Old 07-01-2013, 07:35 PM   #1
ultrachrome OP
Poser
Oddometer: 274
Sealing brake bleeder threads
First time using a vacuum bleeder (harbor freight mity-vac style) on my SMT with ABS.
I found the recommendation for thread sealing after the fact. I just did the rear but so much air was being pulled through the threads that I had to pump the vacuum pump constantly. The fluid would just sputter through the tube. I couldn't judge its color so I stopped after about 2.5 oz.
Did I just introduce air into the system?
So I can use the normal white PTFE tape sold in the plumbing dept?
What's going to happen when I remove the bleeder screw to apply the tape? Much fluid loss? Should the reservoir cap be on or off?
ultrachrome is offline   Reply With Quote
Old 07-01-2013, 07:48 PM   #2
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,359
Not likely you added air. When it comes to using a vacuum bleeder you need to make sure the threads are clean, and barely crack open the bleeder to minimize pulling air past the threads so you can see how well you are doing. Personally I don't use a bleeder unless I have a bubble I can't force through with conventional bleeding.
I would not recommend any kind of tape on the threads.
Jim
Old 07-01-2013, 08:06 PM   #3
HapHazard
Waiting for Gudenov
HapHazard's Avatar
Oddometer: 2,311
The shade tree method is to pack grease around the bleeder threads.
I've used the Mity-Vac, but with pressure - bleeding clutches from below pushing fluid up to the master from the slave.
Worked great on my FJ1200, and on a Ford Ranger (it's impossible to bleed a Ranger clutch effectively any other way).
I had no problem with the threads when using pressure.
HapHazard is online now   Reply With Quote
Old 07-01-2013, 09:19 PM   #4
Motomantra
Registered Lurker
Motomantra's Avatar
Oddometer: 1,351
Brake bleeder screw works more like a needle/seat in a carb. The threads don't seal. The screw has a tapered seat that seals against the slave cyl.
If there was no air in the system before you started it's probably okay. I've bled lots of brakes with a vac bleeder with lots of bubbles coming out of the nipple. No problemo.
If you want to see what's coming out, use the coke bottle method. A clear bottle with a little fresh brake fluid in it. Be sure the drain hose stays submerged in the bottle of fluid & watch what comes out. Keep pumping until it runs clear.
For those that fight for it, freedom has a flavor the protected will never know.
Motomantra is offline   Reply With Quote
Old 07-01-2013, 09:40 PM   #5
Flashmo
Whatever...
Flashmo's Avatar
Oddometer: 2,617
Jim
this^
Flashmo is offline   Reply With Quote
Old 07-01-2013, 10:04 PM   #6
Bogfarth
MOTGATT on a Yamahog
Bogfarth's Avatar
Oddometer: 178
1) Teflon tape will seal the bleeder screw threads, but as Jim said, not recommended.
2) Barely squeeze the lever/pedal while applying vacuum at the just-cracked bleeder screw. Pressure from above and vacuum below tends to move things along nicely.
3) Doubtful you added air in the system.
Motion Pro 08-0143 Hydraulic Brake Bleeder : Amazon.com : Automotive
I'd never seen a gizmo like this before, bled brakes before, or swapped brake fluid before. Had the whole job done in 15 minutes with only a little drippage from the screw, and that was solved with a paper towel. An extra foot of 3/16" tubing comes in quite handy, though, as the included tubing isn't long enough to reach a container. Three pumps of the lever primed the unit and I was off to the races. Remember to check the master cylinder fluid level and top up as needed.
Christopher Robin was sitting outside his door, putting on his Big Boots.
As soon as he saw the Big Boots, Pooh knew that an Adventure was going to happen
Bogfarth is offline   Reply With Quote
Old 07-01-2013, 10:06 PM   #7
ultrachrome OP
Poser
Oddometer: 274
Jim
I tried opening from a little to a lot. At the smallest setting it just didn't pull very much fluid through before I lost nearly all the vacuum. I'll see how the brake feels tomorrow before attempting the fronts.
I should raise the catch bottle above the level the caliper as this should allow fluid accumulate in the hose.
Old 07-01-2013, 10:57 PM   #8
victor441
victor441's Avatar
Oddometer: 962
I ran into the same thing using a Mityvac, air is sucked in through the bleeder threads but then goes right back out the bleeder nipple...makes it impossible to visually tell when all the air is out of the system like when bleeding brakes the traditional way but it DID work when I ran enough fluid through, the brake pedal was high and firm...in my case I was working on a car w/ two master cylinders and a balance bar so the traditional method was useless. One trick I've read about is to use ATE blue brake fluid every other flush/bleed so you can tell when all the old fluid is gone but on most vehicles I've worked on the old fluid is dark enough with age that it is obvious when the new fluid is coming out the bleeder.
victor441 is offline   Reply With Quote
Old 07-02-2013, 04:23 AM   #9
rbrsddn
3banger
rbrsddn's Avatar
Oddometer: 2,698
I have Speed Bleeders on my bike, and along with a Mityvac, brake bleeding is a piece of cake. I use grease too.
http://www.speedbleeder.com/
rbrsddn is offline   Reply With Quote
Old 07-02-2013, 05:27 AM   #10
Railbender
Oddometer: 1,039
The thread sealer that Speed Bleeder uses is now available separately. http://www.google.com/#output=search...w=1440&bih=794 I've used it on 2 bikes and it seems to solve the problem.
The shortest distance between two points is boring.
Railbender is offline   Reply With Quote
Old 07-02-2013, 05:47 AM   #11
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,393
Jim
Curious why you make this statement?
In nearly 40 years of bleeding brakes, I've used tape, grease, pipe dope or nickel anti-seize when needed.
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Old 07-02-2013, 06:22 AM   #12
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,415
Vacuum bleeder sucks, pressure bleeder rocks. Had 'em both for years.
Old 07-02-2013, 06:46 AM   #13
JimVonBaden
"Cool" Aid!
Oddometer: 53,359
Using tape can allow some tape to get into the brake lines and block the very small valves. Pipe dope can do the same. Grease is likely going to desolve in the fluid, but I prefer pure brake fluid only in the system.
Jim
Old 07-02-2013, 08:11 AM   #14
ultrachrome OP
Poser
Oddometer: 274
Pressure bleeding is forcing the fluid in through the bleed screw? How would I keep fluid leaking out of the threads?
Old 07-02-2013, 09:14 AM   #15
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 14,052
Try reverse bleeding . . . . .force fluid (under pressure) from the bleed fitting up to the master cyclinder.
I use a syringe I copped at a farm & Fleet like place, designed for vets (no needle) . . . . pop the right sized tubing on the the business end, fill with fluid, put the tubing on the fitting, crack it, and push the fluid up.
Easy, cheap, and effective.
The looks on your buddie's faces when you pull the big honkin syringe outa your tool chest? priceless.
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance. T.R.
Times are GMT -7.   It's 01:30 PM.
