Old 07-06-2013, 08:18 PM   #1
Apocalipsis FZR OP
Im too old for this....
Apocalipsis FZR's Avatar
Oddometer: 85
Retro Street Tracker ...with a 710cc DR Thumper..
2014/MAY UPDATE.
Done it!
As always..my apologies are given to anybody that considers to be offended by my poor spelling and limited vocabulary. Im afraid that english is not my preffered lenguaje to write in.
Also I am really sorry about some of the quality of the pics...Im not a photographer, neither....
Ok.
This is one of the most strange build ups I ever made....not because my previous monsters were basically Street Fighters, but mainly due to the fact that it started with a piece of crap frame I founded at the back of my shelter and with fuel tank that I founded in the local ebay for 5 $...
So the story begings with this:
The tank ..I think is from an old Suzy...may be a GS250 from the 80s.
The frame is from the almighty DR650 Dakar or Djebel (1990).
In order to take this pic I had to chopp the fuel tanks front fixing points...otherwise the tank wasnt laying prpperly on the frame...
After a intensive thoughts I decided to move forward....but I wasnt sure about my main objective...
So I took the decision to see or imagine which concept I wanted, I assemblied the mock upor an empty engine I use to check clkearances in my DRs, also installed a swingarm and a R6 rear shock I have from my super Sport times...
I also check the web for inspiration, and this were the bikes that suit almost everything I want from a tracker:
So the ojective was:
  • Build a Street tracker with Retro inspiration (even when this means going back in time about frame /suspension design - Engineering INvolution??).
  • Build it with what I already have in my garage (even when this mean wasting more time creating something I can find already done - Tight budget).
  • Use the available money in trying new Engine Ideas I have for the DR 650 engine (I have one DR650 RSE from 1995 with a 670cc Wiseo kit -the one w/ Faring , the european model- as dailly conmuter, and one DR650 R kick starter Highly modified for Adventure Rides in South America).
So...lets start with basics.
Defining if I go with a flat subframe, or I leave the soft curve of the orinial DR frame...Ill leave it, but it must chopped until a new subframe lenght is defined, and I must take a decision if I leave the frame chopped or I close it in a curve...the last one will be ...like an old Triumph ..
Wheels .... In front a 19" , ok,
I found a new rim 2.15x19 , new spokes, done it...
Rear??? I dont know yet...
By general standads, it must be a thin 19 or 18"...but this is something I will decide with a propper roller chassis and working suspensions...for now I will leave the standard 17 x 2.5 from the DR650...
Until now...looking promissing...
http://www.ladobleayuda.org/
Apocalipsis FZR screwed with this post 05-18-2014 at 06:22 PM
Apocalipsis FZR is offline   Reply With Quote
Old 07-06-2013, 08:36 PM   #2
BigPigDaddy
ADV Dreamin'
BigPigDaddy's Avatar
Oddometer: 20
I really like the lines of it already. Muy Bueno!
Micah 6:8
Don't infringe on my rights because someone else abused theirs!
BigPigDaddy is offline   Reply With Quote
Old 07-07-2013, 06:06 AM   #3
plugeye
mc caregiver
plugeye's Avatar
Oddometer: 3,907
looks properly proportioned imo.
plugeye is offline   Reply With Quote
Old 07-07-2013, 03:13 PM   #4
Apocalipsis FZR OP
Oddometer: 85
Ok... Retro style on going....or Engineering INvolution started...
Started to cut some things and these are the leftovers..
12 cm shorter swing arm (I need this thing to be able to slide), dual shocks... In the pictures checking clearances with the DR 650 Jurassic Rallys rear wheel (a 18 x 2.5 with Knobbies).
Over there is the muffler she is going to use...an old style megaphone .
Started to build the exhaust....
Im afraid that my hydraulic bender cant do a good job with this kind of pipes...and Im also using a bigger pipe...so Im using the Oil & Gas curve system...mitred bends....its time consuming but I peffer to do it myself.
The shocks I was trynig were from a Chinesse 250cc...but believe it or not...there were really hard...so I had to change them to a 125cc donnor...also Chinesse...
My former engine builder (from my super sport time) gave me an old front mudguard.... donnor bike unknown (by the style, quality of the chrome and general dimensions...I elieve is from a 80s street bike)...its going to be at the rear...
