Old 07-08-2013, 10:28 PM   #1
Straightedge OP
Skin Donor
Straightedge's Avatar
Oddometer: 34
DIY in-the-field flat repair
I'm "working" on a little project here that is a Kawasaki ex500 with klr650 wheels, forks, etc., like some inmates here have done. It has been a long (over a year to get the title), thoughtful, and rewarding process and I've enjoyed all the mental/puzzle aspects of things going together where they were never designed to.
Here's my dilemma. It's time to remove the existing non-DOT knobbies and replace them with dual-sport treads. In my years growing up I can't remember more than a couple flats on our dirt bikes. Every time I've tried replacing the tubes I can't remember ever being successful; ending up taking it to a shop. Now I'm back there again. I've humbled myself and watched how-to videos, read how-to articles and asked mechanics "how-to" remove and replace a tire. This is ridiculous! I'm an engineer-minded detail-guy who's hands feed his family and they're sore and worn out after a couple hours of tire-removal failure and insanity! I promise you i will not shed one more bead of sweat over this seemingly impossible grunt work and will give my mechanic money tomorrow. (Whine, whine...)
Now the obvious secondary problem, and maybe more crucial, is I am still not learning what I need to know: how to make a field repair. And it bothers me. Much. I now have little or no confidence that I will be able to express my "wanderlust" on every gravel road, forest service trail, or deer path that interests me. I surely don't want to be stranded and I surely do want to ride this bike wherever, whenever.
I need some advice here folks. And some affirmation!
Security is mostly a superstition. It does not exist in nature, nor do the children of men as a whole experience it. Avoiding danger is no safer in the long run than outright exposure. Life is a daring adventure or nothing at all.
-Helen Adams Keller
Straightedge is online now   Reply With Quote
Old 07-09-2013, 12:22 AM   #2
3DChief
"Moto therapist"
3DChief's Avatar
Oddometer: 411
Two things about tire changes:
1. The videos make it look simple because that tire has been off/on the rim repeatedly and hasn't sat on that rim for years and thousands of miles. They are not going to put up a how-to video where you watch them curse and fumble for hours with a stubborn tire!
2. Changing a tire is all technique. If you can break the bead, that is the hardest part. As far as taking the tire off or putting it on, if it is hard, you are doing it wrong! The three main points are to have a little air in the tube to prevent pinching it, keeping the tire down in the well of the rim on the opposite side that you are working on, and taking small bites with the tire irons. Also, don't skimp on the lube or use stuff not designed as tire lube. Go buy a gallon of tire lube at Napa for $15 and it will last you for years.
For changing/repairing a tire while out on a ride, I practice changing my tires at home with the tools I carry with me on the bike, even though I have a HF tire changer. I use another bike's kickstand to break the bead, plus a few blocks of 1x4 to put around the rim as I push the bead down until it finally breaks free. After that, it's a 5 minute evolution to take the old tire off, put the new tire on, install the tube, and inflate.
The best thing you can do is watch someone in person change a tire. The videos are great, but you can't ask questions or see everything that is going on. Then practice it yourself with them helping you through the process. In your garage, you'll give up pretty easy, but 20 miles from the closest pavement and help will make you very persistent and inventive to get it done because walking sucks!
Tim
3DChief is offline   Reply With Quote
Old 07-09-2013, 02:30 PM   #3
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,243
Practice, practice, practice. Being able to change a tire in the field is a very handy skill. Walking out sucks. Changing them at home is practice for changing them in the field. It's not rocket science, it just takes practice. The videos help, but nothing replaces practice...see a theme here?
Some tips
- When mounting the tire the opposite side of the bead MUST be in the groove in the middle of the rim. That extra 1/2" makes it much easier to spoon the bead over the rim.
- Warm tires are easier to spoon on/off (Let it sit in the sun)
- Some tires are easier than others. Stiffer sidewalls, slightly bigger rims are harder.
- Get 3 spoons. I like the little Motion Pro steel ones that look like a spoon on the end. My favorite are the Motion Pro ones with the wrench in the opposite end. They are softer aluminium and won't scratch the rim. If you need a 2' long car tire spoon, you aren't doing it right (See top tip).
- It does get easier with time, but is never "fast" in the field - at least for me.
- Carry both a front and rear tube if possible. The front can be used in both in a pinch, but doesn't last long cause it's all folded up in there. If you use a front in the rear, end your ride and head back to the truck/home and change it out ASAP before you get stranded.
