Old 07-05-2013, 11:29 AM   #1
D.T. OP
Up in this MF'er!
D.T.'s Avatar
Oddometer: 10,962
Question HD stapler
I'm putting a bit of foam under my exisiting seat and the stapler I have will not cut it. I'm trying to go into the seat (plastic) and it barely goes into the plastic.
Something like these.
http://www.mcmaster.com/#manual-staple-guns/=nhp9fc
Is there an option for a hand stapler that can ka pow into the plastic better without costing hundreds of dollars?? Should I use staples with the pointed ends?
I'm just a weekend warrior when it comes to upholsery.
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 07-05-2013, 11:33 AM   #2
groundrules
groundrules's Avatar
Oddometer: 1,719
You could go pneumatic or electric for less than $50. Both available at Lowe's/Home Depot.
http://www.lowes.com/pd_398889-355-BTE550_0__
groundrules is online now   Reply With Quote
Old 07-05-2013, 12:29 PM   #3
squirrelnator
Mystical Adventurer
squirrelnator's Avatar
Oddometer: 224
Hand Staples
No need to go electric or air. I have used the regular old inexpensive stanley PowerShot from home depot with 3/8 inch staples in several honda seatpans. It works just fine for attaching the material.
A fast moving target...
squirrelnator is offline   Reply With Quote
Old 07-05-2013, 12:40 PM   #4
kubiak
Oddometer: 4,829
if you have a air compressor get a harbor freight air stapler. i got mine for about 15 bucks about 10 years ago and have done a few dozen seats with it. works perfect!
Old 07-05-2013, 01:13 PM   #5
victor441
victor441's Avatar
Oddometer: 931
+1, bought an HF crown stapler for $20 or so and it works great on hard plastic seat pans that defy a manual stapler...also FWIW you don't even need much of a compressor, my wimpy wall mounted tire inflator worked fine as the stapler uses very little air
victor441 is offline   Reply With Quote
Old 07-05-2013, 01:19 PM   #6
boardrider247
Weekend Anarchist
boardrider247's Avatar
Oddometer: 657
I have 3 or 4 staplers. Electric, air and hand operated. I know the electric was useless on seats. But I think the hand operated was OK, haven't used the air one yet.
The hand operated stapler is a Duo-fast pretty sure it's this one:
http://menards.com/main/tools-hardwa...412-c-9164.htm
The key was to have the 1/4" staples, the 1/2" would go in but not every time.
Anyways if you want to borrow something let me know, I work in st. paul and can probably drop it off for you.
Life is a waste of time, Surfing is a great way to waste it
boardrider247 is online now   Reply With Quote
Old 07-06-2013, 12:51 AM   #7
Wolkow
Oddometer: 2
HD stapler
In the same situation I drilled many holes in base of the seat and used blind rivets.
Wolkow is offline   Reply With Quote
Old 07-06-2013, 07:05 AM   #8
D.T. OP
Up in this MF'er!
D.T.'s Avatar
Oddometer: 10,962
I am using #5 1/4" staples. Trying to get the staples into seat plastic on my Suzuki DL. Currently have a Proshooter All in 1 model 5650. Doesn't cut it. Restapling seat vinyl. I almost bought a $37 pneumatic stapler at Norther Tool.
I may try the HF pneumatic stapler.
I just don't want to buy one and it doesn't work.
Menards? I don't really wan't to spend more that $25 bucks.
http://www.menards.com/main/tools-ha...308-c-9164.htm
D.T. screwed with this post 07-06-2013 at 07:37 AM
Old 07-06-2013, 08:32 AM   #9
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,651
The harbor freight works awesome
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 07-06-2013, 08:33 AM   #10
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,632
My cheap pneumatic stapler shoots T-50 standard. That's good easy to find even in SS. But I took all the safeties off for better reach, they were in the way on my BMW seats.
Someone used it on a Suzuki, no problems.
Have tools, will travel!
Old 07-09-2013, 09:27 AM   #11
Gillus
High Desert Rat
Oddometer: 762
+4 on the HF air stapler.
Beware those with no sense of humor as they will cause you misery.
Disclaimer: I am only responsible for what I said, not what you understood or how you interpreted my words!!
'11 GSA supertanker/mothership, '11 Suzuki Burgman 400, '06 KTM 640A
Gillus is offline   Reply With Quote
Old 07-09-2013, 09:54 AM   #12
mjydrafter
evil boy for life
mjydrafter's Avatar
Oddometer: 4,126
Make that a +5, it didn't even break a sweat on my hard-assed Corbin pan. My manual stapler didn't even make a mark...
1974 Suzuki TC-185 (The little 10 speed)
1986 BMW K75c
Yes! Whenever bicycles are broken, or menaced by International Communism, Bicycle Repair Man is ready!
mjydrafter is offline   Reply With Quote
Old 07-09-2013, 12:08 PM   #13
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 12,425
if using a manual stapler, make sure it is seated squarely agaisnt the seat base . . . . for me, even a couple of degrees off square keeps the 1/4 inch staples from seating fully.
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance. T.R.
bomber60015 is online now   Reply With Quote
Old 07-09-2013, 12:49 PM   #14
D.T. OP
Up in this MF'er!
D.T.'s Avatar
Oddometer: 10,962
Bluhduh
Shit. I bought a $20 manual stanley stapler at the pot Sunday. Cranked it up to max and didn't even get the staple in.
I'll try the HF pneumatic next!
Old 07-09-2013, 04:04 PM   #15
2 SPOT
wannabe
2 SPOT's Avatar
Oddometer: 3,218
i picked up a powershot stapler many years back, the kind that pivots on the tail so your hand pressure is over the head. works great, no problem with seat cover on plastic pan.
2 SPOT is offline   Reply With Quote
Times are GMT -7.   It's 09:58 AM.