Made a couple of steel plates and welded to the frame, so the shocks can be mounted directly to the frame...
Still looking good.....
Apocalipsis FZR screwed with this post 07-07-2013 at 03:18 PM
Old 07-08-2013, 04:26 PM   #5
Apocalipsis FZR OP
Oddometer: 85
Ok some up dates for you...
  • Still checking geometry with a 18rear wheel,
  • Exhaust completed, painted and asbestos taped.
  • Final location of the rear mudguard.
  • Final location of fuel tank (rear support made and welded.
  • Front light installed (from a HONDA CG 125 Chinnese copy, the cheapest one I could find).
  • Seats structure completed (a steel back bone with front and rear/lateral supports) ready for cushion fabrics.
  • Handlebar Risers (25mm) Lathe manufactured, in place.
On the fuel tank aspect...I really dont know what to do with it...
It has some minor dents (which can be roughly reapired and then epoxy and paint) but there is a pinhole due to Pitting .
Its becoming really hard finding someone that makes an old school repair (welder and Sn/Pb added), and the epoxy resin is a repair I can do my self...
Any suggestion??
Old 07-09-2013, 07:02 AM   #6
bk brkr baker
bk brkr baker's Avatar
Oddometer: 5,869
Use silver solder from a welding supply house to fill the pinhole.
Old 07-10-2013, 07:32 AM   #7
Apocalipsis FZR OP
Oddometer: 85
Good Idea BAKER.
I'll find the local supplier of that stuff...
I even watched a Video in Youtube about it... seems easy...
OK.
the engine is almost done.
Amost because of the 3 available Cilinders top head , not even one is in an acceptable status...
I cant find a suitablke replacement locally (and in US ebay there is nothing in good price).
I'll be going to a local machine shop to make some old school repairs on one of the HEADs...
like this (look at the inserted sleves):
But I really want to try another solution...instead of using sleves, I want to use actual Roller Bearings.....
Like KTM's Heads...
ANY DISADVANTAGE??
Have anybody try this before?? I mean, replacing the OEM Sleve system of a CAMSHAFT to a Roller BEARING system???
So, until now, regarding the engine,:
  • gears revised.
  • ALL Engine bearings replaced.
  • Oils seals replaced.
  • Oil pump checked.
  • NEw clutch discs installed
  • New Heat Resistant Paint.
  • Sand blasted Engine covers
  • 710 cc " KIT " Installed.
On the 710cc KIT...I have to tell that is another of my "wanna Try" things...
PRE 1996 DR 650 has a Bore of 95.0 mm , which linked to a stroke of 90.4 mm , it results in a 640cc displacement.
POST 1996 DR650 SE has a Bore of 100.0 mm , which linked to a stroke of 82 mm , it results in a 644cc displacement.
NOW, my Idea was..." What about taking a PRE 1996 DR 650's engine and installing a POST 1996 DR650 SE's Piston????
You will end up with a BORE of 100mm and a stroke of 90.4 mm....that will give you a 710 cc engine...."
Sounded extremly stupid ....SO I DID IT!!!!
Bought a JE Piston kit of standard diameter for the DR650SE ( although is lighter that the Suzuky OEM unit, its the same dimension and compression ratio) , Took the Cylinder to a machine shop, removed the Sleve, machined the Cylinder, installed another larger Sleve, machined the new sleve to the desired diameter...and thats it... a 710 cc Thumper based on a DR650 engine....
Old 07-10-2013, 02:25 PM   #8
MODNROD
Perpetual ponderer
MODNROD's Avatar
Oddometer: 2,130
Rollers for the cam might be more expensive to fit than a new motor.
What about measuring the cam journals on the head, finding a set of conrod bearings that come close, then line-boring the head to fit it all together? Conrod bearings are easy enough to lathe down a bit to make it all fit, just need to find something close.
Either that or weld/fill/machine/line-bore.
Who the hell would drag race a Ducati?!?!?!?!
http://www.dragtimes.com/Ducati-Mons...lip-10329.html
MODNROD is offline   Reply With Quote
Old 07-10-2013, 03:04 PM   #9
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,826
Like KTM's Heads...
ANY DISADVANTAGE??