- Get a cheapo DC Slime Pump and wire a batter connection for it (Batter Tender connection etc.) and find a place on the bike for it. You get too tired in the field spooning the sucker on - you don't want to have to manual pump also.
Finally, FWIW, I still consider tire changes a home workout myself. It's simple, but not always "easy". I'd still rather do it myself though.
2014 KTM 690R, 2009 KLR650, 2004 KTM 450 EXC, 2000 R1150GS
My MotovLog (Youtube Videos): http://www.youtube.com/user/scottb572/videos
Where Am I via SPOT (Code SCT): http://www.advrider.com/forums/showthread.php?t=719703
Scott_PDX is offline   Reply With Quote
Old 07-09-2013, 11:39 PM   #4
One Fat Roach
One Fat Roach's Avatar
Oddometer: 1,552
Wow great tips. This is one dilemma im not looking forward to on the road. I know it's only a matter or time though. My tires are about spent, maybe another 800 miles or so?, so im guessing it would be a good time to learn to put on the new ones as well? I've never had to deal with a flat or change a tire before. And as I say this im sure I'll get one Friday when I move and head back home to Bellingham from Chelan.
Originally Posted by Mr. Fisherman View Post
This is an adventure, not a field trip!!
One Fat Roach is offline   Reply With Quote
Old 07-10-2013, 04:49 AM   #5
trailer Rails
trailer Rails's Avatar
Oddometer: 3,847
I remember changing my first tires, it was a royal PIA. Now that I have done 100 or so tires, it really is not too bad, I have a 30 gallon metal drum as a stand, a pair of long levers and WD40 in a squirt bottle. Make sure you at least have those 3 things and you will get it.
trailer Rails is offline   Reply With Quote
Old 07-10-2013, 06:03 AM   #6
sTE610vE
sTE610vE's Avatar
Oddometer: 1,998
Tire Lube!
In addition to the tips above TIRE LUBE is an essential imo. I carry a small squeeze bottle with a flip top of Ru-Glyde tire lube but you can use other things like soapy water. I believe lube made for mounting tires is better but I have also heard of people using windex with success.
After you get the bead back on the tire make sure you squeeze the tire away from the rim to make sure you don't have the tube caught under the bead.
And i have the $10 slime pump but I don't carry it on the bike anymore after one failed after only a few uses, they are cheap for a reason. I carry the little more expensive slime atv/motorcycle pump kit that is about $30, I trust it to not leave me stranded, I also carry a very small 6 inch bicycle pump just in case.
TRAIL STAND (advrider thread)- Dual Sport Portable Jack Stand www.endurostar.com
Husqvarna TE630
Cagiva Gran Canyon
sTE610vE is offline   Reply With Quote
Old 07-10-2013, 10:46 AM   #7
jon_l
jon_l's Avatar
Oddometer: 3,153
read all of Neduro's tire changing class thread
http://www.advrider.com/forums/showthread.php?t=50717
I am not an expert, but after reading every post of Neduro's thread, and buying some basic tools, I started changing my own tires and tubes last year. Have done 4 replacement tires and one tube only change so far. It isn't easy for me, but it isn't impossible.
None performed in the field as yet, but I have the kit in case I need to.
CBF1000 & PCX150
jon_l is offline   Reply With Quote
Old 07-10-2013, 11:01 AM   #8
MrPulldown
MrPulldown's Avatar
Oddometer: 3,165
Pinching a tube is no joke. Make sure you know where the tip of your tool is. I guide it in with my fingers to make sure I am not pinching anything.
MrPulldown is offline   Reply With Quote
Old 07-10-2013, 11:16 AM   #9
3DChief
"Moto therapist"
3DChief's Avatar
Oddometer: 411
Here are some examples of the practice you get on the TAT, we had about 20 flats between the two bikes over 7,500 miles of riding last summer:
Oklahoma, 110 degrees, construction staple, patch wouldn't hold, replaced tube:
Arkansas, nail, 110 degrees, able to patch this tube, about 30 minutes total.
Putting new tires on both bikes in the hotel parking lot, Arkansas. You can see my tire/tube repair kit next to the chair.
North Carolina, 100+ degrees, had an audience of Harley riders who couldn't believe you could fix a tire without taking it to a shop, took about 20 minutes but would have been quicker without the audience asking questions!
