Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Old 07-01-2013, 08:04 AM   #1
Purcell69 OP
Mors ex Tenebris
Purcell69's Avatar
Location: Moving forward...at the speed of rust in mid-OK
Oddometer: 3,833
And so it begins...1957 Chevrolet, meet 1994 Dodge
Some of you out there will consider this sacrilege. Fine, you're entitled to your opinion. I've been considering what I am about to do for some time now and I am ready to move forward to the execution. About 20 years ago, I bought a fairly solid 1957 Chevrolet 3100 long bed, minus engine and transmission for a project vehicle. Over the years, I have tinkered with it, driven it a few times and enjoyed playing with it. I started out with an uncut frame and OEM suspension, did a disc brake and PS conversion. It was ok, but 1957 steering tech.
Later, I chopped the frame and went to a Camaro front clip. Once that was done, I ditched the carb and went to various forms of EFI, Crossfire injection and later a single TBI.
I've always had my eye on an old NAPCO 4wd set-up. I liked the all business attitude the truck conveyed, but it just isn't practical now. They ride rough and have gearing that will climb a brick wall, but...
My project is going to be mating the 1957 Chevy body to a 1994 Dodge Ram 1500 4wd chassis and running gear. Originally I was going to use the drivetrain out of a 1996 Jeep Cherokee in the Dodge chassis, but CG69 talked me into staying with the Dodge V8 over the 4.0 inline 6 and AW-4 automatic. I liked the idea of the Jeep motor for the appearance of the inline motor, as was standard in the '57. She convinced me that I would miss the power of the V8.
I chose the 1994-2001 Dodge chassis for the solid front axle and coil spring front end. The ride is far better than the leaf spring front suspension. I was also looking at the Dodge due to the front pinion location (when considering the Jeep drivetrain), which isn't an issue so much now.
Yesterday, I picked up a 1994 Dodge 1500 4wd long bed with a 360 V8. The motor is dead, but the rest is all good. $500 and a two hour drive to tow it home. I will need to shorten the frame to match my wheelbase, modify the rear driveshaft to match the frame. Make my cab mounts, etc. this is going to be fun. Pictures to follow.
-Joe
The Marines...When it absolutely, positively has to be destroyed overnight.
Trust and Respect take years to earn, but can be lost in a moment.
Life's too short to hold a grudge. -Joe
Purcell69 is offline   Reply With Quote
Old 07-01-2013, 09:38 AM   #2
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,317
Sounds interesting to me.
Jim
Old 07-01-2013, 09:46 AM   #3
ragtoplvr
Oddometer: 6,390
In my younger days we had a 460 ford in a 66 chevy (fordlet) a cadvrolet 500 caddy in a 80's chevy and a Dord. (440 in a beam axel ford) The Dord was the most scary. The cadvrolet was actually a very nice truck.
So a chrysolet or a dodolet makes perfect sense.
The driveshaft guy we used to use is long gone to his reward.
Rod
ragtoplvr is offline   Reply With Quote
Old 07-01-2013, 11:50 AM   #4
Purcell69 OP
Mors ex Tenebris
Purcell69's Avatar
Oddometer: 3,833
When I first started playing with this truck years ago in AZ, I had a neighbor who lived down the road who had swapped a 472 Cadillac motor into his '64 C-10. Granted that was GM to GM so other than the correct transmission bolt pattern, it was somewhat straight forward. Of course, gasoline was also about a buck twenty per gallon.
-Joe
Old 07-01-2013, 12:09 PM   #5
ragtoplvr
Oddometer: 6,390
Actually the Cadvrolet got much better mileage than you would expect. We took out a blown 5.7 diesel. It had the stock air cleaner with an extra snorkel grafted on, so cold or heated air as needed, dual exhaust, rejetted quadrajet, and recurved distributor, it would often get in the 17-18 MPG range unloaded, and 14 pulling a decent bass boat, lots of power to spare. The diesel before it blew was hard pressed to get 22 and with boat, kids on tricycles wanted to pass.
It sure was fun passing an the shiny new diesel trucks going down highway 65 to Branson in a older chevy with 5.7 diesel badges still on it. Some of trucks going up hill once I put in the 383.
Rod
ragtoplvr screwed with this post 07-01-2013 at 12:19 PM
Old 07-01-2013, 01:06 PM   #6
Purcell69 OP
Mors ex Tenebris
Purcell69's Avatar
Oddometer: 3,833
Rod
. I remember those 5.7 diesels. Dad got on the diesel band wagon back in '75 when we lived in Maryland. He traded in his Olds 442 on a Peugot 504 and brought in a fuel tank to put beside the house. He'd get the tank filled about once a year with #2 home heating oil to run in the car. That little diesel routinely got 38 mpg, so he figured that a diesel Olds had to be the best of both worlds, because Dad was an Olds guy. That car was slow and loud, but not much else. Surprisingly, he did get a speeding ticket in it once...driving down a 6% grade in New Mexico. He should have fought it. Nobody in their right mind would believe and Olds diesel could break 60 mph.