I did this recently on a damaged Arctic Cat H1 head. On the H1 the inner-most journal was destroyed. Luckily, it was a smaller diameter than the other journals, which made it easy to enlarge and add roller bearings to the new cam. This was about half the cost of a new head.
Things to worry about:
oil pressure - roller bearings don't hold oil pressure like a journal will. If you are going to install roller bearings on a journal that has an oil hole (like the center on in your pic) you will want to weld the oil hole shut and drill an appropriately small-sized hole (or otherwise restrict oil flow) to keep the proper oil pressure throughout the rest of the oiling system.
Bores - typically heads are machined as a matched pair, which means you bolt the cover to the head and then bore out the journals. So if all of your journals are the same dia and you want to bore in inner-most journal, you will also have to bore the middle and outer ones too.
other notes:
Roller bearings don't need as much oil as journals do.
Pablo83 is online now   Reply With Quote
Old 07-10-2013, 06:32 PM   #10
Apocalipsis FZR OP
Oddometer: 85
other notes:
Excelent.
Also Thank you for you suggestion MODNROD, look at the pictures,
it was included in the solution ...
PAblo I understand your oil pressure concern.
I already worked in a secondary Oil cooler for my old ADV bike
(nowadays my dailly conmuter) where I had to reduce the oil flow
(in order to mantain OIL pressure in the main gallery).
In that case I installed a small carburator jet... and that was it.....
Pressure was optimun even at low RPMs.
Here is a pic of the Head Tops I have:
And here is what I want to do...
OK... going back to the engine and frame.....
I got to clarify something.....
For my understanding, dirt bike frames should be black.....
so mud/dirt willl not notice too much (yes Im lazy)
....also for this particular bike I wanted the old school look of the Sach engines
(do you remeber ? those huge unpolished Aluminium bellys on the sides??)
so this is what I have acomplish with my limited Sheds resources....
Notice that the rear end has a 130/80/17 now....
I decided to stick with a 17rear.... the 18
(although is more respectfull of the pure blood dirt tracker concept...
its a PITA to match with the front 19", mainly because all 18 rear tyres are tall...).
Here are a couple of shots of my "710 cc KIT" ... compared to the OEM 95mm Piston...
Yes....I love to show off....
Apocalipsis FZR screwed with this post 07-10-2013 at 06:57 PM
Old 07-10-2013, 06:34 PM   #11
Apocalipsis FZR OP
Oddometer: 85
Sorry...I really have no idea why some pictures look huge and others are OK....
EDIT:
Problem solved...its good to have a wife with graphic designers degree ...otherwise my digital life would be misserable...
Apocalipsis FZR screwed with this post 07-10-2013 at 06:59 PM
Old 07-11-2013, 03:41 PM   #12
Apocalipsis FZR OP
Oddometer: 85
ok.... Last Pictures of the Bike (current status)...
If you llok at the pictures
you will notice that the bike lines are more "balanced" with a 17" rear wheel,
even with a relativly LOW profile tyre as the Metzeler Karoo generation 1 in 150/70/17.....
Also I installed this tyre in the OEMs DR rim just to check how it looks
(you CAN NOT use a wide tyre like this one in a 2.5 in Rim...
it doesnt sit properly ....)...
So the decision is to find a wider RIM in 17 ...
Im afraid that SUpermoto Aluminium Rims are extremly expensive
and not easy to find in my Country....
but an old school Steel Rim will do the job and it would be more "in line" with the bikes concept...sort to speak...
Details....
I have to find another solution to the rear LIGHT....
This one is cheap simple and basic....
but it just doesnt "fit" in my mind...
SUGESTIONS??
The License plate Holder will reamin...mainly because is a stainless steel plate and Im going to paint/plot the numbers on it (yes...I can do that here )
Old 07-14-2013, 05:37 PM   #13
Apocalipsis FZR OP
Oddometer: 85
This week had a slow progress, mainly because Im getting ready my ADV bike for the PRE DAKAR ride... You ll see, the DAkar is in january, so in September we take the time (2 weeks) to ride some of the stages.... like a mini Dakar for the non professionnal riders ...
So, some pictures of some new details...
A new Brat style , small Carter protection..
In case you havent noticed, I dont have a CNC...so everything I do is hand made....
