013 at 07:41 PM
SwampFox883R is offline   Reply With Quote
Old 06-29-2013, 03:31 AM   #5
cleatusj
Dirt floor engineer
cleatusj's Avatar
Oddometer: 1,234
Lee, I think you explained it better, I.E.[in more extreme riding, slip the tire, by applying throttle to break drive tire loose.]
'99 WR400F
Old 06-29-2013, 06:20 AM   #6
Wolfgang55
Wolfgang55's Avatar
Oddometer: 3,527
In Motion
Originally Posted by SwampFox883R View Post
A technique to help keep the 3rd wheel down is to:
1) shift you weight inside the "triangle" -- load the inside foot peg; and 2) apply front break while maintaining throttle -- in more extreme riding, you can make to back tire slip a little to bring the rig around the turn.
I think this is the best & simplest expression of what to do. At least for me too. This works for me so well. The fast transfer of drivers weight has been my main helping factor. I can feel the rear tire slip or shift to a better ''line''.
But usually I always shift my weight now, even if I don't need the extra stability.
Reason here is that I want to stay in the habit of riding ''in motion''. Meaning I am actively adjusting my weight left & right.
I also ask my passenger(s) to join in the riding experience by anticipating our turns. Most catch on right away & tell be later their experience as a passenger is a lot more fun than just sitting there.
Would like to add, Carson our first choice ''monkey'', a Labrador, really gets into the leaning.
Wolfgang55 is offline   Reply With Quote
Old 06-29-2013, 01:22 PM   #7
Tarka
Doesn't wave back.
Tarka's Avatar
Oddometer: 2,089
You were lucky there.
Target fixation is the major factor in most of the single vehicle bike crashes, such as your sunny day crotch rocket riders going across bends and through walls,into trees or free falling off bridges on corners into the valley below.
You were fixated on tree and had decided you weren`t going to make the bend...hence you were heading for the tree...as you generally go where you`re looking.
I,like most combo riders,have been in similar situations where I`ve found myself going in too hot...usually in a sequence of regular bends where one is suddenly tighter and I failed to observe the harsher 'vanishing point' of the hedges/trees/walls which give you a visual indication of the sharper bend if it wasn`t clearly visible any other way.
In these instances I`d definitely not grab or bias the front brake as has been suggested above,because that could cause the front end to tuck in and maybe lead to lifting the rear and flipping the combo....you definitely don`t want that to happen.
By all means close the throttle and brake as hard as you can on the approach,getting off the front while ultimately biasing the rear...then stop braking and get back on the throttle while focusing on the true exit point of the bend.
You`ll get round just fine...okay,the chair may well lift,but just keep the throttle smoothly opening and even if you ride it round on two wheels you`ll make it.
Been there...done it...due to a nasty negative camber left hand bend (remember folks,UK sided combo) midway through a set of regular ones while riding one of my Urals 3-up with loads of camping gear and the bastard still lifted the chair....but we made it okay.
Braking in the bend and especially hitting the front could well be a killer.
I'd only waste my money if I didn`t spend it on all my bikes......
Tarka is offline   Reply With Quote
Old 06-29-2013, 02:21 PM   #8
Mechanista
manic depressive
Mechanista's Avatar
Oddometer: 463
I think they call it "trail braking", what was described above. It does help a little, (unless it is in the liquor store parking lot).
I have also noticed that when coming into a corner "too hot" that the steering does get easier while flying the car, and that it is not the end of the line as far as controllability goes. It is sometimes hard to convince myself that I'm not going to crash at that point.
My wife knew I was this way before she even married me!
Mechanista is offline   Reply With Quote
Old 07-01-2013, 09:22 AM   #9
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 4,090
The steering gets easier when flying the car in a tight turn? That's gotta be something that's not the same for all rigs. If I fly the car in a tight right (my car is on the right), the rig immediately goes straight. I can't control the bars. And I'm a big guy with fairly powerful build and strong hands. Of course, going straight in a tight right means you are gonna go over the left shoulder pretty quick unless you get the car back down and regain control. DAMHIK. But that's on my rig. As a result, I do everything I can to keep the car down.
