Old 06-30-2013, 01:31 PM   #1
woolsocks OP
Oddometer: 232
Need help with turn signals
Went out for a ride yesterday with a friend that I was leading. She thought I was terrible at signalling and I was wondering why it took her so long to follow me through traffic...Anyway, turns out the rear signals weren't functioning.
I checked and the left side bulb shattered and the turn signal casing has started to melt. One of the wires has dislodged itself from the metal spring-loaded piece that holds the bulb. The right side bulb appears to be fine but the signal won't work. I also checked the fuses and all are fine on the bike. The front signals work fine and all other lights as well.
Anything I need to be concerned about? How do I rewire the left signal wires?
woolsocks is offline   Reply With Quote
Old 07-07-2013, 04:08 PM   #2
Kommando
Kommando's Avatar
Oddometer: 7,389
Just install new signals and be done with it. Rebuilding them is likely to cost just as much.
Kommando is offline   Reply With Quote
Times are GMT -7.   It's 12:45 PM.
