Old 09-04-2013, 05:15 PM   #31
MCMXCIVRS
MCMXCIVRS's Avatar
Oddometer: 1,223
Originally Posted by LVCJT View Post
My friends bike outside of Las Vegas this past weekend. Between us we had everything needed to change it out. Airing it up was another storyghead:
Sent from the depths of my pockets
Yep, you look just like your avatar Now trying to get that image erased from my permanent memory
If you have space, a small piece of tarp to work on helps minimize the dirt and grit getting inside the tire when there's no clean working surface. Grit inside the tire can grind a hole in the tube and you'll get more practice at fixing it. I cut a 3' x 3' piece of cheap blue tarp material and added it to my tire kit. Also helps to remove as much dust, dirt and mud from the tire and wheel before opening it up if you can.
My opportunity to practice/learn from a couple weeks ago.
Ed
2009 BMW F800GS, 2008 BMW K1200GT
MCMXCIVRS is offline   Reply With Quote
Old 09-04-2013, 06:54 PM   #32
LVCJT
LVCJT's Avatar
Oddometer: 235
Yeah..... Not me. I've thought about doing something similar. I was thinking 18x18 to keep the bearings clean. I was very happy with my kit though neither of us packed our pumpsdown: but we still managed to get the job done quickly for our first time in the field. Luckily we were right outside of a small town so I just took the tire and aired it up. Lessen learned though. Don't assume the other guy has what you may need.
LVCJT is offline   Reply With Quote
Times are GMT -7.   It's 06:49 AM.
