Old 07-05-2013, 06:21 PM   #1
RealOldDualSportGuy OP
RealOldDualSportGuy's Avatar
Oddometer: 488
Which Air Head???????
"The time has come"the walrus said "to talk of getting an air head GSPD"
Always wanted on, now is the time to buy/restore/rebuild/ride one.
Where do I start?
The bike will be used for day trips and maybe even weekend rides along the BRP, the Natchezz Trace, and etc.
Suggestions?
Past HS racer, road racer, LSR Holder, Buell owner, so not much we won't take on.
Regards and thanks
I wont be wronged, I wont be insulted, and I wont be laid a hand on. I dont do these things to other people, and I require the same from them. John Wayne -- The Shootist (1976)
RealOldDualSportGuy screwed with this post 07-05-2013 at 07:51 PM
RealOldDualSportGuy is offline   Reply With Quote
Old 07-05-2013, 06:23 PM   #2
Lomax
Nanu-Nanu Adventurer
Lomax's Avatar
Oddometer: 8,890
Get the best one you can find and can afford and then plan to put about $2K at least into it. DAMHIK: If it is in good shape.
Marc
84 R100RS LE, 2012 Stelvio, 2013 V7R, 73 850 Commando, 78 CT90, 14 Ural, 74 Eldorado police, 64 R50/2, 13 TR650
http://s22.photobucket.com/albums/b327/lomaxcm/?sc=3
Lomax is offline   Reply With Quote
Old 07-05-2013, 06:29 PM   #3
JM
JM's Avatar
Oddometer: 781
This one looked to be in pretty good shape. It only had 38 original miles on it so it's probably all rotted out from just sitting in a climate controlled garage somewhere.
John
Postponing retirement one farkle at a time!
JM is offline   Reply With Quote
Old 07-05-2013, 06:40 PM   #4
advNZer?
advNZer?'s Avatar
Oddometer: 2,829
yes,buy the absolute best one you can find,or be prepared to do a little work.
In the rime i have had mine i have had to replace the trigger in the bean can,replace the diode board,get the starter bushes done and cleaned up all the carbon,replace the battery,get the battery box cleaned up and powder coated it,re cover the seat and replace the rear shock.I plan to do something about the front brake and have got a new cartridge front suspension setup.I still have intermittent dash lights and the clock and heated grips dont work,and a small oil leak from either the push rod tubes and or neutral switch.Its a 1989 and i dont really know how many KM its done.Its done at least 130,000 km maybe 230,000 km or maybe more.At one point in its life it has had a "catastrophic" drive shaft failure.It needs new rubber boots for the drive shaft and its also got a slight oil weep at the rear drive shaft boot.
I love it
aka BMWST?
advNZer? is online now   Reply With Quote
Old 07-05-2013, 07:29 PM   #5
Oddometer: 488
Appreciate the input
We put $3K in farkles on the last Uly we built !!!!!!!
Any year to stay away from?
Any year better than another?
Cheers
Old 07-05-2013, 07:39 PM   #6
Schlug
JockeyfullofBourbon
Schlug's Avatar
Oddometer: 7,370
We're really a bunch of nice guys and there are some airhead owners amongst us, but you really should put this query to the fellows in Olds Cool.
http://www.advrider.com/forums/forumdisplay.php?f=85
"So what makes this protest different is that you're set to die, Bobby?"
--May well come to that.
"You start a hunger strike to protest for what you believe in. You don't start already determined to die or am I missing somethin' here?"
-- It's in their hands. Our message is clear. They're seeing our determination.
Schlug is offline   Reply With Quote
Old 07-05-2013, 07:48 PM   #7
Oddometer: 488
Thank you for the suggestion
Guess I could cross post it there
Cheers
Old 07-05-2013, 07:50 PM   #8
Oddometer: 488
Which air Head ??????????????? Cross Post from Boxer Forum
Where do I start?
Suggestions?
Regards and thanks
Old 07-05-2013, 07:51 PM   #9
Mugwest
Mugwest's Avatar
Oddometer: 6,036
Surprised you didn't punt him to OldSkool sooner
Post up in the Airheads subforum at the above link, OP. You are basically going to be advised to not get your heart set on a PD model, given your day-trip operating profile. Ie: only difference between 90-95 airhead GS's is the tank capacity-- 6gal vs 9gal and some seat options is really it for those years
Head to OldSkool! :
Mugwest is offline   Reply With Quote
Old 07-05-2013, 07:55 PM   #10
Oddometer: 488
Not too certain about everyone being nice guys here
Why thank you for the very very helpful insight and wisdom
Old 07-05-2013, 08:01 PM   #11
kadesean
eyesuck
kadesean's Avatar
Oddometer: 981
G/S has the monolever, better off road and solo. Available only in 800cc '81-'84. Monolever is also a simpler and more rugged/dependable design.
GS has the paralever, longer wheelbase, bigger overall (not by a lot), better for big roads and two-up. Availability beginning in mid-late '80's. Read up on the horrors of the paralever and how it's the worst thing BMW ever did. (I have one)
Someone will come along and specify which years need circlip attention. I can across a '92 that had an old work order that showed circlip was done already and I'm loving the bike as my do everything bike.
steve-0
kadesean is offline   Reply With Quote
Old 07-05-2013, 08:34 PM   #12
advNZer?
advNZer?'s Avatar
Oddometer: 2,829
Where do I start?
Suggestions?
Regards and thanks
dont do that,i bet your original thread appears here
aka BMWST?
Old 07-05-2013, 08:35 PM   #13
Mugwest
Mugwest's Avatar
Oddometer: 6,036
Miscommunication alert! 'OldSkool' was not a knock on you, it's what we call the Airhead forum here. THat link Bobby gave you is where the Airhead action is here on ADV
You mention Stagehand in your signature, well Jason's in OldSkool like a ton, as am i.
See you there!
Mug
Old 07-05-2013, 08:44 PM   #14
Mugwest
Mugwest's Avatar
Oddometer: 6,036
I was one of the ones in GSpot that directed him here, All good
Welcome RODSG. You're home!
EDIT: Ooops, we still need to get to Airheads at http://www.advrider.com/forums/forumdisplay.php?f=85
Dave? Flood? Move this before OP gets flummoxed?
Mugwest screwed with this post 07-05-2013 at 08:51 PM
Old 07-05-2013, 09:39 PM   #15
seniorasi
Oddometer: 816
WOW!!!! I want one!!!
seniorasi is offline   Reply With Quote
Times are GMT -7.   It's 11:51 PM.