-Joe
Old 07-01-2013, 01:20 PM   #7
madeouttaglass
The AntiHarley
madeouttaglass's Avatar
Oddometer: 3,574
I'm all for it. You are not cutting up an unmolested vehicle, not to mention keeping a '57 on the road. Start posting the before pics!
Our ride across the USA on a Ural Gear Up- http://www.advrider.com/forums/showthread.php?t=781149
Escape from NY- http://advrider.com/forums/showthread.php?t=955520
madeouttaglass is offline   Reply With Quote
Old 07-01-2013, 03:19 PM   #8
Purcell69 OP
Mors ex Tenebris
Purcell69's Avatar
Oddometer: 3,833
Pictures will be coming soon. I am at work right now and it was too late to start taking the yesterday, between unloading my buddy's trailer and taking it back to his place. Patience my friends...
-Joe
Old 07-02-2013, 10:41 AM   #9
High Country Herb
Adventure Connoiseur
High Country Herb's Avatar
Oddometer: 9,068
Sounds like a great project.
I have seen some mixed breeds that turned out fine. My friend's 80 year old father runs a 4X4 pull truck (like at the county fair) that is a '51 Dodge pickup with a Ford 514 big block. It is barely streetable. It is seriously loud when he opens up the cut-outs for competition.
The other one is an early 50's Ford 2WD pickup with a heavily modified Cadillac motor.(He used to build Caddy motors for the Engine Masters build-offs.) I haven't seen the completed show quality truck since it got out of the hot rod shop, but I will get a really close look at it soon. The rear main seal is leaking, my friend and I will be providing some help to get it fixed.
2009 Aprilia Dorsoduro 750 (adventurized): http://www.apriliaforum.com/forums/a...893274&thumb=1
High Country Herb is offline   Reply With Quote
Old 07-02-2013, 11:48 AM   #10
troidus
Oddometer: 15,117
I don't know why no one ever put a turbo on those 5.7s. Maybe they did and I never heard about it. (Probably have to o-ring the block to keep the head gasket together, so maybe it was cost-prohibitive.)
troidus is offline   Reply With Quote
Old 07-02-2013, 12:47 PM   #11
Purcell69 OP
Mors ex Tenebris
Purcell69's Avatar
Oddometer: 3,833
I think the 5.7 diesels got such a bad rep that GM stopped right there with spending money on them. Most were lucky to make it to 50k miles before the nylon teeth on the timing gear gave out. GM went back to the drawing board and came up with the 6.2 and later the 6.5 turbo.
I had toyed with the idea of going diesel, a 4BT to be exact. The drawback is the noise and vibration. I could pretty well sound deaden the '57 cab, though there are metal to metal points of contact that were never meant for a diesel when this truck was built. Then there is all the small hardware that holds thing like the grille together. Literally hundreds of small screws and nuts needing Loctite of the highest order. As much as I love my Cummins trucks, I just felt there would be a lot of retro engineering to make a diesel a viable engine choice for this project.
For what I really want to do, enjoy driving something unique, the gas V8 will work. Early on, I had been in hot rod mode with this. An early hemi would have been cool, but the cost is beyond my budget. I did have a 454 in place at one point, but to enjoy driving this means not stopping for gas every 150-200 miles, so I started playing with a small block and EFI.
In addition to modifying the Dodge chassis to accept the Chevy body, I have a few patch panels that need to be installed and I am seriously considering adapting in more modern cab mounts for the body. 1957 tech was a rubber wafer about as thick as a heavy duty MC tube that sat between the body and frame at mounting points. As a result, almost every noise and vibe was transferred and amplified in the cab.
-Joe
Purcell69 screwed with this post 07-02-2013 at 12:58 PM
Old 07-02-2013, 03:32 PM   #12
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,335
I say good and cool! A 57 truck is worth no where near what a 1957 Belaire is so go for it. Now if you were gonna mate a Dodge truck to a 57 belAire 2 door, we would all collectively kick your ass. Or fell like it!
" The people who cast the votes decide nothing. The people who count the votes decide everything."
Straight Out Da Trailah!
Sniper X is offline   Reply With Quote
Old 07-03-2013, 04:09 AM   #13
ddavidv
Thrifty not cheap
ddavidv's Avatar
Oddometer: 1,178
That will certainly drive the Chevy fanbois insane, and that alone is reason enough to do it. Just be prepared for lots of moronic comments from Bowtie Believers.
'04 Wee Strom
'89 KLR 650 (sold)
I write books!
http://www.amazon.com/David-Wittling...ntt_dp_epwbk_0
ddavidv is online now   Reply With Quote
Old 07-03-2013, 06:24 AM   #14
JimVonBaden
"Cool" Aid!
Oddometer: 53,317
I'm nondemoninational, but you are obviously a "fanboi" of some denomination to hold so much disdain for others.
I haven't seen anyone act foolish about this until now!
Jim
Old 07-03-2013, 08:01 AM   #15
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,335
I have a 1974 3/4 ton Chevy C20 and have Dodge Wheels and hubcaps on it. You should hear the questions....I call it the Chodge.
Thread Tools
Times are GMT -7.   It's 02:50 AM.
