Old 07-08-2013, 08:37 AM   #61
claude
Sidecar Jockey
Oddometer: 3,596
Originally Posted by DirtyDR View Post
.... I was going along 44 through Lasson National Park and I went to pass a car and because the camber on the oncoming lane was so dramatic when I got into the oncoming lane I thought I was going to roll the rig. Really did not expect that and that was on a straight section of road not a turn.
Good point Dana. That type of thing can be alarming to newbies and veterans alike if not prepared for it. Even on an interstate highway cambers can change. Some are cambered toward the center median strip. This can create an unexpected thrill at speed especially when you pull out to pass a tractor trailer and have that wind blast hit you at the same time the camber changes.
We always bring this up when a new sidecarist goes through our limited training here at the shop.
Claude
http://freedomsidecars.com/
Old 07-08-2013, 11:46 AM   #62
davebig
Another Angry Hun !
davebig's Avatar
Oddometer: 3,205
I already learned that one gentlemen, in WI the majority of secondary roads are paved ( lots of huge milk trucks) but that doesn't mean they are level or even and often send one off and multiple directions.DB
Patience: A minor form of despair disguised as a virture.
Ambrose Bierce
davebig is offline   Reply With Quote
Old 07-08-2013, 09:23 PM   #63
SwampFox883R
SwampFox883R's Avatar
Oddometer: 362
.... If one does decide to hang off in a turn toward the sidecar it really should be done when entering a turn and not while in it. Depending on the situation a sudden 'butt off the seat' hang off can actually make things worse because the rider may be pushing away from the bike. If the sidecar is already in the air and the rider is attempting to 'save it' the 'push off ' from the bike can be counter productive....
This has happened to me when trying to hang off too late into a turn into the sidecar. Rather than transferring weight inside, I ended up "pushing off" of the outside peg, effectively transferring weight to the outside footpeg. It was ugly -- but thankfully it was while practicing an evasive swerve in an open parking lot. I still have difficulty completing a left/right swerve (sidecar on right side).
Lee - Maddie's Chauffer
KLX250S + TW200
R1100GS w/CSM Sidecar
AN650 Burgman w/Texas Sidecar <Mrs. SwampFox's
SwampFox883R is offline   Reply With Quote
Old 07-09-2013, 03:49 AM   #64
haggis mctavish OP
Oddometer: 19
thanks claude
you have cleared up 2 things for me
flying the chair is not the same as lifting the hack wheel whilst cornering
weight redistribution at least for the rider is over rated
this is especially so for left handed hacks where the danger is that you
lose proper control of the throttle front and rear brake whilst trying to move your weight around
haggis mctavish is offline   Reply With Quote
Old 07-09-2013, 06:51 AM   #65
claude
Sidecar Jockey
Oddometer: 3,596
A good experiment to show this is to have someone lift your sidecar wheel to a balance point while you are in the saddle. Then do your hang your butt off maneuver and see what happens. If done wrong the person holding up the sidecar wheel will have to keep it down...with some practice it is possible to make your move so he will have to hold it up harder. Still 'iffy' either way but this exercise will help to show the effects of a hang off that is done wrong and too late. Some practice will possibly help one to get used to how hanging off too late affects their outfit and how much. The reason I said the word 'iffy' above is that static experiments as described do not reflect the effects of cornering forces that are in action when at speed in a real cornering situation. Centrifugal force is a huge issue that can't be duplicated doing what is described above on a garage floor.
Claude
claude screwed with this post 07-09-2013 at 07:15 AM
Old 07-09-2013, 07:04 AM   #66
claude
Sidecar Jockey
Oddometer: 3,596
Originally Posted by haggis mctavish View Post
thanks claude
Throttle control is always something that is very important. Left mount or right mount.
Wrist rests (those flat things that have a curled end that fit around the throttle grip) can be an issue if hit during a tight turn. Myron, A good friend and fairly experienced sidecarist took a ride through a cornfield a couple of years ago due to the wrist rest being hit by mistake in a 90 degree leftie. (Right side mounted chair). It was simply due to his hand hitting the wrist rest when he turned and throttled up...the throttling up was far too much and off he went. It is funny how things go into slow motion when reactions are called upon. This comes from experience and practice. You mind is calling upon your skill reserve. Hopefully you get and answer...lol. If you don't you freeze at the helm and are at the mercy of the dynamics that got you into that place to begin with the outcome being what it is. Myron had a split second choice to try and save it and risk going over a fairly high bank sideways or to drive over the bank straight. He chose the latter, caught some air and played corn picker for about 20 yards. If he would have went over the bank sideways no doubt it would have been ugly. Myron, in the situation he was in, made the right choice.
