Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 08-02-2005, 05:44 AM   #1
RoyB OP
Dartmouth, Massacusetts
Oddometer: 1,578
how does a GPS measure distance?
over a long trip, how does a gps measure distance? point to point and then adding it all up or as the crow flies?
Roy B
Dartmouth, MA www.rvbprecision.com
2007 BMW K1200R Sport abs,2007 DL650 V Strom abs
2004 Honda VFR abs,2001 Moto Guzzi Rosso Mandello
1971 Honda Trail CT90
RoyB is offline   Reply With Quote
Old 08-02-2005, 05:48 AM   #2
Kaumajet
H.I.D. Positive
Kaumajet's Avatar
Oddometer: 10,137
Assuming you have an auto-routing GPS, or one that will navigate roadways - if you're in Automobile mode, the GPS will calculate the distance along a route determined by your criteria (shortest route, fastest route, avoid this or that). The distance it comes up with will be the actual distance along the roadway.
In marine or other modes, depending on the GPS, the distance wil be straight line, without slope correction.
"I understand the dilemma. Correct spelling takes time that could be spent licking the windows on the short bus." mac62
"There is just something special about a stripper with a tail" ilmostro
Kaumajet is offline   Reply With Quote
Old 08-02-2005, 07:46 AM   #3
Jabba
"HOLD THE LIGHT!!!"
Jabba's Avatar
Oddometer: 12,554
Huh- I was gonna go with "triangulation, knucklehead".
"Everybody loves cunnilingus!" Chacifer
"The road to paradise is paradise" Jacques Yves Cousteau
Jabba is offline   Reply With Quote
Old 08-02-2005, 09:05 AM   #4
reinerka
Oddometer: 350
A GPS will take a position every second (or 5 seconds for some older units) and then calculate the distance between the two measurements. For the trip odometer of the GPS it will simply add those distances up to compute the total miles (or kilometers) traveled.
The distance includes changes in altitude as well if you have enough satellites (3D Navigation).
If your GPS does have track logs (typically for back tracking a route) those will not match the odometer (in most cases) since they "smoothen" out the number of points and will come up with a more straightline approach. This will result in slightly smaller distance numbers. Found this when comparing a longer trip with lots of twisty roads and comparing the total of the GPS odometer with the individual track logs (differed by about 3% - still better than the bike odometer).
Reiner
'09 R1200GSA
'09 F800GS
'05 KLR650
reinerka is offline   Reply With Quote
Old 08-02-2005, 11:50 AM   #5
Infracaninophile
Finding My Way..
Infracaninophile's Avatar
Oddometer: 7,514
Geometry.
Edit: Now that I think about it, it must be Trig, not geometry. Math is hard.
T.
Infracaninophile screwed with this post 08-02-2005 at 04:15 PM
Infracaninophile is offline   Reply With Quote
Old 08-02-2005, 12:34 PM   #6
FatChance
Road Captain
FatChance's Avatar
Oddometer: 10,296
Math is hard.
Pain in the Butte Ranch
Durango, Colorado
- Calculated risk or forbidden fruit?
FatChance is offline   Reply With Quote
Old 08-02-2005, 05:26 PM   #7
jktpa
X-Troller
jktpa's Avatar
Oddometer: 784
By Fucking Magic
Knick
Low Tech-Hi Fun
F800GS
WR250R
ET4
jktpa is offline   Reply With Quote
Times are GMT -7.   It's 02:24 AM.