Today I finished removing the tanks paint...Ill start repairing the tank tomorrow night.
Old 07-16-2013, 08:11 AM   #14
JagLite
JagLite's Avatar
Oddometer: 1,384
Thumb Tracker
Excellent work!
I really like the return to twin shocks for appearance and "age".
I do think the forks are too long to go with the look though.
Are you considering lowering the front end?
Have you figured what the compression ratio will be with the longer stroke/100mm piston?
The piston didn't hit the crank? Or did you trim the skirt?
Two thumbs up for the low cost build!!
Anyone can buy parts and bolt them on (if they have the money).
But to build your own with what you have and what you can make is great.
I thought I was building a budget tracker until I added up all the bits I bought and was shocked at the total spent!
Keep up the good work!
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is offline   Reply With Quote
Old 07-16-2013, 07:46 PM   #15
Apocalipsis FZR OP
Oddometer: 85
Talking
Originally Posted by JagLite View Post
Excellent work!
Thank you!
Yes, the forks are too long right now.
The solution is to Cut the springs or cut the spacer that goes inside of the forks. But that is something I need to do once the Bike is in a running condition or with its complete weight (complete running engine, oil, fuel, electronics and battery). By that moment I can really see which is the real Sag of the forks (or in other words, how much the forks are compressed in a static situation). Until that moment, the forks are dry, the seals are old and ready to be discharged, so now I can only rise the forks in th triple clamp in order to achieve a balanced view.
Also I need to determine which is going to be the height of the bike....on the rear end I have plenty of regulation (now a days both shocks are with no Pre compression at all, and installed in middle height possible).
To be true I havent thought about the compression ratio. Using common sense, If the piston top is the same shape as the standard one, and the Combustion chamber is the same volume, the clearence volumen is the same, the stroke is the same, but the deck height was increaced, the added displacement shouldnt change drastically the compression Ratio. MAy be a huge 10% added. Lets say that with the standard pre 1996 DR 650 compression ratio as a base line...I really need to do a BIG change in order to achieve autocombustion...
But, that is a good question to see what an increaced bore is creating.
Ill go to my old faithfull University time books and look for it (I am one of those reluctant guys that does neither believe ALL what the TV says, nor ALL what Internet shows...although I trust wikipedya...
The JE piston skirt is shorter than the OEM Suzuki unit.
The piston didnt hit the crank.... but the new sleve was larger than the original, so the cylinder didnt fit the crank
What I did was, assemble the Crank tight as hell, went to my nearest machine shop, and told the guy: "I want this cylinder (with the new sleve installed) installed in this crank. Machine the crank until the cylinder Fits completely". ... and He did it....
Low production days... (ive been working in my Adventure DR in order to start training before September...The Bolivian Stages are in a 3500 / 4500 m of altitude, so I really need a good , flexible and easy tunning carburation, otherwise it will be hard to hit the ANDES with a crappy running bike...
Existing rear wheel dismantled, cleaned and painted....
Ready for new spokes..
I bought this extremly CHEAP STEEL rim....
As I wrote before, Aluminum Rims in big sizes are extremely expensive...to sum up...every kid in town its a wanna be Supermotard Racer...so people is asking impossible ammounts for a Chinnese Aliuminium rim in a decent 4.25 x 17 (note that no fancy Brand like Excel wasnt even mentioned... . )
So this new chromed oldschool steel rim in a (strange nowadays, but really old guys can recognize it) dimensions of 4,1 x 17..
It will allow a propper fitting of a 150/70/17 .... which, by the way, are one of the most common sizes in dual sport nowadays.....and (here my lazy, redneck nature comes to the surface) is one of the sizes where you can find used , almost new and almost for free tyres.... no, I dont own a KLR...(no ofense intended, please).
The reality is that, most of my friends that owns BIG Twins (BMW, YAmaha TDM, Suzys Svs, ETC) use tubeless tyres, and when the have a big puncture, they try to avoid using a heavily repaired tyre at high speeds, so they discharge those almost new tyres....like the KAroo you see in this pictures (instead of installing a nice 5.10 reinforced tube like I do use in this Bike and travel at a nice 110 km/h in any surface...)...resuming, dual sport 150/70/17 cheap provision granted.
Times are GMT -7.   It's 11:32 AM.