Claude
claude screwed with this post 07-09-2013 at 07:18 AM
Old 07-09-2013, 07:29 AM   #67
kailuasurfer
Dreamer
kailuasurfer's Avatar
Oddometer: 363
Claude, as you already know, I am a firm believer in "hanging off" to shift weight in the "right" direction. Since my Watsonian rig is so light, I have practiced and learned to use the throttle and the front brake while I am practically sitting in the sidecar.
(Besides, my butt happens to be the heaviest part of my body .)
kailuasurfer is offline   Reply With Quote
Old 07-09-2013, 07:32 AM   #68
claude
Sidecar Jockey
Oddometer: 3,596
I am Not opposed to hanging off. It is just another technique that as you know shifts a little weight to the inside of the turn.
Claude
Old 07-09-2013, 10:38 AM   #69
claude
Sidecar Jockey
Oddometer: 3,596
Kailuasurfer mentioned using the throttle and the front brake in a turn above. Excellent technique. Linked braking systems will react differently but the idea still works to a point. The idea isn't true drifting but it is close to it. Every tire is built to have what they call a 'slip angle' designed into it. The slip angle is basically the difference between where the wheel is pointing and how much it is out of line with the contact patch in a turn. In a stationary position the contact patch would be 90 degrees to where the wheel is pointing. In other words the tire 'squirms ' as cornering forces are applied to it. This is a good thing as it allows much more forgiveness when cornering hard than you would otherwise have. No slip angle would mean that all traction would be provided just by the rubber compound and the tread design itself. Once that was overcome the vehicle would lose traction.
When applying the front brake and throttle at the same time the slip angle of the rear tire in increased. The throttle makes you move forward and the front brake is trying to hold you back. This allows faster cornering speeds and does seem to keep the sidecar down in turns toward the sidecar. It takes some practice an dis a semi advanced technique but does work quite well.
A step up from this is true drifting. This is cornering with the rear tire actually not totally connected with the road surface in right handers. To do it properly you need enough power to break the rear tire loose and keep it from hooking up as that can cause issues.
If you practice the first 'non true drifting' technique you can do so safely and see how it works pretty quickly.
TRUE DRIFTING CAN GET YOU IN TROUBLE. It is ,however, quite a thrill coming out of a turn and contemplating when to let go of the front brake and let the rear tire regain it's traction. When it doe sit is kinda like being shot out a cannon. :-)
Claude
Old 07-09-2013, 12:27 PM   #70
claude
Sidecar Jockey
Oddometer: 3,596
A MORNING CHALLANGE
Rig is feeling good...the setup must be pretty close as the machine is just
seeming to cruise with little or no effort. Man and machine are in that
special 'sweet spot' that all sidecarist yearn for.
The twisties loom ahead in a never ending undulation of pavement surrounded
by some of the most beautiful scenery east of the Mississippi. It is early
on the Parkway and the never ending expose' of beautiful vistas pass by on
either side. A good time to get in some spirited sidecarring before the
road becomes choked with motorhomes and trailers of a multitude of wide
eyed tourists.
Anticipation grows in proportion with the rising tach needle. Faster and
faster as more petrol is fed into the powerful engine. Rider concetrating
on being smooth ...feeling the weight of the rig rise and fall on it's
suspension as it moves from left to right to straight and repeats.
Slipping into right handers while maintaining as much speed as dared and
then powering out while the sidecar wheel hovers slightly above the
pavement....the rear tire protesting as it searches for traction. Mind is
racing as endorphins are activated yet the vision of what is unfolding
seems to be in slow motion. The dynamics of the outfit speak to the
subconsious in a never ending diatribe of input. The man and machine are
constantlly talking to one another as old friends. Some thoughts are
retained and some rejected...the machine and rider are one and pushing the
envelope in a neverending quest for the perfect turn.
Down the straight stretch with left hander fastly aproaching , tucked in
behind windscreen in an aerodynamic position but moreso to ward off the
chill of the crisp morning air. Quicker and quicker the turn aproaches until
at the last moment the throttle is released and a lower gear is found in one
fluid motion. Front tire wants to slide but then the rear of the outfit
breaks loose as the the right handgrip is twisted to the stop. The strained
throttle cable's intergity being put to the test. Steering to the right
while going left with the rear tire of the machine singing a song of protest
as rubber is deposited on the Virgin Tarmac.
Thoughts race through the rider's mind...some from experiences past and
some from fear of the unknown. 'Will the rear wheel stay down?' Hope so
....lean left as centrifigul force attempts to push the rider off the seat.
Out of the turn and almost immediately into a sharp right hand hairpin...too
much speed ! Chair lifts going in .... lower gear is found and again the
right grip is twisted to the max...rear tire breaks loose on the dew covered
road surface and chair settles down as forward motion begins to be shared by
a sideways protest of varied forces working against and with one another.
