Thread Tools Search this Thread Rating: Thread Rating: 14 votes, 5.00 average. Display Modes
Old 07-06-2013, 05:29 PM   #76
MasterMarine
Oddometer: 1,585
I did. I tried importing another file that I had imported previously and it did the same thing.
I tried updating Basecamp and it says there are not any available updates. It is 4.2.1.
It is weird. It did not used to act in this way.
MasterMarine is offline   Reply With Quote
Old 07-06-2013, 05:35 PM   #77
DRTBYK OP
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,763
That is a bit strange. But, you can reinstall v4.2.1 just download it from here.
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is offline   Reply With Quote
Old 07-06-2013, 05:52 PM   #78
MasterMarine
Oddometer: 1,585
I found on the Garmin Basecamp forum where someone else had reported the same issue and the response was that they know about it and are working to fix the issue.
Old 07-06-2013, 05:54 PM   #79
DRTBYK OP
DRTBYK's Avatar
Oddometer: 5,763
Excellent!
Cheers,
Dan
All Things GPS
Old 07-06-2013, 08:04 PM   #80
kingbee
Oddometer: 177
Hope this is the right place for this question. Just installed 4.2.1 on a windows machine. I use tracks, and previously I could select and open multiple tracks and the properties tab would read the total mileage of all selected tracks. With this version it only gives information (mileage, number of points) to one track at a time. Any ideas?
Cheers,
Dave
1999 DR350SE- Mine
1992 XT225- Queenbee's
2007 CRF150F- Princessbee's
kingbee is offline   Reply With Quote
Old 07-06-2013, 08:13 PM   #81
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,666
Cheers,
Dave
Maybe if you combine them first?
Old 07-06-2013, 08:47 PM   #82
kingbee
Oddometer: 177
You mean join them into a single track? Could do that but I need to keep under 500 points per track for my 60CSX. So a full day's riding might consist of 3 or 4 tracks.
Cheers,
Dave
1999 DR350SE- Mine
Old 07-06-2013, 09:49 PM   #83
DRTBYK OP
DRTBYK's Avatar
Oddometer: 5,763
Cheers,
Dave
Select the Tracks you want the info for and then right-click and select OPEN. This will give you the info your are looking for.
Cheers,
Dan
All Things GPS
Old 07-07-2013, 05:09 AM   #84
kingbee
Oddometer: 177
That's how I did it previously, but in this version when I do that the window opens and tells me how many tracks I've selected, but the summary box under the properties tab just says zero points and zero distance.
However, if it works correctly on yours and other's then at least I know the feature is still there. Maybe a glitch with my install? I'll try reinstalling the program and see what happens.
Thanks much for the responses thus far.
Cheers,
Dave
1999 DR350SE- Mine
Old 07-07-2013, 08:53 AM   #85
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,595
Hmm how do you do it on the Mac, Get Info is greyed out and there's no Open selection.
Old 07-07-2013, 09:20 AM   #86
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,666
Same here; until I 'Join' the track, I can't get those attributes. Once the tracks are all in one file it's easy to see the info.
I am also using the Mac version.
Old 07-07-2013, 10:49 AM   #87
DRTBYK OP
DRTBYK's Avatar
Oddometer: 5,763
Currently, you don't. I know that this "enhanced" data view has been requested but it appears that it didn't make this release. How about going over to the Mac-BC Forum and making the request (again)
They just need to enable the Get Info for this same info:
Cheers,
Dan
All Things GPS
Old 07-07-2013, 11:40 AM   #88
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,666
It's fairly easy to get the information on the tracks by 'Joining' them, checking the information, the undoing the 'Join' through Edit, Undo.
Yes, it is a little cumbersome but it works.
Old 07-07-2013, 11:44 AM   #89
Dagwood_55
Dagwood_55's Avatar
Oddometer: 1,345
This has got to be simple, but I give up easily...
In Trip Planner, how do I set my "Home" to where I actually live
and start my trips from??
Live long, love much, laugh often, and
Ride, Ride, Ride.....
Dagwood_55 is offline   Reply With Quote
Old 07-07-2013, 12:02 PM   #90
DRTBYK OP
DRTBYK's Avatar
Oddometer: 5,763
Well, it works if you don't want valid milage and other data for your collective Tracks that may not be nose to tail.
(We don't want to give Garmin an easy way out - that still doesn't meet requirements.)
Cheers,
Dan
All Things GPS
Times are GMT -7.   It's 10:50 PM.
