Old 07-08-2013, 08:03 PM   #1
irishdec OP
irishdec's Avatar
Oddometer: 745
Need fellow ADV rider help chain about to break
Hi all.
Need some help here.
On my way from Toronto to Yellowstone with my son.
Riding a DL 1000 and have stopped west of Chicago , noticed a few of my O-Ring rubbers have come loose from the links.
Is this a major problem ?, and should it last till I get to Sioux falls ?- 500 miles give or take ?.
irishdec is offline   Reply With Quote
Old 07-08-2013, 08:10 PM   #2
Navin
Navin's Avatar
Oddometer: 7,841
How many miles on the drive set? Sprockets hooked? I'm guessing pretty worn out?
Best case, start babying it to the next shop that stocks a chain & sprocket set. Too many potentially terrible consequences to regret if it fails.
Navin is offline   Reply With Quote
Old 07-08-2013, 08:19 PM   #3
joexr
Oddometer: 3,773
Keep it lubed in the mean time. The open links where you lost the O-rings are no longer internally lubed. You still have to lube the O-rings and rollers on an O-ring chain.
Old 07-08-2013, 08:24 PM   #4
kubiak
Oddometer: 4,829
i would shoot some chain lube on it often like a non oring since thats what it is now. then get a new one fist chance you have along with sprockets if possible.
kubiak is online now   Reply With Quote
Old 07-08-2013, 10:02 PM   #5
doorman
Aimless
doorman's Avatar
Oddometer: 243
I bought a bike once that was missing probably half the o rings in the chain. I ran that chain for at least 3000 miles before replacing it. Just keep it well oiled, and keep a close eye on it.
Be happy today.
Motoflyfishing
http://www.advrider.com/forums/showthread.php?t=894025
doorman is offline   Reply With Quote
Old 07-09-2013, 05:49 AM   #6
mcma111
mcma111's Avatar
Oddometer: 12,088
The O'rings keep the dirt out of the inner pins and the lube inside the links.
Ride on.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 07-09-2013, 06:41 AM   #7
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,224
Chains didn't even have O-rings for a long time. All it meant was much more frequent lubrication and faster wear. It will be OK for the rest of your trip but replace it when you get home.
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 07-09-2013, 07:07 AM   #8
irishdec OP
irishdec's Avatar
Oddometer: 745
Thanks mates
Thanks to all.
Times are GMT -7.   It's 07:56 PM.
