Old 07-06-2013, 11:38 AM   #1
Yakima OP
DL 650
Yakima's Avatar
Oddometer: 381
Mid 80's Honda: gauge cluster glass is glued in: separate how?
My 85 Nighthawk 650 was recently forced off the road by an asshat truck driver and I went down. (Guy stopped, looked, then took off...)
Among the damage is a cracked glass lens in the gauge cluster. I've taken the cluster apart down to the bezel which holds the glass. The glass is glued in.
Two auto glass shops have said "Can't help you."
Honda, of course, has none to sell me.
I've put a WTB over at the nighthawk forum. Might hear from someone.
Here's the question: two, actually--
Why did Honda glue the lens into the bezel???
Do any of you have the hot tip on getting the lens out? (I've tried heat from a hair dryer. Softened things, no movement)
TIA
Be yourself. Everyone else is already taken.
Yakima is offline   Reply With Quote
Old 07-07-2013, 03:03 PM   #2
Yakima OP
DL 650
Yakima's Avatar
Oddometer: 381
Oven?
Heat gun?
dynamite?
Old 07-07-2013, 04:32 PM   #3
kubiak
Oddometer: 4,829
they might have glued it to keep moisture out maybe? i would try to soak it in something like paint thinner or something.
Old 07-07-2013, 05:44 PM   #4
trc.rhubarb
trc.rhubarb's Avatar
Oddometer: 1,998
Check out headlight posts on car forums about HID retrofits and/or angel eyes retrofit.
They bake the plastic lenses at some temp and time and they come right apart.
2007 BMW GS Adventure / 2000 Ducati 900ss / 2010 Harley Ultra Limited / 1975 BMW R90/6 / 2006 DRZ400S
Follow me here
trc.rhubarb is online now   Reply With Quote
Old 07-07-2013, 06:05 PM   #5
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,315
If you have a replacement lens you could try to carefully break the glass and pick the pieces out, then when it is out you could figure out the best way to fit a new lens in place.
GreaseMonkey is offline   Reply With Quote
Old 07-07-2013, 06:34 PM   #6
Yakima OP
DL 650
Yakima's Avatar
Oddometer: 381
Thanks, guys. I'm sniffing around HID kit sites.
I don't have replacement glass. Hope to get the existing piece(s) out fairly intact to make/size another.
Old 07-08-2013, 08:50 AM   #7
KungPaoDog
Oddometer: 465
I know the fix for my early 80's Suzuki's with similar issues was to dremel or saw the whole speedo in half right below the glass bezel (chrome of some sort) and then glue the assembly back together. If your cut is in the right spot you won't have an obvious repair line.
2010 Honda NT700V-Red
KungPaoDog is offline   Reply With Quote
Old 07-08-2013, 09:21 AM   #8
mcma111
mcma111's Avatar
Oddometer: 12,384
Soak it in ACETONE.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 07-08-2013, 10:00 AM   #9
gweaver
Wandering between rooms
gweaver's Avatar
Oddometer: 1,605
If you used a hair dryer and it softened up some, more heat should take care of it. Beg/borrow/steal a heat gun with adjustable thermostat and slowly turn it up until the glue softens to the point of being able to remove the lens. If you have a hi/low heat gun, just sweep the air stream back and forth slowly to regulate the heat.
FWIW, a quick search suggests that appropriate oven temp to melt the glue is between 200 and 250 degrees, for anywhere from 5-10 minutes. I'd start at 200 for 5 minutes, pull the housing and test. If it's getting soft, put it back in, check every couple of minutes. After 10 minutes, I'd remove, let it cool and jack the oven temp up to 215-220. You want a slow temp increase, as you have no idea at what point the plastic will start to melt/deform. I'd think you'd be safe up to about 275 or so, but no point taking chances.
G
I just twist and my eyes glaze over, "uh....errr huh huh, weeeeoooooh---doo dat agin, doo dat agin..." -morriswf
I like my women like I like my instant oatmeal- quick, easy, and covered in facts about dinosaurs.
gweaver is offline   Reply With Quote
Old 07-08-2013, 12:29 PM   #10
Yakima OP
DL 650
Yakima's Avatar
Oddometer: 381
Acetone?
I'm a tich worried about trying that: the whole assembly is plastic. The lens is glass. I touched a bit of acetone to the back side and it began eating away at the plastic. What I'm calling silicon/glue is in a channel, thus contained, sort of. But while the acetone is sitting on the glue, it's also sitting on the plastic.
Can't think of a way to get the acetone on the glue without it landing on the plastic too.
Old 07-08-2013, 02:30 PM   #11
GreaseMonkey
Preshrunk & Cottony
Oddometer: 5,315
what diameter replacement lens do you need?
Old 07-08-2013, 02:33 PM   #12
mcma111
mcma111's Avatar
Oddometer: 12,384
I was thinking the gauge case would be steel. Yeah, acetone and plastic does not go well together.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 07-08-2013, 02:34 PM   #13
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,709
You might want to google making a hotwire cutter. 9V battery and some Nichrome wire, as long as you can get the wire through in one spot, could free that lens.
You are right keep the chemicals away from the plastic.
Have tools, will travel!
Old 07-08-2013, 03:06 PM   #14
Yakima OP
DL 650
Yakima's Avatar
Oddometer: 381
This is mid80's styling, so the gauge cluster is sort of rectangular. Circles would be easy!
"Sort of" means there are angled corners and a center notch.
It's all plastic. From the inside or looking down at the lens, there's an outer shell upon which the glass rests. Then an inner piece, pressed and glued down onto the glass and to edges of the bottom piece. No place to pry without breaking glass. The glue isn't readily accessible, it's a good .5 inch below the edge of the plastic insert that's the keeper for the glass.
Obviously, Honda didn't plan on anyone having to repair this thing!
I'm waiting to hear from a guy who has a complete cluster he's parting out. Might have a bezel+lens for me.
I think I'll try the oven idea in the meantime...
Old 07-08-2013, 03:10 PM   #15
Yakima OP
DL 650
Yakima's Avatar
Oddometer: 381
http://www.bikebandit.com/houseofmot...1694#sch407708
#11
Times are GMT -7.   It's 01:14 PM.
