Old 07-10-2013, 07:25 PM   #1
Stroker OP
motorcycle traveler
Oddometer: 184
1100/1150 final drive PTO
Has anyone modified an Oilhead final drive to have a PTO for right-handed driven sidecar wheel? If so are you willing to share your information? Or is there a shop that has performed this machine work?
Stroker is offline   Reply With Quote
Old 07-10-2013, 08:53 PM   #2
FR700
Heckler™©®
FR700's Avatar
Oddometer: 8,458
Been done ... off the shelf parts.
Some light reading for you .
http://www.expeditionportal.com/vehi...car-build.html
I'm diagonally parked in a parallel universe.
FR700 is offline   Reply With Quote
Old 07-11-2013, 08:22 AM   #3
dholaday
dholaday's Avatar
Oddometer: 349
Stroker:
What does "PTO" mean?
Answer to your question: Mobec. Not sure if you can buy one and install yourself - altho Murph did.
Duncan
It is better to have ridden and crashed, than to have never ridden at all.
dholaday is offline   Reply With Quote
Old 07-11-2013, 08:29 AM   #4
norton(kel)
vintage
norton(kel)'s Avatar
Oddometer: 1,272
Question
Originally Posted by dholaday View Post
Stroker:
Duncan
Put The cat Out (power take off)
norton(kel) is offline   Reply With Quote
Old 07-11-2013, 09:35 AM   #5
Stroker OP
motorcycle traveler
Oddometer: 184
output shaft
FR700, thanks for the link...I have sent an email to LBS sidecars in the Netherlands, who did Murph's work, asking if they can/will do the output shaft portion of the conversion. I do not plan on using a Mobec transfer case, just a simple(?) belt driven system similar to one pictured on one of the rigs in the "Smiling Swordfish" thread.
Times are GMT -7.   It's 11:09 AM.
