Old 07-03-2013, 11:15 PM   #1
grumpyman OP
Oddometer: 84
640 adventure doing 50% commute ??
if i use this 640 adv to commute 50-60% of the time 12-18 miles am i going to be ok on motor wear as long as i let it warm up fully before taking off??
i take it out on longer rides when i can get some buds together but am i killing it with the commute into san francisco???? if this has been answered before please tell me to f%$k off but point to the appropriate thread if you can.
thanx
grumpyman is offline   Reply With Quote
Old 07-04-2013, 12:55 AM   #2
grumpyman OP
Oddometer: 84
or what else can i do to help??
any ideas???
i love this bike
Old 07-04-2013, 02:06 AM   #3
mountaincadre
Oddometer: 360
Let it warm up first, they don't take long(mine takes about 3 mins to get to 3 bars) if you do you shouldn't do any damage. There is a school of though as well that says stand it up right until at least until one bar is showing(again I do this and it takes less than a minute).
mountaincadre is offline   Reply With Quote
Old 07-04-2013, 04:54 AM   #4
2 SPOT
wannabe
2 SPOT's Avatar
Oddometer: 3,291
i would say F#&K off and ask if you would think the same about a klr or dr its an lc4 engine, its made to be used like that, dont worry bout it.
2 SPOT is offline   Reply With Quote
Old 07-04-2013, 06:21 AM   #5
mountaincadre
Oddometer: 360
No but that's because they're shite and I would expect them to break down.
que klr/lc4/dr/xt bunfight
Old 07-04-2013, 04:48 PM   #6
grumpyman OP
Oddometer: 84
i was told the same about my xr600
just let it warm up and went
Old 07-04-2013, 07:05 PM   #7
Sparrowhawk
Sparrowhawk's Avatar
Oddometer: 2,247
You have not gotten a very good response so far. Don't worry about warming it up unless you hop on the highway in the first 3 miles. Just start it and ride easy for the first few miles. Riding 18 miles or so each way gives the engine plenty of time to get to temperature.
The LC4 engine is not some kind of prissy race tool. It has the oil capacity and design for the long run. I have over 30, 000 miles on mine with only regular maintenance and the normal fixes (water pump, etc). It's never let me down and I expect another 20, 000 before I get into it in a big way. Don't worry and enjoy your bike.
Check out the 640 LC4 thread. Lots of good information there.
Cheers.
Sent from my SCH-I535 using Tapatalk 2
Sparrowhawk is offline   Reply With Quote
Old 07-04-2013, 07:20 PM   #8
Kawidad
Kawidad's Avatar
Oddometer: 4,919
Do you like your fillings?
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is online now   Reply With Quote
Old 07-04-2013, 10:57 PM   #9
grumpyman OP
Oddometer: 84
1 mile to 880
and then on to sf ca at 75+ w/ normal gearing so 5000 -5500 rpm
i usually let it warm up till i have to choke it down
i will just delay the helmet /glove ritual and wait another min or so
scored a set of held namibs off cjdesigns and love them
thanx for the replies i was not sure what i was going to get off such a mixed forum
Old 07-04-2013, 11:28 PM   #10
Sparrowhawk
Oddometer: 2,247
Assuming you are new. Go to the bike specific thread and select LC4 640. The mind trust is very deep here. Welcome to the Borg.
Old 07-05-2013, 04:21 AM   #11
Mat
Mat's Avatar
Oddometer: 1,189
Cheers.
Listen to the hawk. Just take it somewhat easy for the first few miles until it has been rolling a few minutes on 4 bars, and don't worry too much about the engine. I mistreat mine by commuting in Winter where it actually never gets completely warm, except on joy rides. It is still in top shape.
Hereabouts it is illegal to let cars or bikes just idle for nothing (for example to warm up), and that is a good thing. There is really no point for a halfway modern engine to be warmed up idling, except if you plan to blast off to redline right at the start. Life isn't a race most times. Plus it tends to piss off the neighbors, apart from the needless pollution.
I think there might be a more scenic route somewhere...
Mat is offline   Reply With Quote
Old 07-05-2013, 10:43 PM   #12
bmwktmbill
Traveler
Oddometer: 5,205
More important than short runs is running it at proper rpm's.
Don't lug the engine!!
Run it consistently above 4K rpm's once underway and it will be happy.
b
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 07-06-2013, 09:32 AM   #13
2 SPOT
wannabe
2 SPOT's Avatar
Oddometer: 3,291
lot of opinions about it,,, but the only real important thing to take away, and it goes for any engine, is achieving engine temp for a long enough duration to burn off the condensation that forms when you start a cold engine, otherwise you start getting into the kinds of problems associated with water in oil.
keep in mind that long idle times are no good for an engine either, you'll have cilynder wash problems, unburnt fuel in the oil, excessive carbon build up ect.
you only need to idle long enough to build oil pressure but then theres that nagging problem of putting the engine under load while its still cold.
i think your best bet is to sell the bike and commute in a car, nobody seems to be worried about the same damage that occurs to cars under the same circumstances.
multi cylinders and fuel injection do a better job of hiding little wear problems than singles, but trust me, i see the same wear day in and day out no matter what the engine.
my advise is simple, start the bike and let it idle just long enough to put on your helmet and gloves, take it conservative to the hiway and that first on ramp, then your golden , warmed up and ready to giver hell. your commute is long enough to burn off condensation.
i dont know what happened with the xr but i doubt it was all your commute or how you do it, must have been another issue involved in that.
2 SPOT screwed with this post 07-06-2013 at 09:39 AM
Old 07-06-2013, 11:24 AM   #14
kubiak
Oddometer: 4,829
all my bikes i had i did the same thing, start it up let the oil flow a bit then take off easy for a few miles to get up to normal temp before riding hard.
Old 07-08-2013, 07:45 AM   #15
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,243
Assuming you take proper care of the bike, that commute will not bother it unless you are breaking laws on a regular basis.
And while I do agree with folks here that "fully warmed up" is not essential to casual riding around town, I just want to point out that three bars on the temp gauge may not be even close to warm. I have a thermometer dipstick and when I reach three bars from cold it is only approaching 60C, and warmed up is 80C. Good to know if you are getting ready to dig into the throttle and are assuming three bars means GO!!!
Link below to the 640 Index thread.
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Times are GMT -7.   It's 06:33 AM.