Along the Blue Ridge Parkway, nail, luckily right as we pulled into the campground, so I could get out of my riding gear and fix it at my leisure!
As you can see, it's really not a big deal if you have the tools and know how to do it. It's also not all that uncommon if you get off the beaten path regularly. For our cross-country trip, we carried two 21" front tubes and one spare 17" and 18" rear tube. I usually patched the hole, replacing the tube was my last resort. One tube had 11 patches before it finally blew a seam and had to be replaced! I have a small repair kit in a tupperware type container that holds patches, spare valve stems, valve stem fishing tool, several small tubes of patch cement (they dry out), small bottle of tire mounting lube, and small bottle of baby powder for the tubes. In my tool tube, I carry 4 tire irons, a small Slime compressor, and also a small bicycle pump, plus rags to lay the parts out on.
I was like you a few years ago and feared getting a flat or changing tires. But this is a crucial skill to learn if you plan on doing much ADV riding and is not as difficult or mystical as it seems. It's not hard to do, but it does take practice and technique. Learn now in the comfort of your garage, because in the beating sun with no shade in Oklahoma when it is 115 F and the closest town is 60 miles away is NOT the place to learn!
Tim
Old 07-10-2013, 09:25 PM   #10
One Fat Roach
Oddometer: 1,552
Also, where can I find those nifty packs that Velcro onto the front fender?? I've seen many of them in photos... Does the pouch come empty and you supply the tools and goodies??
Old 07-10-2013, 09:58 PM   #11
3DChief
"Moto therapist"
3DChief's Avatar
Oddometer: 411
Got mine at Rocky Mountain ATV.com, it came with two tire irons. The clips that hold it to the fender are not to be trusted! You'll lose your fender bag on the first ride. I used a bolt and a fender washer through the bag and fender with a nylock nut on the bottom side, has held up to 15K miles of rough riding. It will hold one tube, two technically, but it will rip out the seams in short order with two tubes in it. I carry the rest of my tools in a PVC tool tube and a small tail bag, but I can fix 99% of the stuff that can go wrong on the trail. Lots of zip ties, safety wire, hose clamps, and tools to fit every nut, bolt, and screw on the bike.
Tim
Old 07-10-2013, 10:13 PM   #12
One Fat Roach
Oddometer: 1,552
Thanks Tim. I was a boy scout for 6 months many moons ago and I learned to always be prepared. I'd rather have the goods and not need them then need them and not have them!
Im learning a lot from you Master Jedis
Old 07-10-2013, 10:19 PM   #13
_cy_
Oddometer: 6,196
holy crap 3Dchief ... me thinks you've got fixing flats down! how did you get soooo many flats?
_cy_ is online now   Reply With Quote
Old 07-10-2013, 10:45 PM   #14
3DChief
"Moto therapist"
3DChief's Avatar
Oddometer: 411
Just lucky I guess!
Nails, drywall screws, chunk of steel, construction staples, and one thorn! All the flats were rear tires, I've never had a flat front tire. Something about how the front tire stands the offending object up and the rear tire hits it just right.
Not running low pressures, 20-22 psi on both bikes. Tires were in good shape with good tread and brand new for the trip. We changed to new tires (and tubes) way earlier than I normally would, but didn't want to risk ruining a once in a lifetime trip because of tires.
Thousands of miles in places like Death Valley, Moab, lots of National Forests, and trails in Alaska, never had a flat tire. On the TAT it was almost a daily experience, sometimes several times in one day!
No regrets! It's all about the memories, and a trip isn't an AVENTURE until stuff goes wrong!
Tim
Old 07-10-2013, 11:59 PM   #15
FlyingFinn
Oddometer: 1,100
+1 on what Chief said.
In addition to using right technique, the right tools make the job also that much easier.
At home I nowadays use the plastic "Stubby" tire levers.
They don't mar the wheels so there's never a need to mess with any sort of wheel savers. The machined end notch grabs the lip of the tire really well while being safer for the tube than a metal spoon.
I change all my tires by hand with levers even at home just for the purpose of getting the practice. And I really like the Stubbies.
Mikko
"It is not when or how you die but how and if you truly were ever alive!" Dr. Jerri Nielsen FitzGerald
FlyingFinn is offline   Reply With Quote
Times are GMT -7.   It's 10:13 PM.
