Old 11-01-2013, 02:45 PM   #46
LukasM
Oddometer: 5,425
Originally Posted by Rusty Shovel View Post
Any word on gearing?
None, so don't expect any changes or we would have heard about it already.
Old 11-02-2013, 12:43 PM   #47
ktmmitch
Oddometer: 662
[QUOTE=LukasM;22686703]None, so don't expect any changes or we would have heard about it already.[/QUOT
Gearing same as before
ktmmitch is offline   Reply With Quote
Old 11-02-2013, 01:03 PM   #48
Night Falcon
Adventure NZL
Night Falcon's Avatar
Oddometer: 2,220
All 690's should come standard with the Rally Raid chain/clutch front sprocket protection guard - period!
Hey mitch, welcome back buddy.
My EXC530 Adventure
My KTM690 Adventure
2008 250 Beta Rev3 - Trials with lots of errors
Night Falcon is online now   Reply With Quote
Old 11-03-2013, 02:36 AM   #49
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 1,144
No they don't, mechanical throttle on my 2013 EU 690 SMC-R with 67 HP.
Also single plug head, although I doubt that the twin spark design can really add a 5% improvement if the rest stays the same?
I think I know the diffrence.. don't know about your smcr as my post is about the enduro. Check out the photos on page 3.
999 LC8 Rat-Rally custom - 500 EXC - XR666R '85
StevenD is offline   Reply With Quote
Old 11-03-2013, 03:10 AM   #50
LukasM
Oddometer: 5,425
Well your post was about the 2013 EU models, and the Duke was the only model that had fly by wire throttle then. It is a completely different bike (starting with a single tube backbone frame with a front mounted gas tank vs. trellis frame and rear tank) than the Enduro and SMC-R, which are apparently getting the Duke engine and throttle for 2014.
FYI the SMC-R is the same bike as the Enduro except for suspension, wheels and brakes.
LukasM screwed with this post 11-03-2013 at 03:36 AM
Old 11-03-2013, 03:26 AM   #51
Katoom72
Katoom72's Avatar
Oddometer: 897
My 2013 enduro has the mechanical cables combined with the EPT.
The 2014 lacks those cables so it seems to share the ride-by-wire of the duke.
Now:
'03 KTM 250sx -- '05 KTM Adventure 950
Before:
'00 KTM 250sx -- '03 KTM 450sx -- '03 Yamaha R6 -- '08 KTM SuperDuke R --- '13 KTM 690 enduro R
Katoom72 is offline   Reply With Quote
Old 11-03-2013, 11:09 PM   #52
DirtSolace
Oddometer: 96
2014 690R changes
I was looking around Rally Raid and found this:
https://www.facebook.com/RallyRaidProducts
there are 11 pics to look at.....
here's the brief writeup:
KTM 690 Enduro R 2014 (11 photos)
We saw the first KTM 690 Enduro R model for 2014 today at the Dirt Bike Show in the UK.
Overall, the bike looked same as previous, but closer inspection noted the following:
1,ABS added front & rear
2.Twin-plug 690 Duke motor fitted.
3.Lower fork changed to allow fitment of ABS sensor.
4.New electronic throttle from Duke 690, and new throttle/front brake cluster.
5.Frame looked the same, apart from repositioned rear brake reservoir, and coil removed to as 690 Duke motor has twin-plug head, with inboard coils.
6.Forks changed to left leg compression damping, right leg rebound damping.
7.New airbox, with repositioned sensors.
8.New ECU, only 1 fitted now.
All in all a nice little package, available February/March 2014.Price as 2013.
DirtSolace is offline   Reply With Quote
Old 11-05-2013, 07:42 AM   #53
Jan from Finland
Registered
Oddometer: 567
New cylinder head, dual ignition, ABS with roll-over protection, greater fuel mileage, new forks....
Official info at:
http://www.ktm.com/au/news-events/ei...c4-enduro.html
If you are ever attacked by lion, your best defense is to shove your arm down
their throat, grabbing the back of their tongue and hope help arrives quickly.
- Pro Travel Tip by Overland Journal
Jan from Finland is offline   Reply With Quote
Old 11-05-2013, 09:24 AM   #54
leanin
Oddometer: 181
I wonder whether the tuneecu software will work with the new ride by wire. I'd sure hate to lose the ability to use tuneecu on the 690.
leanin is offline   Reply With Quote
Old 11-05-2013, 09:47 AM   #55
Schannulleke
Oddometer: 209
That could be a deal breaker for the 2014 model. I would prefer 2013 than.
The current 2013 duke has the ride by wire engine, is it possible to use tuneecu with this engine?
Schannulleke is offline   Reply With Quote
Old 11-05-2013, 11:45 AM   #56
Katoom72
Katoom72's Avatar
Oddometer: 897
There is still a mechanical connection between the throttle and throttle body. The 'older' 690 engines have an EPT system that is commonly mistaken as a ride-by-wire system that has only an electrical connection.
the rider’s twistgrip commands are interpreted by an advanced ride-by-wire throttle system; KTM’s “EPT” (Electronic Power Throttle) which optimizes intake vacuum and also allows various engine “modes” for different conditions.
My '13 enduro has the same system as the older ones. So yes, TuneECU is possible on the '13.
Now:
Before:
Old 11-05-2013, 12:39 PM   #57
Scutty
Oddometer: 216
No tuneECU - the twin spark engine is canbus not compatible with tuneECU
Sent from my HTC One using Tapatalk
My bike anthology: Another KTM 690 Enduro R, BMW G450X, BMW R1200GSA LC, KTM 690 Enduro R, Yamaha WR250R, Yamaha XT600E, KTM 990 SM-T, Ducati Diavel, Kawasaki Z1000, Suzuki SV1000, Kawasaki Zx7-R, Honda VFR800, Honda CBR600F, Yamaha RD350, Yamaha DT175, Honda CM125, Kawasaki AR125, Kawasaki AE50 - wow I have owned a lot of bikes
Scutty is online now   Reply With Quote
Old 11-05-2013, 12:51 PM   #58
StuInFH
Oddometer: 426
When will wheelie control be mandated? Probably get that before WR trans.
It has CAN Bus system with ABS and DbW so the gubmint can control your speed where necessary, like posted speed areas and dirt-where you may hurt yourself otherwise.
StuInFH is offline   Reply With Quote
Old 11-05-2013, 05:20 PM   #59
JTucker
JTucker's Avatar
Oddometer: 2,270
I doubt you'll be able to miss anything with KTM marketing, even stuff they did a couple years ago will be an update. They changed the seat foam on the 14 dirt bikes and it's news.
On the bright side it looks like the 14 street bikes will be in the US early, hopefully first of the year instead of May......
http://www.ktm-parts.com
03 Aprilia Caponord 06DR650
13 GasGas EC300 05 WR450F 87 T-dub
JTucker is offline   Reply With Quote
Old 11-11-2013, 02:26 AM   #60
haildamage
haildamage's Avatar
Oddometer: 181
i am facing a dilemma, please help with some advice.
i could get a very good deal on a new leftover 2010 model now. or i could wait and see what is up with the new 2014 model. the 2014 model seems to be quite a bit more complicated with all the drive by wire, but it has ABS which is nice. the 2010 is a more simple and proven version.
how big an issue is the no tune ECU?!?
haildamage is offline   Reply With Quote
Times are GMT -7.   It's 12:29 AM.
