Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 07-06-2013, 08:09 PM   #1
cmkaduce OP
cmkaduce's Avatar
Oddometer: 199
GPX File Import Error to Basecamp - PONI
Hey guys,
I am using a Zumo 660 with Basecamp.
I am able to successfully load a Google Map to Basecamp but the .gpx file cannot be exported to the Zumo because of all the points of no interest (PONIs).
I downloaded the PONI Killer and converted the file. The new file is saved as a .gpx file.
I receive an error message when I attempt to load the new .gpx file with PONIs removed to Basecamp.
Does anyone have any suggestions to help me out?
Parabellum Windshields
Bel-Ray Lubricants
EBC Brakes
MN Buildings & Equipment; Kaduce Tire
The Minnesota Boy Heads South --> http://advrider.com/forums/showthread.php?t=928493
cmkaduce is offline   Reply With Quote
Old 07-06-2013, 10:54 PM   #2
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,632
Originally Posted by cmkaduce View Post
Hey guys,
Import the KML file directly into BaseCamp then filter the Track(s) in BaseCamp. Your zumo660 can only handle Tracks with ≤650 points.
HELP -> Tracks -> Editing Points in a Track
Filtering Track Points
You can filter the points in a track to remove unwanted points and simplify the track.
NOTE: When you filter track points, the removed points are permanently deleted from the track.
1.Double-click a track.
2.If necessary, hold Shift on your keyboard, and click the starting point and ending point of the range to be filtered.
3.From the Properties tab, select Filter.
4.Select the points to filter:
•To filter the entire track, select Entire Track.
•To filter only the range of points you selected, select Selected Track Points.
5.Select the filtering method:
•To set a minimum time between points, select Time, and enter a value.
•To set a minimum distance between points, select Distance, and enter a value.
•To have BaseCamp adjust the number of points automatically, select Automatic, and adjust the slider.
•To set a maximum number of evenly spaced points, select Maximum Points, and enter a value.
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK screwed with this post 07-06-2013 at 11:00 PM
DRTBYK is offline   Reply With Quote
Old 07-07-2013, 11:13 PM   #3
cmkaduce OP
cmkaduce's Avatar
Oddometer: 199
Thanks Dan. I will try that.
Bel-Ray Lubricants
EBC Brakes
Times are GMT -7.   It's 10:11 PM.
