Old 07-04-2013, 01:19 AM   #1
indr OP
Oddometer: 501
Plastic Fairing Hole Repair
indr screwed with this post 02-22-2015 at 09:30 PM
indr is offline   Reply With Quote
Old 07-04-2013, 05:27 AM   #2
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 1,459
I haven't used this product, but have read about it's successful use from legitimate riders: http://www.urethanesupply.com/Motorc...irings-Repair/
Although, if your aren't the type to (read and) follow directions it may be a waste of money. Good luck!
Stan_R80/7 is offline   Reply With Quote
Old 07-04-2013, 08:14 AM   #3
joexr
Oddometer: 3,773
Put a sticker over it.
Old 07-04-2013, 11:25 AM   #4
Beezer
Oddometer: 5,841
cut the hole round, make a plug the same size from a donor cover (junkyard), glue & fill as required. maybe make a larger patch for the inside as a doubler if needed
Beezer is offline   Reply With Quote
Old 07-04-2013, 01:28 PM   #5
redprimo
Oddometer: 484
Originally Posted by indr View Post
Hmm. I looked at their video. Seems like a very long process compared to what I was imagining.
Which was what? Some magic words and some fairy dust as opposed to real work.
redprimo is offline   Reply With Quote
Old 07-04-2013, 01:30 PM   #6
joexr
Oddometer: 3,773
Old 07-04-2013, 07:14 PM   #7
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,317
Quick way to patch is to tape some stiff plastic, like a piece of coffee can lid or other plastic container, over the outside and then use most any flavor of epoxy putty and spoon it in with a spatula. press some fiberglass cloth or even a piece of fly screen into the back, then when it has cured remove the plastic piece and you should have a relatively well blended surface to finish up and paint.
GreaseMonkey is offline   Reply With Quote
Old 07-04-2013, 07:16 PM   #8
GreaseMonkey
Preshrunk & Cottony
Oddometer: 5,317
Also, if it is ABS use some plastic pipe primer you get in the plumbing section to help get a better bond.
Old 07-04-2013, 08:05 PM   #9
Cosmic_Jumper
Location: The Republic of Dreams , Bureau of Dubious Reality
Oddometer: 270
Yeah, but you've got to use "ABS Plumbing Cement". PVC cement or ABS/PVC plumbing cement won't work. Or won't bong well to ABS plastic.
You can sometimes Oatey (brand) ABS Plumbing Cement at Home Depot or Lowe's or an RV supply store. If your local building codes permit ABS drain plumbing (black plastic pipe) you're in luck as you'll be able to find ABS Cement.
You may also be able to use "Kleer Strip" liquid paint stripper. It contains methylene chloride. Which is the same stuff that Plastex kits contain. HTH
Tim
Cosmic_Jumper is offline   Reply With Quote
Old 07-06-2013, 09:34 AM   #10
MrBob
Certified Geezer
MrBob's Avatar
Oddometer: 7,563
I have been down this road with broken luggage.
There are charts online that will help you determine what material your fairing is made of. You'd be surprised to learn how many different types there are. I was surprised to learn how many can't be glued.
If you can cut a donor piece from an unobtrusive location on your bike, that should work, otherwise, try to get the same material from a motorcycle junk yard or inmate. The donor piece can be welded in place using a heat gun. It's tricky to keep the right amount of heat in the right spot but it should produce a permanent fix.
"When I was younger I was afraid I'd die riding now that I'm old and falling apart, I'm afraid I won't."
bwanacswan's dad
MrBob is offline   Reply With Quote
Old 07-06-2013, 03:48 PM   #11
Racer111v
Racer111v's Avatar
Oddometer: 794
It's easier than it looks. I have repaired my FJ1200 plastic with it. It bonds absolutely, and with some care and practice it is invisible. A scrap of fairing will save some time if easilly available, but you can make shapes with this stuff if need be. I made missing pieces that were easily an inch across.
2004 KTM 950 ADV ...............................1979 Suzuki RM400 VMX Race bike
2006 DR-Z400E plated........................... 2001 Ducati ST2 944
2001 YZ250N 2T plated.......................... 1986 Yamaha FJ1200
Racer111v is offline   Reply With Quote
Old 07-08-2013, 01:47 AM   #12
Falconfixer
It is what it is....
Oddometer: 584
I found some ABS plastic welding rods, made for use with a simple heat gun, at a Home Depot style store when I was stationed in Germany 4 years ago. If theyve got it there, we've got to have it available in the states by now, right?
Falconfixer is offline   Reply With Quote
Times are GMT -7.   It's 07:44 AM.
