Old 03-23-2014, 07:08 PM   #796
Mk5mike
Mk5mike's Avatar
Oddometer: 304
Had a blast today 108mile down and back. About 80 of it on the freeway and on the street I have no complaints from this bike. Off road I need to find some settings that make this bike go over some the terrain a little smoother. But like the mt21 tires and the throttle is awesome. But anyone notice engine runs a lot with the fan on on slower speeds?
Mk5mike is offline   Reply With Quote
Old 03-23-2014, 07:09 PM   #797
Mk5mike
Mk5mike's Avatar
Oddometer: 304
Old 03-23-2014, 07:12 PM   #798
armourbl
Adventure Life
armourbl's Avatar
Oddometer: 622
My buddy has noticed that with his. No boil overs yet.
ben
______________________________
2013 KTM 990 Adventure Baja Edition
armourbl is offline   Reply With Quote
Old 03-23-2014, 07:13 PM   #799
TheMuffinMan
Forest Ranger Magnet
TheMuffinMan's Avatar
Oddometer: 5,913
It's not bad compared to my 950Adventure . 2012's and up run a little hotter due to the higher displacment but the only time I've had overheating issues was towing a bike through deep sandwash for about four miles. Trails going up the mountains have never caused overheating issues even when crawling at 5mph.
"To strive, to seek, to find, and not to yield."
"You don't cross the mountains, they let you through."
KTM 525 XC-W // KTM 950 Adventure
TheMuffinMan is online now   Reply With Quote
Old 03-23-2014, 07:22 PM   #800
TheMuffinMan
Oddometer: 5,913
Oh and the handlebar vibes smoothed out after about 4,000 miles or so for me. They're barely there now at 8,500 miles and it's probably just the knobbies.
Old 03-23-2014, 09:07 PM   #801
BrandonH
Oddometer: 33
Love mine. Have 500 miles on it now. Only thing it could use is maybe renazco seat and Scott's dampner,.
07 KTM Super Enduro R
14 KTM 690 Enduro R
14 KTM 1290 Super Duke R
96 Yamaha TW200
07 Tacoma (Expo Rig)
BrandonH is offline   Reply With Quote
Old 03-23-2014, 09:18 PM   #802
itnanti
aka "cautious cotta"
itnanti's Avatar
Oddometer: 423
Details on 2014 690 enduro r?
Awesome ride with the boys today 230miles of 1/2 dirt 1/2 mountain twisty pavement. Rear break pedal sucks. Totally twisted it like gum on an easy get off. Now I'm scrambling to find a new before Death Valley this week. Anybody know if the 14 rear brake pedal is the same as 12 and 13?
My adventure spec case savers paid for themselves.
itnanti screwed with this post 03-23-2014 at 09:26 PM
itnanti is offline   Reply With Quote
Old 03-23-2014, 09:29 PM   #803
burmbuster
burmbuster's Avatar
Oddometer: 1,430
Soften the suspension with the clickers, change the coolant to Engine Ice, and change the fan temp switch to the lower temp switch. It will start cooling earlier with the switch and the new coolant will have it running cooler unless you are stuck in traffic.
_______________
2013 KTM 690 Enduro R
burmbuster is offline   Reply With Quote
Old 03-23-2014, 10:14 PM   #804
isaac004
isaac004's Avatar
Oddometer: 821
Bike prep, fresh canvas!
Started out with this. Lots of goodness here.
This list included:
ADVSpec engine skid plate
CJ Fuel Cap
RallyRaid Luggage Rack
Garmin Montana GPS
Rally Raid Front Sprocket Guard
HDB Guards
Battery Tender cable
Double Take Mirrors
Scotts Damper and anti-vibration bar mount
Rally Raid Radiator Guards
Also installed a Agri tool tube holder behind the right side of the RR rear luggage rack...this holds a 1L MSR bottle full of spare gasoline.
Installing the Scotts steering damper:
Installing HDB guards:
Installing RR rear rack:
And finished with this! Ready for a weekend in Death Valley in one week.
isaac004 screwed with this post 03-23-2014 at 10:51 PM
isaac004 is offline   Reply With Quote
Old 03-24-2014, 01:40 AM   #805
tacomodo
Trailblaze
Oddometer: 59
How are those case savers mounted? Glue?
That may be true, sir. But I have a hammer
tacomodo is offline   Reply With Quote
Old 03-24-2014, 02:26 AM   #806
Bike Nomad
Bike Nomad's Avatar
Oddometer: 321
High temperature silicone.
DON'T GET IT TWISTED --ITS DUAL SPORT! NOT DUEL SPORT!
Bike Nomad is offline   Reply With Quote
Old 03-24-2014, 05:45 AM   #807
Chris6501
Oddometer: 33
Be sure to keep an eye on your rear brake lever. Mine fell off yesterday. Have less then 200 miles on the bike. I'm pretty sure I have read others with same issue. Had no rear brakes for the second half of my ride.
Chris6501 is offline   Reply With Quote
Old 03-24-2014, 05:53 AM   #808
itnanti
itnanti's Avatar
Oddometer: 423
I used copper rtv high temp silicone. If I didn't have these on I would have been dumping oil.
Old 03-24-2014, 06:31 AM   #809
TheMuffinMan
Oddometer: 5,913
I'd put a dab of blue loctite on the swingarm screw when you take the right footpeg mount off to re-screw or replace in the rear brake lever. I torqued my swingarm nut to spec after installing the RR billet lever, and the right hand swingarm screw loosened and fell out at some point . Noticed my bike was handling a little funny on a ride down to a tech day at a friends place. I look up at the bike while changing a tire and yeah, no right side screw in the swingarm and the swingarm bolt was working itself out the left side of the bike!
No issues since using a small dab of loctite on the replacement bolt though.
Old 03-24-2014, 06:42 AM   #810
ba_
ba_'s Avatar
Oddometer: 2,732
Can these covers ever be taken off or once applied properly are they permanent?
'09 Triumph Bonneville 50th Anniversary, '14 KTM 690 Enduro R
ba_ is offline   Reply With Quote
Times are GMT -7.   It's 06:02 PM.