Riders heart is racing with the hope that the rear tire will not regain
traction just yet...front brake is feathered.. then while steering
correctively the front tire begins to drift as well...rider smiles with a
fearfull satisfaction as he knows he is experiencing an area that few
sidecarists venture into. A true three wheel drift in a right hander...more
power is wished for but none can be found. The machine begins to hook up.
Fear plays it's game with the riders ... a tipover seems eminant but just in
time the sidecar lazily lifts as the final stages of the hairpin are
realized. Front brake is totally released and the machine, triumphantly ,
rockets out onto the straight stretch with the sidecar wheel giving a faint
chirp as it comes back to earth.. Rider smiles within the confines of his
helmet as he knows he has explored and counquered the fringe of control one
more time.
Road straightens out and speed is slowed as the machine enters the welcome
haven of a rest area. Engine is shut off and rider dismounts still vibrating
from within as his mind reflects on the experiences that just took place.
The rig rests silently except for the tick ticking cooling down sounds a
machine makes. The rider leans against the stone fence and admiringly stares
at his rig.
There is a common bond between this man and machine that is too sacred to
be described by mere words. A faint smile can be seen on the rider's face
and it seems as though the machine is smiling too.
A shaky gloved hand struggles to light a cigarette. The thermos is called
for and reveals it's contents of cold java to a parched mouth.
From a distant curve a car is heard approaching. Then slowly out of the
early morning mist appears one of Virginia's finest in all his glory. He
slows and waves on his mission to serve and protect. The rider smiles and
returns the greeting.
Life is good.
Claude
Old 07-09-2013, 03:02 PM   #71
DirtyDR
Dana
DirtyDR's Avatar
Oddometer: 2,379
Wink
Waxing all poetic on us there Claude?
Going to have to save that one and make a poster out of it.
06 Ural Patrol
03 R1150 GS Sport/ Friendship II
94 R1100RS
99 Rokon Ranger
71 Rokon RT140
Hack'n the TLH
http://www.advrider.com/forums/showthread.php?t=592860
http://dirtydr.smugmug.com/
Proud Member of the Patrol Patrol
DirtyDR is offline   Reply With Quote
Old 07-09-2013, 10:09 PM   #72
cleatusj
Dirt floor engineer
cleatusj's Avatar
Oddometer: 1,124
Thank's Claude, that says it all and even lets one feel the experience.
In the stable now. '76 Moto Guzzi Convert Hack
'93 Moto Guzzi Calli 3 with Leaner turned rigid
Hack build: http://www.advrider.com/forums/showt...rt+floor+build
cleatusj is offline   Reply With Quote
Old 07-10-2013, 10:03 AM   #73
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,646
Never thought about that. I use a wrist rest. I wonder if that has happened to me and I didn't realize it? On my next trip (two weeks from now) I'm gonna try rotating that thing out of the way when I'm in the twisties.
WUMPA
Sidecardogs.com
DRONE is offline   Reply With Quote
Old 07-14-2013, 07:12 PM   #74
davebig
Another Angry Hun !
davebig's Avatar
Oddometer: 3,205
I'm catching on I think
Ok long timers Dana and Claude so rights are actually easier than lefts,if you use the rigs tendency to pull right and try and pass the sidecar when going right. It takes allot less energy and seems easiest way to drive one "so simple it plumb evaded me"
Ok so going left obviously one closes the throttle and the rig wants to drift or turn left , not as handy or as easy as the right.What will increase that effect ? I should have tried a loose hand and a little rear brake, I did manage to point it several places I didn't want it to go and closed throttle it headed left but something more subtle would be handier.
Left to my own devices I'd complicate it 2 foils or wings like the Can-Am cars of years gone by one each car and tug tip them individually as the turn required .LOLOLOL DB
http://speedreaders.info/303-can_am_cars_in_detail_by_p_lyons_aamp_p_r"]http://http://speedreaders.info/303-can_am_..._lyons_aamp_p_r[/URL]
Ambrose Bierce
davebig screwed with this post 07-15-2013 at 08:30 AM
Old 07-15-2013, 08:20 AM   #75
DirtyDR
Dana
DirtyDR's Avatar
Oddometer: 2,379
Rear brake is not a bad thing on left handers but be very careful with the front. Going straight down the road and just hitting the front brake will make the sidecar nose dive on mine. I also have the GS Sport though which is a non ABS bike. I wonder what the hack nose does on an ABS bike?
06 Ural Patrol
94 R1100RS
99 Rokon Ranger
71 Rokon RT140
Hack'n the TLH
Times are GMT -7.   It's 01:46 PM.