WUMPA
Sidecardogs.com
DRONE is offline   Reply With Quote
Old 07-01-2013, 01:00 PM   #10
Old Mule
Old Mule's Avatar
Oddometer: 441
hot corners
Sounds like your outfit has soft modern suspension, plenty of ground clearance?
Weight transfer can be disconcerting when you got in too hot...
A street outfit with limited fork and shock travel and very small sidecar suspension behaves pretty well in that situation...
Getting on the throttle hard in those turns toward the chair works pretty well, if the outfit doesn't lurch around too much...
I only wish my outfit had enough horsepower to break the rear tire loose on dry pavement!
Sure is interesting to read others' ideas about fast sidecar driving.
Old Mule is offline   Reply With Quote
Old 07-01-2013, 04:27 PM   #11
claude
Sidecar Jockey
Oddometer: 3,978
It is always good to try and increase one's personal skill envelope. How? Practice in a safe place a little above your personal comfort zone. This type of thing is an act of doing ourselves and possibly our loved ones a favor. It is important for all of us to try and get to know how our outfit will react under various conditions and how we can possibly ramp up our skill levels a little at a time.
Claude
http://freedomsidecars.com/
Old 07-01-2013, 04:31 PM   #12
claude
Sidecar Jockey
Oddometer: 3,978
Hello Drone. Try going around in a circle and either keep increasing your speed or possibly better yet keep making the circle smaller and smaller. When the sidecar comes up just keep on doing what you were doing . Over correcting when a sidecar comes off the ground will make the rig go straight and can be a disaster.
Claude
Old 07-01-2013, 05:09 PM   #13
tripodtiger
I used to be SCRay
tripodtiger's Avatar
Oddometer: 4,733
Originally Posted by claude View Post
practice in a safe place
+1
rayb Crash Dummy (no testing involved)
Old 07-01-2013, 07:13 PM   #14
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 4,090
Tried. Can't do it. Soon as the wheel lifts off I go straight. I can balance it straight but can't get it to turn right. I can yank hard on the bars and get it to wobble a little, but that's it. Maybe it's not my rig--maybe it's me. Bad right knee and difficult to transfer much weight to the right peg -- even when hanging off I can't press down hard.
Now that I think about it, I couldn't do it with one of Vernon's lightweight rigs when I took his class. I could fly straight and left, but not right. So I guess maybe it's me and my knee.
Anybody else have the same problem?
WUMPA
Sidecardogs.com
Old 07-02-2013, 07:13 AM   #15
claude
Sidecar Jockey
Oddometer: 3,978
Drone....Try it slow in a small circle without hanging off. Your knee may be bad but that should not be the issue. I have seen a friend with no right leg do it...so?
The only reason I am saying this to you is that IF you were to get into a situation where the sidecar came up in a right turn with no notice (hitting a road kill, rock or log in road, too much speed for a decreasing radius turn or whatever) you DO NOT want to go straight. Going straight can lead to evil things on the other side of the centerline.
As far as hanging off goes it is not a bad thing but basically all you are doing is transferring a little more weight to the sidecar side. No magic here at all. Everything that a sidecar outfit will do it will still do just at a possibly higher speed. If you can put a scale under each wheel and measure wheel weights in various seating positions you can see just how much weight does transfer when you hang off.
One possible negative to hanging off on some rigs for some people is that the reach to the left handlebar grip is too far for some in a tight turn. Also it is important to be aware that turning the bars can result in throttle position changes due to the right hand motion. Those who have the flat type wrist rests need to be very aware of this in left or right turns. They can be dangerous...sorry to drift off topic here.
Claude
claude screwed with this post 07-02-2013 at 07:21 AM
Times are GMT -7.   It's 01:32 PM.
