Old 07-07-2013, 06:52 PM   #16
CycleDoc59
Wrench Rider
CycleDoc59's Avatar
Oddometer: 983
Easy on the dielectric grease, it's non-conductive..!
You say the stator is putting out over 50v ac on all
three legs, so there's more than ample output there, for sure.
Stators on modern bikes virtually all have output well in excess
of what is normally needed to run a bike, allowing for quite
a few electrical accessories to be added.
Rectifier/regulators do not always provide adequate output.
Output varies a bit from one to another; some go barely to
14v if at all, others I find put out over 14.6v; too much.
CycleDoc59 is offline   Reply With Quote
Old 07-07-2013, 06:53 PM   #17
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,415
So what's the problem? No start from a weak battery? All those voltage readings are within range of acceptability.
Old 07-08-2013, 04:03 AM   #18
conlysm OP
conlysm's Avatar
Oddometer: 43
the problem is last year the bike was fine, this year my second commute to work the bike would not start, not a huge deal as I was home and just took the car. I often use this bike to go on long rides out of state no where near home or help for that matter. I am fearful of getting stranded somewhere. I understand the the values I am getting are prob within range and acceptable, but being OCD I am not comfortable with leaving as such. I want it to be like it was last year ie; like new.
conlysm
08' Ducati HM1100S (Scooty-Puff Jr.)
conlysm is offline   Reply With Quote
Old 07-08-2013, 04:05 AM   #19
conlysm OP
conlysm's Avatar
Oddometer: 43
I did take the bike for a ride yesterday, approx 200mi with several stops for fuel and breaks in general, the bike worked fine but I was nervous every time I went to start it, being fearful if it would even start. I can't check the voltage while moving (which sucks) but when stopped and in neutral the instrument cluster will let me check the voltage and at one point I was down to a flat 13.V so in short this thing is all over the map when it comes to charging.
conlysm
Old 07-08-2013, 04:30 AM   #20
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,415
Lol, replace the battery, ride reliably. Your OCD will not change how the charging system was engineered however. Learn to accept fluctuations. Or sit in the garage and wring your hands. JK Really, it's fine.
Times are GMT -7.   It's 01:53 AM.
