Old 06-30-2013, 06:11 AM   #1
alongat OP
alongat's Avatar
Oddometer: 1,174
What sprocket sizes are stock on 990R
So I can tell by the part number that my bike came with a 16tooth front sprocket but when I look at the rear, I can't tell though I think I can almost see a "42" or"43" stamped on it. I've recently gone with the 19/17 wheel setup on my 2012 990 adventure R and obviously the geari g ratio has changed. Wile I appreciate the new found acceleration and wheeliness, I don't want to be spinning that high on highway crushing / longer runs and I was happy with the original gear ratio. To get it back to stock, I need to either reduce the rear sprocket tooth count by three or add one tooth up front but when I look at the front area, I'm not convinced that there is actually enough room for a 17 tooth sprocket given the chain,s current proximity to the slave cylinder, etc. can anyone confirm if there is in fact room to run a 17 tooth up front? It seems like the better choice compared to reducing the rear by three teeth. Bigger sprocket up front is easier on the chain and reduces drivetrain losses, right?
Thanks in advance
Toronto, Canada
KTM 1190 ADV, KTM 530 EXC
Gone: Ducati 999R, KTM 530EXC, KTM 990ADV-R, KTM 950ADV, KTM 690, KTM 640ADV, kTM RC8R, Ducati 996S, Yamaha R1
And how can this be? For he is the Kwisatz Haderach!
alongat is offline   Reply With Quote
Old 06-30-2013, 06:13 AM   #2
alongat OP
alongat's Avatar
Oddometer: 1,174
And I just counted the teeth on the back sprocket - 42 so my bike has a 16/42 setup.
Toronto, Canada
Old 06-30-2013, 07:06 AM   #3
laramie LC4
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,403
yup 16/42 is the stock ratio on the 990R. divide 42/16 = 2.625, 45/17 = 2.647, 45/15 = 3.0 and so on....the lower the number, the taller your gearing.
i have no idea how your smaller tires will affect/change the ratio but i'm sure a little google work will get you a formula.
laters,
laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Old 06-30-2013, 07:25 AM   #4
alongat OP
alongat's Avatar
Oddometer: 1,174
I've done the calculations - based on my new wheel/tire circumference, going with one tooth up in the front or three teeth down in the rear will get me extremely close to what I had before changing the wheels. I'm wondering if people are running 17 tooth front sprockets from a clearance standpoint.
Toronto, Canada
Old 06-30-2013, 07:36 AM   #5
rider911
rider911's Avatar
Oddometer: 483
All 990s used to come std with a 17T front sprocket. Im not sure what year they started putting 16T on.
I use 17/45 on my bike most of the time but if im doing a softer ride with some bemmers then I will use 17/42 to give it a few more legs.
New RR ~ Across OZ... Corner by Corner
08 KTM 300 exce (small)
12 KTM 500 exc (medium)
07 KTM 990 Adv (large)
rider911 is offline   Reply With Quote
Old 06-30-2013, 01:26 PM   #6
alongat OP
alongat's Avatar
Oddometer: 1,174
Ok, so it sounds like a 17 does fit. Now, does anyone have an opinion on whether or not to get a standard front sprocket or the KTM dampened sprocket like the one on it now? Can anyone actually feel any difference?
Toronto, Canada
Old 07-01-2013, 10:02 AM   #7
spafxer
spafxer's Avatar
Oddometer: 2,632
The 17 dampened sprocket fits for me, and I do not notice any noise difference from the un dampened sprocket.
I assume when they do noise tests with machines, the dampening must make a difference ! (of course they use stock mufflers too. Long gone for most of us!)
spafxer is offline   Reply With Quote
Old 07-01-2013, 01:20 PM   #8
Trail bandit
Random adventurer
Oddometer: 204
I like the legs on the 17/42. Note. It doesn't look like its going to fit. You've got to get it sitting just right then it just slips in place with no room to spare.
Rekluse clutch gives the best of both worlds. You can run good highway gearing and crawl speeds with no clutch use.
I'm up to 160 miles on a tank of gas. 1/3rd dirt trails and balance highway. Very interested when I go to fill up what the mpg is going to be. Low fuel just came on.
Trail bandit is offline   Reply With Quote
Old 07-01-2013, 01:54 PM   #9
woodchuckexc
Oddometer: 801
Why an "R" if you plan on riding street? It seems like such a waste to take a thorough bred offload beast and mount street wheels.
woodchuckexc is offline   Reply With Quote
Old 07-01-2013, 02:48 PM   #10
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,811
It's always been my understanding (I could be wrong, and often am) the dampened sprocket is meant to be gentler to the power train.
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Old 07-01-2013, 03:52 PM   #11
spafxer
spafxer's Avatar
Oddometer: 2,632
Originally Posted by FakeName View Post
It's always been my understanding the rear sprocket "cush drive" is meant to be gentler to the power train.
There, you are not wrong !
Old 07-01-2013, 08:35 PM   #12
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,298
spafxer has it right: Rear cush yes, but the rubber on the front sprocket dampens only noise. It does nothing to cushion the drive.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is offline   Reply With Quote
Old 07-01-2013, 11:17 PM   #13
keener
Speed changes you.
keener's Avatar
Oddometer: 932
And it dampens a lot of noise, the front sprocket that is... I tested this riding with engine off in natural. I compared two sprockets.
04 ADV 950
keener is offline   Reply With Quote
Old 07-01-2013, 11:21 PM   #14
keener
Speed changes you.
keener's Avatar
Oddometer: 932
Surprised no one has mentioned this here yet:
http://www.gearingcommander.com/
04 ADV 950
Old 07-02-2013, 06:51 AM   #15
MortimerSickle
Semi-Adventurer
Oddometer: 12,298
I guess I'm deafer than I had thought.
G.H.W.S. 1878-1962
Times are GMT -7.   It's 10:37 AM.
